Offline elsleuth
#1 Posted : 18 January 2005 19:52:24(UTC)
elsleuth
Hi,I have two separate figure 8 tracks and a 32 va transformer for each, can I attach two 32 va transformers to a single 6021 control unit so I can control everything from one control unit and have plenty of power? Kent in CA
Offline Sander van Wijk
#2 Posted : 18 January 2005 20:45:03(UTC)
Sander van Wijk
Connecting 2 transformers to each other isn't recommended. And could even be dangerous.
Using just one 32 va transformer wouldn't release the full power of the 6021. The maximum output of a 6021 is 2,5A, so 2,5A x 16V = 40 va. I would recommend using a simple 52va transformer (Viessmann 5200 or alike) but if you're running no more than 2 or 3 locos, one 32va transformer will do in most cases. (Depends on extra functions, like sound and other differences between locos)
Sander
#3 Posted : 18 January 2005 22:59:51(UTC)
Two transformers should never be connected to each other.
David
Offline elsleuth
#4 Posted : 18 January 2005 23:11:34(UTC)
elsleuth
Thanks for the information, I had a feeling it was a bad idea. Kent
This page was generated in 0.216 seconds.
