2 Pages12>
Offline Lars Westerlind
#1 Posted : 29 August 2004 10:22:13(UTC)
Lars Westerlind
Well,
what is really known about this? Very little has reached my eyes and ears (except pure speculations). So let's speculate :-)
It appears that the first units which will be able to handle the new protocol are the mobile stations, the mfx decoders, and the CS. I get the impression that the mobile station don't react unless a mfx decoder registers itself during power setup; therefore, I guess noone has yet been able to see any new packets, as the mfx decoders are not available?
It has been denied from Märklin that the new protocol is DCC; it's also clear that Märklin for marketing reasons can't tell the whole truth, as well as can't lye completely. It could be possible to have a new protocol very similair to DCC which is not approved by NMRA, and then it isn't DCC by definition. But it seems a little bit unlikely to me, even if I think it would be smart, as in that way it would be easier for Märklin to reuse existing components.
The specs of the new protocol, or rather, what is told about the new system is that there are 16 k adresses, 16 loco functions, 128 speed steps, and a register function activate at power startup; the digital system senses what mfx decoders are present, and make sures even that two identical locos (with mfx) can be adressed individually. Mark my words, it has not been described as features of the protocol. Also the existing protocol can be used for some of these features, for example as the new BR55 with 8 functions, implented by using two adresses!
So. Perhaps the first question is, is the new protocol an enhancement of the Motorola protocol (1), or is it something completely new coexisting with the Motorola protocol (2)?
1. could be thought of as Motorola New vs Old. I don't think so, it seems very difficult at least to fit 16 k adresses into it.
2. seems more likely, either a third "frequency" opened up and Motorola Style, or something more like DCC (which with Uhlenbrock and lots of decoders coexist), or something completely new. The nature of this is important; with possible new frequencies it might be that the old boosters can't be able to handel the new protocol. And it might be that IB+Daisy can't be software updated to do it either. Any thoughts from those more skilled than me in electronics?
Lars Westerlind
Offline perz
#2 Posted : 29 August 2004 11:25:42(UTC)
perz
According to a previous thread, a Märklin representative had told that the nev protocol is essentially the old protocol, but with extra information sent in the pauses of the packet. Of course it is possible to send DCC packets in the pauses between Märklin/Motorola packages, but this is not likely to be the case.
Until we have real stuff to measure on, we can only speculate, but there are some basic facts that are hard to ignore:
1. The new protocol has to be compatible with all old locos, including 6080, Delta, 6090, 6090x and C-sinus locos.
2. Old control equipment will be able to control the basic functions of the new locos.
This is consistent with the statement about normal Märklin/Motorolas packages combined with new information sent in the pauses. Opening up a new frequency while still using the same protocol might be a possibility, but there are some technical problems with it. If you select a higher frequency than the 9.6 kbit/s now used for accessories, you may get problems with radio interference and increased heat dissipation in the control unit. If yo select a lower frequency than the 4.8 kbit/s now used for loco control, you may get problems with the capacity and reaction time in the system. So, my theory is that they have added a new protocol using signals in the same frequency range as they use now. The actual frequencies used in the Märklin/Motorola system are 19.2 kHz and 38.4 kHz so with a new protocol there is a potential to use the bandwidth more efficiently without going up in frequency. This could still be boosted by a traditional booster.
Another possibility is that they have chosen a completely new method to transmit the supplementary information, e.g. modulation with high frequency low amplitude signals. Such systems could certainly be built and could be given very good functionality, but I doubt that Märklin would go for such an advanced system since it would probably be too expensive.
Offline jorge_vilarrubi
#3 Posted : 29 August 2004 15:04:01(UTC)
jorge_vilarrubi
Hello Perz, Lars, everybody,
I was told that Selectrix is a high speed protocol. It is compatible with Motorola and DCC and used in this way in the Intellibox.
Märklin should keep support to SX as well, since they can't leave the TRIX customers abandoned.
So, in my opinion, another possibility is an enhancement of the SX protocol to support 16K addresses, 128 steps and 16 functions.
Only my speculations, of course.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline Fredrik
#4 Posted : 29 August 2004 15:25:42(UTC)
Fredrik
and another suspicious thing is that "they" (Marklin) specifies 16.384 addresses... for locos? How many then for turnouts? And S88-decoders (or let's say the not known new variant)? Or is it 16.384 for all??? (which is Selectrix-alike, take 1 adress and get 8 turnouts and so on...).
Fredrik.
Fredrik.
WWW: MJ-fjärren
Offline nico van zon
#5 Posted : 29 August 2004 15:34:36(UTC)
nico van zon
Jorge,
there are two reasons why the Selectrix protocol is faster than the other protocols. First, the pulses are shorter. SX: 50uS per pulse, Motorola: 196uS per pulse, DCC: 200/116uS per pulse
Second: Selectrix works with groupaddresses. Other protocols send an address per loco, and data for that loco following the address.
SX sends a groupaddress, followed by the data for seven successive loco's, so saving transmission time for 6 addresses.
Selectrix is not compatible with motorola and DCC as you stated, but the IB sends messages for MM, DCC and SX in sequence. When for instance a Selectrix message is send the DCC and Motorola decoders don't react because they don't understand the "language", and so vice versa.
#6 Posted : 29 August 2004 18:33:17(UTC)
Lars Westerlind
I think I've red from Märklin, that the turnout protocol won't be affected so to say (Fredrik).
Still Perz, do you have any clue then what is meant with 16k adresses, and info in between? IMHO it's basic for the Motorola protocol that the adress is 4 double bits, expandable up to 8 bits=256 adresses. The number of bits couldn't easily be expanded. The major problem is that almost any combination of 18 bits for the first may be "falsely" interpreted by an old decoder. It's easier to think of the new protocol as a combination of old packets for the old decoders, and completely new looks of the new packets, intended for the new locos.
However,
sometimes I have the thought that the marketing peopel are brave enough to tell that there are 16k adresses; meaning that during registry of the loco a connect is done, which dynamically assigns an ordinary 8 bit adress to the loco for that session. In that case, the protocol allows maximum 256 adresses, which also is the limit for simultaneoulsy controlled locos. Still, more locos than that could be identified. But I admit, my thought are rather weird, and Märklin should have a hard time to explain this as 16 k adresses. But not completely senseless; the apparant news with the Märklin systems IMHO, isn't the functions, nor the display or whatever, it's the fact that adresses are under way to disappear from the thinking of the average user.
/Lars
Offline digilox1
#7 Posted : 29 August 2004 19:58:25(UTC)
digilox1
Lars,
A weird speculation from my part.
Guess the 16k addresses in fact are not decoder related, just aliasing addresses.
What if a short shuts down the system with "dynamic address assigning"? How does the system resume operations in this case? How do decoders know about their identity in a digitally controlled environment with old style power off block sections?
How long does it take to identify and dynamically assign addresses for, let`s say, 80 locos?
To Jorge,
Don`t care about the Selectrix users group. They are excellently taken care of By MÜT, Rautenhaus Digital and Doehler&Haass. Far better than any time in the past!
BTW, MÜT is probably the best address when it comes to digitalizing
Z-scale.
Manfred
Offline Fredrik
#8 Posted : 29 August 2004 20:55:46(UTC)
Fredrik
What it says (in the MS-pages) is that "old decoders are reusable without restrictions"... But it won't say if there will be any additionally adresses for switches/signals. Which I think would be neccessary (I surely need to extend the amount of switches and signals beyond 256 if I occasionally had more locos than 80...
I wish Marklin could tell a little more about what's coming. I'm about to upgrade my old 6020 (yes I'm still at THAT level...), and don't know where to go (IB, MS). Currently I use the SRCP-protocol togehter with the computer as "control-box", but I'd like to have the opportunity to play without computer too. And with a growing layout, maybe I must dedicate a single computer to be SRCP-server anyway and then I can rather have a "normal" Central Unit (Central Station/Intellibox...).
My greatest problem is that Marklin won't give away the new interface-protocol - and thereby I won't be able to write my own control software (gives IB an advantage), at the same time I'm Marklinist, and really like the new CS... :-/ Added to that I'm currently starting a new small (modular) layout - and need to know how to wire it... What kind of busses do I need??? CAN, S88, LocoNet...??
Fredrik.
Fredrik.
WWW: MJ-fjärren
#9 Posted : 29 August 2004 23:15:11(UTC)
Fredrik...are you lucky enough to have more than 80 Locos????
David
#10 Posted : 30 August 2004 00:48:58(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by digilox1
<br />Lars,
Manfred
Not weird, however, I don't see the problem. A short is normally detected by the digital system and not the transformer, so also without storing anything in resident memory, there is no problem for the digital system to resume where it was. And the digital decoder of course must remember what the results from the power up negotiation; also when losing power at signals and at shorts. And the negotiation might all the time suggest the same adress as the decoder used last time. But of course there are problems, like how does the registration work, including, how is it known that there are two identical locos present, with the need for different adresses (note, I think I speak about mfx decoders all the time; or rather, decoder with the registry capability). The easisest way would be (in my eyes) if all mfx decoders had a unique serial number.
/Lars
#11 Posted : 30 August 2004 00:59:07(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by fredsaf
<br />What it says (in the MS-pages) is that "old decoders are reusable without restrictions"... But it won't say if there will be any additionally adresses for switches/signals. Which I think would be neccessary (I surely need to extend the amount of switches and signals beyond 256 if I occasionally had more locos than 80...
Fredrik.
Yes, I think you are right. But still guess that they won't change the accessory protocol.
About more news, yes, I guess we all would like that. Including what possibilities there will be for other manufacturers, and how they (including Uhlenbrock) reacts to that.
In my thinking it's more important to know if the mfx-locos will be fully usable with for example Intellibox and Daisy, if the new protocol may co-exist with DCC (nearly the same question), and if the DC brake signal is still understood by the mfx. Central station and Mobile are of less interest, as they represent closed systems.
Lars
Offline Fredrik
#12 Posted : 30 August 2004 01:11:55(UTC)
Fredrik
To David:
No :-( I'm "only" 1/4 of that - and they're not yet all digital...
However - as there are 16.384 addresses available, even if won't ever get close to that amount of locos, it would be interresting to know whether they've thought on adding more switch-addresses too, as even if I had 81 locos, I'd probably need more than 256 switches/signals... And I then would rapidly grow out of S88 contacts (if I don't use the parallell input possible in SRCP, which gives 4 * 496 contacts).
Because: If 256 switches is the maximum - who then needs the possibility of 16.384 locos??? No IMHO there must be possible to add more switches - sooner or later.
Fredrik
Fredrik.
WWW: MJ-fjärren
#13 Posted : 30 August 2004 01:37:43(UTC)
Good point Fredrick. With more and more items now working under digital control you are right about 256 switches.Also Lars point about mfx is interesting although at present there will only be two mfx locos available as far as I can see. Will Marklin be able to change fx and C sine locos to mfx if they wish thus making full use of the new system.
David
#14 Posted : 30 August 2004 01:41:24(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:Originally posted by nico van zon
<br />Selectrix is not compatible with motorola and DCC as you stated, but the IB sends messages for MM, DCC and SX in sequence. When for instance a Selectrix message is send the DCC and Motorola decoders don't react because they don't understand the "language", and so vice versa.
Agreed. I've said compatibility instead of coexistence, which is the actual situation. That is, all three protocols don't interfere wich each other and can be put in the track in sequence without any problem, just as the IB does.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline pcederstrand
#15 Posted : 01 September 2004 13:42:17(UTC)
pcederstrand
Interresting information from yahoo Marklin Bar and Grill
From: "Prof. Dr. phil. Dr. h.c. mult. Dipl.-Ing. Andreas Kreuz" &lt;kd4vs@c...&gt;
Date: Tue Aug 31, 2004 10:58 pm
Subject: Reflections on the M. Mobile Station
If one has an opportunity to spend a little quiet
time with one of the new M. Mobile Controllers,
one will learn the following.
1. Inside lies a "CAN bus" driver chip.
Therefore, one may conclude that the bus which
will connect the various "stations" is a "CAN
bus." (CAN = Controller Area Network.) Please
see
&lt;http://www.semiconductors.philips.com/buses/can/&gt;
for further details of this simple, two-wire
differential serial bus system.
2. The heart of the MS is an MC9S12D64 CPU of the Motorola HCS12 family.
3. The MS also employs a "PT2579-S" chip. The
great Oracle "Google" reveals to her devotees
that the PT2579-S is an RDS (Radio Data System)
decoder. RDS is an "SCA" system with a
subcarrier frequency in the range of 67 kHz, used
by FM Broadcast stations to send ancillary data
such as a station's call letters, format, slogan
(e.g., Jazzy 100), etc. It is reasonable to
conclude that M. or its developer has harnessed
the same, mature RDS technology to enable
decoders talk back to the control station.
Beste Grüße,
Regards /Peter
#16 Posted : 01 September 2004 16:16:22(UTC)
Peter, this is most interesting information, many thanks ! I think we all anticipated M not revealing all her cards when the game started biggrin
By the way, I'm very glad M stayed with MOTOROLA - just like MARKLIN it is top of the line quality (even under badest conditions we never ever have any single trouble with our Motorola 2-way radios [^])
Best Regards
#17 Posted : 01 September 2004 19:45:32(UTC)
As John says this is interesting info. My problem is I havent a clue what all these chips and systems are that the Prof is talking about. I think I have reached the stage where if it works the way I want then I am happy and whether it is Chips French fries or just potatoes doesnt really matter. Terrible thing this getting old!!!!
David
Offline dikken
#18 Posted : 01 September 2004 22:22:29(UTC)
dikken
so with a littleluck I might tune in my radio and find mikado on the displaybiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrin
Dikken
Check out my site:
http://www.modelspoorhobby.be
#19 Posted : 01 September 2004 22:56:14(UTC)
Views messages in topic : 11,165
It was already known that it uses a CAN bus, but that superimposed RDS stuff at 67Khz sounds exciting... A 3rd "channel", so to speak... Loks, accessories and now also feedback...
Offline digilox1
#20 Posted : 01 September 2004 23:50:01(UTC)
digilox1
[size=1" face="Verdana" id="quote]quote:so with a littleluck I might tune in my radio and find mikado on the display
...And if the database isn`t correct it`ll probably play
"Pacific 2-3-1" by Arthur Honegger.
Manfred
#21 Posted : 02 September 2004 09:54:02(UTC)
Lars Westerlind
<br />It was already known that it uses a CAN bus, but that superimposed RDS stuff at 67Khz sounds exciting... A 3rd "channel", so to speak... Loks, accessories and now also feedback...
Can anyone explain to me what this ciruit does? Is there an antenna present also; wouldn't it be easy to identify? If not, does it mean that the circuit interprets messages with the same coding as RDS-messages, but not necessarily transmitted in the air? Would radio transmission be a problem due to the differen national regulations over the world?
A side note: in fact, the Motorola protocol initially was built with Motorola circuits coding a signal in the way we know, primarily intended for transmission by IR, for example control of TV sets etc. Thereafter Märklin has design it's own circuis, and extended the old protocol.
/Lars
#22 Posted : 02 September 2004 11:41:50(UTC)
pcederstrand
Lars
It seems they've done the same again. Instead of adopting a working standard DCC the "invent" a new one i.e. the buy or use something else because the don't have the expertise to do it all "in-house".
So IMHO they will actually use the RDS protocol for the feedback, with the 67 kHz as bearerfrequency in pauses of the controller streams.
I didn't have the time to read through the NMRA RP 9.3.1 and .2 to see if they perhaps uses the same ideas?
But on Zimo http://www.zimo.at/ they have some updated information on feedback.
The information is that the will provide extra circuitmodules for their boosters and that they and Lenz will come out with things this autumn.
As said before the curtain comes up slowly and we will have to wait a little longer til everything is revealed.
Regards /Peter
#23 Posted : 02 September 2004 12:33:05(UTC)
Lars Westerlind
OK.
Is it clear that this circuit is a RDS de-coder then? So that we speak about the "feedback" signal coded like this? Couldn't it be an en-coder which produces the signal for the new protocol as well? 16 k adresses an the like?
And could it be explained how the feedback is done electrically? Should the decoder transmit eneregy to the track in pauses? I guess not, should be harmful if several decoders AND booster transmit energy at the same time, shouldn't it? Is somthing like the booster transmitting a bearfrequence which is modified by the decoder/decoders, and current measured at the booster? I've not taken the time to read NMRA nor ZIMO either, and am probably not knowledged enough to fully understand.
Lars
#24 Posted : 02 September 2004 12:50:48(UTC)
Lars Westerlind
(Continued).
The Zimo link was a good one, thank's Peter. I guess it means that each decoder is capable of sending som energy to the track, in the pauses. And the central tells each decoder, or rather adress, when it is it's turn. And what happens if there are two decoders present with the same adress?
Zimo also compares the DCC approach (which Märklin seems to have adopted, but with a differenct coding), with the IR approach (Uhlenbrocks Lissy = Fleischmann Navigation). I agree that DCC's idea has the great benefit of not needing any extra installation in the Loco. But IMHO, the distinct decision of position in Lissy, combined with the identification of the loco, gives very good opportunitities to control the locos; set light and sound at certain places, stop at certain places, turn, choose turnout positions etc. With DCC the communication is easier, but still, noone knows where the loco is situated.
I now turned the discussion toward real feedback; telling something useful for the central. What Märklin has promised to do is not very useful for me, it's just identifying what locos are present; that I can easily do manually.
#25 Posted : 02 September 2004 15:15:36(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
<br /> ... but still, no one knows where the loco is situated
After having gone high tech with MOTOROLA now MARKLIN should buy into GENERAL MOTORS "OnStar" SatNavSystem. GPS on the layout - what a new dimension [:p]
#26 Posted : 02 September 2004 15:47:01(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by pcederstrand
<br /> ... Inside lies a "CAN bus" driver chip
(www.semiconductors.philips.com)
Since that part is from PHILIPS I can only hope they did a better job here than with their junky tv-receivers [xx(][xx(][xx(]
Offline perz
#27 Posted : 03 September 2004 00:54:59(UTC)
perz
The PT2579-S is an RDS demodulator (receiver) only chip. According to the data sheet, the subcarrier frequency is 57 kHz, not 67 kHz.
#28 Posted : 03 September 2004 01:02:03(UTC)
Which leads to the clever assumption that the mfx decoders will have an RDS modulator(sender) chip onboard. At least as my feeble mind understands it..
(To fredsaf) I think it was said somewhere that the 16384 addresses is the total amount of addresses for all devices, both loks and accessories...
Offline perz
#29 Posted : 03 September 2004 01:26:53(UTC)
perz
Are there really RDS encoder chips? RDS decoder chips make sense since they go into every RDS radio. But RDS encoders are mainly needed in radio stations and test equipment, a much smaller market not worth developing specialized chips for. I have found a do-it-yourself implementation of an RDS encoder, but it requires two PIC processors and a lot of other components. http://members.lycos.nl/rdsencoder/rds1.html
#30 Posted : 03 September 2004 01:29:58(UTC)
<br /> ... 16384 addresses is the total amount of addresses
Yes, Sir. But, for heavens sake, who will ever need so many in real life ??? (or is that just because of the new systems' high capacity ?)
#31 Posted : 03 September 2004 02:23:47(UTC)
Well, some way the mfx decoders will have to send data that the RDS decoder chip will understand... At least as I understand it... Or am I totally stupid here? Or have Märklin designed/programmed another special custom chip to achieve this functionality?
#32 Posted : 03 September 2004 10:13:22(UTC)
Thank you for information, but for me the whole matter now becomes a little bit too high rated - I think I'm the stupid here [:I]Smile
But 16000-plus adresses should be very welcome for a really BIG LAYOUT ... So I guess I will never need such ... [:p]
Offline kgsjoqvist
#33 Posted : 03 September 2004 10:53:47(UTC)
kgsjoqvist
Yes, that is told in Märklin's official documentation. There is no longer a separation between loco addresses and accessories, and most probably all of those can be aliased. Now you have to switch zillions of dip-switches to get the accessory decoders to the right button on your keyboard. With the Central Station they have to be programmable (please, please) so you can get them on any button you like... Otherwise, if the CS puts them in a random order at startup - how do we ever learn what button switches what accessory?
Offline Tamrac
#34 Posted : 03 September 2004 18:20:14(UTC)
Tamrac
[size=1" face="Verdana" id="quote]quote:But, for heavens sake, who will ever need so many in real life ???
biggrinI remember 20 years ago thinking, why would anyone need a hard drive bigger than 10MB? It already holds so much more than this 5.25" floppy...wink
Remember with new technological capability comes new inovative uses.
We will soon be able to press a code on our cell phones (handies) to start our layouts running before we get home[:p]
#35 Posted : 03 September 2004 21:22:54(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Tamrac
<br />biggrinI remember 20 years ago thinking, why would anyone need a hard drive bigger than 10MB?
Fair right - but HO isn't the microcosmos of our computers, so I think we are better off recognizing those outer limits. Also, locos and layouts are bigger than chips so a direct comparison just doesn't work here. Last not least since one single operator can't control dozens of locos or more at the same time - he needs computer control.
Well, and from that point on he has lost control and is just spectator - mutation finished [xx(]biggrin
Offline Fredrik
#36 Posted : 03 September 2004 21:24:48(UTC)
Fredrik
Ok - I must have missed that somewhere, but if 16.384 is the total amount, then somewhere the CS must be told that address X is an accessory address (and of the "old" format, as I anyway suppose there will be a "new" one sooner or later). That is the adresses 1-256 must be possible to assign as accessories, and added to that 1-80 must also be configurable for locomotives (or function decoders) of type Motorola I/II.
I totally agree that must of us won't need that amount of addresses, but as they are a sales argument, one can't help wondering how they're usable. And I was suspecting it would be no separation between locos/accessories no more (Selectrix-alike...?). Then comes the next question, how many (locos) will it be possible to operate at the same time? Probably more than I'll ever will - just want to know... :-P
I guess I'll go for a CS whenever it arrives - just because I like the touch(screen ;-) ) of it, and that the IB will be "old" compared to it. Added to that I don't need the multiprotocol feature (which could be built in the CS), as I really don't have any DCC-locos, and I doubt I'll get any. I'm to Marklinish for that...
I'm not so impressed of the 2 non Marklin locos I do have (austrian brand, swedish locos, light & dark blue... :-) ). However as I've been driving both of them 1:1 I do enjoy having them on the track!
I'd rather have them from Marklin instead though (with operating pantographs) then I'll sell these 2 in notime...
Fredrik.
Fredrik.
WWW: MJ-fjärren
#37 Posted : 03 September 2004 23:29:22(UTC)
<br />However as I've been driving both of them 1:1
Fredrik, sounds great - so you're an locomotive engineer by occupation [:p] ?
Best Regards
Offline Fredrik
#38 Posted : 04 September 2004 18:43:37(UTC)
Fredrik
You can say that my hobby since 1977, is now also my occupation since 15 months - yes! biggrin
So I get to play with trains in 1:1 and are getting paid for it, can it be better??? [:p]
Fredrik
Fredrik.
WWW: MJ-fjärren
#39 Posted : 04 September 2004 18:49:43(UTC)
Great - so you are one REAL PLAYER, enjoy it biggrin[:p]
Offline Fredrik
#40 Posted : 05 September 2004 01:14:40(UTC)
Fredrik
I am!!! Smile
And from now on in 3 scales (1:1, 1:87 & 1:220), as yesterday the Z-starter-set (81781) arrived (to my cohabitee, I'll stay mainly with H0), and we'll see if we can digitaize that too (no MS there, probably Selectrix, so now were really of topic... Cool).
I've also got my eyes on a 29820-starter-set... biggrin
Guess I'll have to do some overtime...
Fredrik.
Fredrik.
WWW: MJ-fjärren
Offline perz
#41 Posted : 11 September 2004 20:33:42(UTC)
perz
I made some quick oscilloscope measurements on the Mobile Station output signal. It sends what looks like ordinary Märklin/Motorola packages, with base frequency 38.4 kHz. (Yes, it is 38.4 kHz here, while the 6021 uses 40 kHz.) These packages are interleaved with some other kind of packages that look more DCC-like. The base frequency for these packages seem to be 40 kHz. I'm no expert on DCC so I cannot immediately say if it is real DCC or something just similar.
#42 Posted : 11 September 2004 22:06:12(UTC)
Lars Westerlind
Thankyou perz for sharing. Any info about the interleaved packets is highly appreciated. I must admit I didn't expect any interleaved packages before the mfx decoders were released. What happens if you pick up this years BR 55, which is said to handle all its functions by using Motorola packages to two different adresses? If you put on all functions, does it send packages to two different adreeses in Motorola format, or does it send to just one and interleaved info for the rest?
Lars
Offline perz
#43 Posted : 11 September 2004 22:42:59(UTC)
perz
Unfortunately the oscilloscope I am using is a simple portable one, with limited recording functions and limited resolution. So I don't have the equipment to analyze the packages in detail. I will probably find out a way to do that sooner or later, but it will not be today at least biggrin.
It seems the intermediate packets aren't exactly DCC either. They look very similar to DCC, but there are noticeable differences. DCC should code a "1" with nominally 58 us low + 58 us high and a "0" with nominally 100 us low + 100 us high ("high" and "low" may be swapped).
I see valid DCC "0"s but the "1"s are a little bit too short, only 50 + 50 us (DCC requires a minimum of 52 + 52 us). There are also occational non-DCC symbols (100 + 50 us).
The intermediate packets are rather long, well over 20 ms. A double motorola packet is less than 10 ms.
Offline perz
#44 Posted : 25 September 2004 00:45:08(UTC)
perz
The new ESU mfx decoder announcements added some pieces of information. They say that the new protocol is bi-phase coded with fixed bit length. This is consistent with what I saw coming out of the Mobile Station. So, the Mobile Station sends out mfx format even if you don't have any mfx loco.
The waveform looks very similar to DCC, but it is a completely different coding. By combining my measurement results with the ESU information given, I can conclude that the bit rate of the mfx format is 10 kbit/s. ESU claims that one loco command takes 5.3 ms, i.e. it contains 53 bits. The "mfx packets" I saw were much longer so probably they contained codes for all the selected locos. But why send this out? The Mobile station should know that all the selected locos had old decoders and that the mfx codes were sent out in vain.
Offline digilox1
#45 Posted : 05 October 2004 09:13:33(UTC)
digilox1
[size=1" face="Verdana" id="quote]quote:Die neue Systemtechnik überzeugt in jeder Hinsicht: Mehr Funktionen, höhere Datenübertragungsrate, simpler Einbau und angenehme Anwendung machen Mensch und Modellbahn fit für eine Zukunft, in der künftig alle Einzelelemente Daten senden und empfangen. Damit gehören Fahrzeuge, Weichen, Signale und Steuergeräte zu einem elektronischen Netz
In short:
In the future all system components will transmit and receive data, thus being part of an electronic network.
The German text is copied from the lead of their systems promotions tour.
Manfred
Offline DigitalBox
#46 Posted : 14 October 2004 15:11:19(UTC)
DigitalBox
Fredrik.
Hello list,
I'm a newbie in this forum. Actually I use an IB to drive my Märklin trains on my layout. The layout is controlled by the computer with Railroad & Co. TrainController (Freiwald Software).
I'm very disappointed and furious that with the new Märklin System (M.S. & C.S.) I c'ant connect the Digital System to TrainController ! [:(!] [V] [}:)]
What about the others computer's program like WinDigiPet, SoftLok, Railware, ... which count a lots of "Märklin users" ?
Bye, Dan
IB 1.5 - Märklin - TrainController 5.0 - Win XP - Mac OS X ;-)
Offline dudok12
#47 Posted : 15 October 2004 10:59:35(UTC)
dudok12
Is anyone aware of patents that ESU or M* may have on the mfx system? One would expect that if the MFX system protocol is covered by a patent it is described in some detail in the patent literature.
OTOH, if it is not covered by a patent if can be reverse engineered by anyone who would want this, such as Uhlenbrock.
Sorry if this has been discussed before...
Cheers, Bernhard
IB since 2000. Latest loc aquisition: 37554 BR 55 a long time ago...
Offline HueyCE
#48 Posted : 16 October 2004 01:46:26(UTC)
HueyCE
Hi and welcome to the forum digitalbox.
#49 Posted : 16 October 2004 02:24:54(UTC)
Welcome, Digitalbox...
It is an interesting question you put here... What software will support the new system from Märklin? Will it be "Märklin software" only, or will the independents get enough information to implement support for the new system too?
Then we are in a "wye"... Should we go the "open" way or should we go the "Märklin only" way?
This is up to us to decide, would we like to follow the current market standards or should we jump onto the Märklin bandwaggon?
Until the Central Station is on the market, and if the "competition" as Uhlenbrock with the IB will "answer", we have no idea about how the market will evolve... If Märklin releases the secrets of the new system, we can have a healthy market, but if they decide to make things like the Intellibox obsolete by keeping their secrets, we will have to choose what seems to be the best for us... Then market forces will either force Märklin to comply and release info about the system, or make other manufacturers to step up another notch and offer the same features that Märklin have with their new digial system, even if another "protocol" is used...
Offline digilox1
#50 Posted : 16 October 2004 07:31:45(UTC)
digilox1
Juhan,
DCC has still ample reserves for expansion.(Now, the allowed address range in CV17 is 192-231...) I haven`t read/heard any complaints about the DCC protocol being too slow.
Bidirectional communication really seems to come soon.
BTW, how will you select an US model with an address following the big road number painted on the sides of its cab, like 9234 with Märklin systems?
A swiss retailer is listing the ESU LokPilot mfx for about 62 sFr.
Same retailer has the Märklin mfx listed for about 113sFr.
The two decoders are possibly identical.
The best DCC decoders are less than the ESU mfx, in most cases.
Touchscreens and the like are not track protocol specific.
Given the prices of "Systems", they probably are promoting DCC,
unintentionally.
Manfred
2 Pages12>
This page was generated in 1.011 seconds.
