Offline Eisenhower
#1 Posted : 10 February 2005 19:57:46(UTC)
Eisenhower
Just ordered the following from my local M dealer.
1 Pc 39560 Croc.
4 Pc 4756 Sheel tank wagon
1 Pc 7286 Turntable
2 Pc 24922 transission between C- and K track
(Cant wait [:p][:p] - he says that I'll have to wait till next thursday to get all the parts [V] )
I use C-track on my layout but the turntable is K-track.
I will use K-flex track from the turntable into the roundhouse.
Is there any hints - whatch out - be carefull - things that this great forum can tell me about before I ruin everything in my attempt to build the turntable into my table.
I use MDF 12-16 mm as table on my open frame layout construction.
12-16 mm because it would be possible for me to use 16 mm underneeth the turntable if you think its required ?
Any links to building turntables into the table ?
Any thoughts will be most appriciated Smile
Steen
Steen
Digital | C-Track | Epoche II-IV | Railroad & Co. 7.0 Gold | IB 1 | LocoNet
Offline Timaximus
#2 Posted : 11 February 2005 00:27:18(UTC)
Timaximus
Hi Eisenhower,
I build in a turntable a few months ago myself.
Make sure that the rail from the turntable extensions won't move into the turntable direction when you connect a K-track piece to it. Otherwise you can get a shortcut.
Further no problems detected.
Just make the hole diameter in the table 1 cm larger.
Then it is more easier to fine positioning the turntable when connecting to the main track.
Offline Eisenhower
#3 Posted : 11 February 2005 10:13:29(UTC)
Eisenhower
Thx Timaximus
Good point in making the diameter 1 cm larger - I'll do that !
The shortcut advise is also most valuable.
Steen
Steen
This page was generated in 0.527 seconds.
