Offline Seetal
#1 Posted : 08 January 2005 23:04:14(UTC)
Seetal
Hi there,
Just ran my Seetal 37521. It goes fine in forward, but in reverse the motion is very jerky (slow then fast). I can hear the engine noise changing with these changes in speed. The track is clean and over the same track I do not get the unscheduled speed changes in forward (slider/ski is at front of train).
I ran the engine for awhile in reverse at various speeds and the prblem seems to go away or at least not be so dramatic. I do not know if I will have to do this breaking in every time I run the train. But that would be treating the symptom and I am interested in the underlying cause.
Anyone have any ideas?
By the way I took the cab off the loco but could only see an electronic board I presume to be the decoder (the board blocked my view & access to the engine). All the soldered connections on the board looked clean and tight.
Offline orubias
#2 Posted : 08 January 2005 23:16:10(UTC)
orubias
Is the loco correctly oiled and serviced?
I had a similar problem with a loco not often used, that first was a bit lazy -even had to push it to start moving-, and after a while started to run in a rough way, almost jumping at acceleration and deceleration manouvers. The engine was apparently clean, so after only oiling it, started to run smoothly as usual.
Band on the run
Offline Seetal
#3 Posted : 08 January 2005 23:30:47(UTC)
Seetal
Hi Orubias,
Thanks for the suggestion. My loco has no hesitation in moving in either direction. But maybe I am noticing a lack of oil earlier so if I leave it unoiled I would see the behaviour you describe. So I will read the manual and add some oil to the loco where the manual suggests.
Offline Seetal
#4 Posted : 09 January 2005 04:33:48(UTC)
Seetal
Quick update,
I tried lubricating...little effect
I tried cleaning all my rails (hand wiped with Goo Gone {citrus cleaner, the room smells like Florida now})...got rid of a lot of dirt, helped a little but still had issues in reverse.
I tried GooGone on the loco's wheels (the ones without the rubber tyre). I only rubbed the wheel section that was available since it is a rod driven loco. So only tested that little bit not much dirt came off at first had little effect but now seems to have done the trick..more testing tomorrow.
Thanks again for the advice on cleaning. The strange thing is this loco was only bought (from a dealer) in the summer of 2004, so I have not had 40 hours running time on it [:(] or any of the track I have. I was not expecting to have to clean or lube it yet for quite awhile to come. So thanks again for the advice.
Offline Ranjit
#5 Posted : 09 January 2005 09:08:19(UTC)
Ranjit
Hi John,
Try removing the pickup shoe(s) and cleaning the contact points of oil, dirt, etc. It is surprising how much oil collects in these places.
Cheers and warm regards,
Ranjit
#Get Vaccinated
Offline perz
#6 Posted : 09 January 2005 11:27:15(UTC)
perz
The described symptom does not look like a contact problem. It is most likely some minor misalignment in the motor assembly, combined with lack of oil somewhere. I have had similar problems on a few loks. Usually it's cured by oiling alone, but a few times I have loosened the screws that hold the collector plate a little and then tigthened them again (not too firmly).
thanks 1 user liked this useful post by perz
Offline orubias
#7 Posted : 09 January 2005 13:51:06(UTC)
orubias
Seetal, sometimes brand new locos need to be oiled, as storage/time from assembly/other causes/ may end on a lack of oil.
Personal experience, of course...
Band on the run
Offline Seetal
#8 Posted : 09 January 2005 16:36:23(UTC)
Seetal
So I tried everything again this morning and the problem is still there [:(] and still only when the loco is going in reverse.
I did clean the pick up shoe yesterday also (wiped it with Goo Gone) it was very clean. I also checked the spring in the shoe and it seemd that everything was correclty set up.
Per you mention a collector plate. What is that and roughly where would I find it? I am assuming different models will have it in different places.
I did the experiment of turning the loco on but lifting it up with my hand. I could hear the different engine sounds change(a distinctive change when the speed varies).
When I oiled (I've never done this before) I use the oil sparingly (1 drop from a syringe needle). I turned the lok over oiled the cog wheels I could see and the axle wheel joint for all non-traction tyred wheels. Just one drop of oil (it is a German brand, not Marklin, that is supposedly suitable for oiling).
This is quite frustrating since slowly moving in reverse is a common operation for my train running.
Offline Davy
#9 Posted : 09 January 2005 21:02:03(UTC)
Davy
You have two years warranty use it if you don't like something. This loc I have one to must drive very slow in both directions without any problems.
M-track with a CS2.
Offline Seetal
#10 Posted : 10 January 2005 03:19:51(UTC)
Seetal
Hi Davy,
I will contact a dealer and discuss the next steps.
#11 Posted : 10 January 2005 10:22:26(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Seetal
<br />So I tried everything again this morning and the problem is still there [:(] and still only when the loco is going in reverse
Had the very same problem years ago. Changing the brushes solved it immediately Smile
Offline Davy
#12 Posted : 10 January 2005 14:54:19(UTC)
Davy
Has a seetal brushes? I don't think. It has a engine with a fly wheel.
M-track with a CS2.
Offline nico van zon
#13 Posted : 10 January 2005 16:22:54(UTC)
nico van zon
Davy, what is the relation between flywheel and brushes?
All motors have brushes, except the C-sine.
Offline Seetal
#14 Posted : 27 December 2005 22:24:56(UTC)
Seetal
I returned the train to Marklin USA. Decoder exchange did nothing, so they got me a new train. This one was unfortunately damaged, not Marklin USA's fault, so I returned it again. They managed to get another new engine and this one works fine. While Marklin USA were not the most communicative in this whole epsisoe (it lasted many months) they did stand by their product and they got me a solution I was pleased with. I imagine that their warranty can cause them some issues since it begins upon purchase, and you may buy an itme several years after it left production...yet they must stll honour the warranty.
Anyway thaks to Marklin USA my namesake train is back up and running...at least it will next time I get the carpetbahn going again...but that's a different story.
Online xxup
#15 Posted : 28 December 2005 00:10:49(UTC)
Holey Moley that took 12 months to sort out! Not good at all..
Offline Noel Loganathan
#16 Posted : 28 December 2005 00:26:25(UTC)
Noel Loganathan
How long did you have to wait for a swap or swaps?
Happy birthday mate.
Cheers then
Noel
Noel
#17 Posted : 28 December 2005 00:35:59(UTC)
For future problems I would suggest using RC car motor cleaner spray to clean all contacts. I use this stuff on all electrical Marklin components as well as any electrical terminals on automobiles I am working on. It is strong and effective. However, I'm sure it can't be good for paint. I've always been to cautious to find out the hard way, but just a warning. Spray it onto a Q tip or something then apply to your locomotives.
Offline Seetal
#18 Posted : 29 December 2005 17:42:00(UTC)
Seetal
It took many months about 6 or so for everything to get sorted out. In the course of the "work" I did email Fred Gates and I even sent email to Adams and Unser(?) the marketing guy about the time it was taking.
While the turn around time was not great, in the end they did get me a replacement train. Could the whole response be handled better? Yes. Are they funded and staffed to improve? I don't know. Did I get a repsonse when I emailed Fred Gates? Yes, the reply was quick and promised resolution which they delivered on.
Jerky motion (H0-scale)
by BenP 23/07/2025 16:42:44(UTC)
This page was generated in 0.460 seconds.
