Offline cazart
#1 Posted : 13 April 2005 02:17:52(UTC)
cazart
I understand that Turn Outs are where trains might be more likely to de-rail or have running problems. First, I would be interested in your experience with this?
Second, I will work with C-Track; and I would like to know if the Wide Radius (R= 1,115.6mm) Turn-Outs (part 24711 or part 24712) are more operationally reliable than the 'standard' Radius (R=437.7mm) Turn-Outs (part 24611 or part 24612). By 'operationally reliable', I mean are the trains less likely to de-rail or have running problems on the Wide-Radius Turn-Out versus the standard Radius Turn-Out?
Offline rugauger
#2 Posted : 13 April 2005 03:45:35(UTC)
rugauger
I would say that one of the most common causes of derailments on turnouts is the sudden change in direction from straight to left/right. This is obviously exacerbated by increases in speed.
I can run pretty much anything at full speed across a wide radius K-track turnout, so I would answer "Yes" to your question. In fact, I came across a site once where someone had used wide radius turnouts for their hidden yard (shadow station) for that very reason.
Richard
Offline frankv
#3 Posted : 13 April 2005 03:55:07(UTC)
frankv
I have never really had any problems with the Standard Radius C track turnouts on most of my rolling stock. The only time I have any issues with derailment is with extra long cars, and this is infrequent.
That’s the great thing about C track.
Offline Lars Westerlind
#4 Posted : 13 April 2005 10:30:10(UTC)
Lars Westerlind
As a matter of fact,
I share one negative experience with some others: One Roco locomotive has difficulties with one of my wide radius turnouts; it's reported to be caused by Roco silent slider with the long distance between the pukos at the rail crossing. But I've had no problems with Märklin rolling stock, and no problems with the sharper radii either.
IT IS a good idea to avoid S-curves however; and this is hard to do with connections between two parallell tracks, unless wide turnouts are used.
/lw
Offline hmsfix
#5 Posted : 13 April 2005 12:07:56(UTC)
hmsfix
I am mostly using K-tracks, but I have never seen any difference between turnouts with small and large radii as far as derailment is concerned.
Some time ago I had a problem with the derailment of long, short-coupled passenger cars and steamer tenders on some turnouts, but this was caused by the underground not being perfectly flat, and the cars collided at their front sides.
Hans Martin
Offline jorge_vilarrubi
#6 Posted : 13 April 2005 15:07:47(UTC)
jorge_vilarrubi
I use large radii in the main track and some small radii in the yard.
Loks of all brands pass across large radii without any problems.
Some Rocos, Fleischmanns and Liliputs do not negotiate small radii.
Cars of all brands can negotiate small radii but no curved turnouts can be used when 2-rail cars are used.
Generally speaking, all Märklin Loks and Cars will operate well with small radii, despite the fact they are not prototypical at all.
The most beautiful C-track curve I have seen has been made with R9 track, the 1,115m one used to compensate large turnouts.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#7 Posted : 13 April 2005 20:40:12(UTC)
I have problems only with long cars.If the geometry and the declivity of your
layout is correct,everything is fine.
Offline cazart
#8 Posted : 13 April 2005 21:36:38(UTC)
cazart
foumaro Posted - 2005/04/13 : 18:40:12
I think I know what you mean by correct Geometry; however, can you explain what you mean by correct 'declivity'?
Offline HueyCE
#9 Posted : 15 April 2005 08:04:02(UTC)
HueyCE
cazart-
Main Entry: de·cliv·i·ty
Function: noun
Inflected Form(s): plural -ties
Etymology: Latin declivitat-, declivitas, from declivis sloping down, from de- + clivus slope, hill; akin to Latin clinare
1 : downward inclination
2 : a descending slope
As to the original question. I have run my trains on both types of C-track turn-outs and have not had any problems with derailment.
Ira
#10 Posted : 15 April 2005 14:18:39(UTC)
or as we say in Scotland...its a wee hill
David
#11 Posted : 15 April 2005 21:13:48(UTC)
Yeah - dooooown we go ... biggrin
Offline cazart
#12 Posted : 16 April 2005 19:09:13(UTC)
cazart
guys, I did understand the dictionary definition of declivity, but how does that apply to reliable running of model trains on turn-outs?
I understood there should be NO slope on turn-outs - is that correct?
Anyway, I am not meaning to be obtuse, I am just making sure that I understand the proper meaning for my question - and it may also help others...
Thanks everyone for your comments, it helps very much.
Offline rschaffr
#13 Posted : 16 April 2005 21:17:00(UTC)
rschaffr
No change of slope, certainly. I do have a case in my EraIII layout where I have one branch of a C-switch going up and one going down. I was very concerned about it but space constraints made me try it. It seems to work ok, but it still worries me.
-Ron
Offline jerdenberg
#14 Posted : 26 February 2006 18:38:09(UTC)
jerdenberg
I am posting in this thread because I have a more or less related question and did not want to open a new thread:
My 3060 Santa Fe F7, converted to digital with a Tams decoder, caused the MS to emergency stop when it encountered a long turn-out on its first test run. A V200 converted with a U75200 did the same. Both did not cause trouble when running over a "normal" K-track turn-out, so I think the long sliders on these old locos are the culprits (they are way longer than the sliders of, e.g. the 37610 PA-1's).
I seem to remember someone mentioning this issue before, but I cannot find that post. Anybody here had the same problem? Is there a shorter slider for these old models?
Jeroen
Offline rschaffr
#15 Posted : 26 February 2006 19:39:28(UTC)
rschaffr
Jeroen: Could have been me. My Lux track cleaning car was terrible with shorting out on turnouts. I determined that it was the length of the slider, so I replaced it with a shorter Marklin one nad have had no problems since.
-Ron
Offline jerdenberg
#16 Posted : 26 February 2006 21:59:13(UTC)
jerdenberg
Hi Ron,
Thanks for the confirmation! Do you have a part number by chance?
Jeroen
Offline Alberto Pedrini
#17 Posted : 26 February 2006 21:59:50(UTC)
Alberto Pedrini
I had this problem with some not Marklin loco, solved tightening the contact points showed in picture.
Alberto
Marklinfan Club Italia
www.marklinfan.net
Offline jerdenberg
#18 Posted : 26 February 2006 22:16:41(UTC)
jerdenberg
Hi Alberto,
I wonder whether our problems were the same.
As to my old locos, I suspect the length of the "old" slider causes it to be "more horizontal than it should be" when its front reaches the crossing track and thus touches that, while the shorter "new" slider is on the incline in its entirety at that point, is at a larger angle and thus free from the crossing track.
I am interested to know in what way your loco caused the short, and how that is now prevented by your technique?
Jeroen
#19 Posted : 27 February 2006 01:18:42(UTC)
Alberto Pedrini
Look at the pic:
the gap between the right rail and the right contact point is very small, about 2 mm.
If the contact point isn't upright the gap can decrease to 1,5 mm.
The trucks of some loco have a action that allow the contact of the internal face of one wheel and the short track has done.
This happen on both the rails, depending from the position of the turnout and the direction of train.
Never happen with Marklin locos, but frequent with Hag and Roco.
For example: the beautiful HAG Ae4/7 cannot absolutely run on this turnouts because it has the drive gear on the internal face of the wheels very large.
Alberto
www.marklinfan.net
Offline rschaffr
#20 Posted : 27 February 2006 01:22:11(UTC)
rschaffr
Jeroen. I can't remember offhand which slider I used. I just took one out of my spare parts drawer.
-Ron
Offline Trainingtime
#21 Posted : 27 February 2006 15:13:35(UTC)
Trainingtime
I have all C Track turnouts and have no problems at all with a variety of Marklin cars and loks. I do not have any "large" locs the size of the Big Boys. Are the "large" locs more troublesome on the smaller radius turnouts?
Offline jerdenberg
#22 Posted : 27 February 2006 22:13:08(UTC)
jerdenberg
As long as there are no small-radius S-curves the Big Boys do manage the smaller-radius turn-outs at slow speed, but I think they look either ridiculous or pathetic doing it, so I am restricting my layout to radius 4 and above.
Ron, interesting spare parts drawer! Strangely, even my antique 3029 has the same huge slider as the F7 and the V200. I will have to pay my local shop a visit then; they are quite well sorted.
Jeroen
Offline rschaffr
#23 Posted : 27 February 2006 22:56:37(UTC)
rschaffr
I tend to accumulate spare parts. For instance, when I decided to start equipping my older loks and cars with NEM pockets for CC couplers, I went through the exploded parts diagrams on Marklin.de and ordered two of every coupler pocket that looked like NEM. I have plenty of light bulbs, brushes, sliders, tires, every type of pantograph, etc. Enough to go into the repair business, I guess. I just don't like to have to wait to do a repair.
-Ron
Offline jerdenberg
#24 Posted : 04 March 2006 13:23:55(UTC)
jerdenberg
Alberto,
Your description fitted my problem after all: the distances between the wheel flanges of my F7 varied from 13.8mm (slightly too narrow) to 13.6mm (guaranteed to cause trouble on the long turn-outs). This seems to be a well-known problem with old models: I found several references to it on German forums. I have increased the gaps to 13.9--14mm and all seems well now.
Jeroen
#25 Posted : 04 March 2006 14:32:08(UTC)
Alberto Pedrini
Smile
Alberto
www.marklinfan.net
Offline perz
#26 Posted : 04 March 2006 22:03:21(UTC)
perz
[size=1" face="Verdana" id="quote]quote:This seems to be a well-known problem with old models:
Yes, I have observed that too. The two wheels on an axle tend to move closer together with time, at least on models from the 60's. I adjusted all wheels on my old rolling stock a few years ago, and went from frequent derailings to almost none.
This page was generated in 0.689 seconds.
