Offline Eisenhower
#1 Posted : 20 September 2004 22:26:21(UTC)
Eisenhower
I am on my way building my first layout (open frame etc) [:p]
Today i have build the first uphill turn, 270 degree where the tracks (double track) will cross itself 12,5 cm higher up.
The outer length of the wooden circle (15mm plywood) is 210 cm which approx. gives 0.06 cm incline per. 1 cm - which again is app. 6% incline.
Do you think that is too much?
PS: The double track is R1 and R2.
PSS: I will post pictures when I have done some more wood-work
Thx
Steen
Steen
Digital | C-Track | Epoche II-IV | Railroad & Co. 7.0 Gold | IB 1 | LocoNet
Offline perz
#2 Posted : 20 September 2004 23:08:41(UTC)
perz
I think 6% is a bit steep. It may be difficult to run long trains upwards. There is no absolute limit, but it is recommended to keep it below 4% if possible.
I have a maximum grade of 5% on my layout. It is not totally impossible, but it limits the possible length of the trains. Small locos can only have 4-6 cars before they start to slip.
#3 Posted : 21 September 2004 00:36:07(UTC)
Sounds like a good excuse to use consisting (double or even triple locos)... Isn't this mandatory in mountainous places like Switzerland?
Offline McLae
#4 Posted : 21 September 2004 00:38:36(UTC)
McLae
With inclines this steep you will start to see Enormous (BIG) differences between load-regulated and standard Loks (AC and Delta).
For example, Delta Loks will slow to a crawl or stop on the way up, then at the same setting, will race down at over 300KPH....[:p] Heart stress test for bystandars.biggrin
You will want to refit all your Loks with 6090X or Lokpilots.biggrin[xx(]
I recommend you connect the power and test several of your Loks on the hill to see if you like the result.
Also good idea to roughen the rail tops for traction. My S3/6 would chug for all it was worth going up, with the wheels turning about twice as fast as the Lok was going.[:p][:p] With 2 cars![:0] The 39222 would say "Hill, what hill?Cool".
The McLae
#5 Posted : 21 September 2004 00:50:57(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by McLae
<br />The 39222 would say "Hill, what hill?Cool".
Well - it's a Gator biggrin
Offline Eisenhower
#6 Posted : 21 September 2004 01:39:18(UTC)
Eisenhower
ooopps ....sounds like I have done somethin bad [:0] - made it too steep. [xx(]
I havnt build that much yet that cant be changed wink - so what are you advising me to do ?
Trying 4% !? - but that will give me a slight problem crossing the lower track with only 8,4 cm above level 0.
Or what do you suggest - simply make a test run?
Thx
Steen
Steen
Offline McLae
#7 Posted : 21 September 2004 08:27:58(UTC)
McLae
Try running your Loks and see if they can make the grade.wink
If not, then worry about changing to lesser grade. If your Loks have no problems, no change needed.
To coin a phrase, trust but verify.biggrin
The McLae
Offline Lars Westerlind
#8 Posted : 21 September 2004 10:15:21(UTC)
Lars Westerlind
IMHO,
there is not much problem slope itself. If it were straight. Curves are much worse, that's why I also support trying to lessen the slope if possible, however, 6 % will probably work. I have some small locos with only one traction tire, and in curves only one side will be pushed towards the rail. And if this is the wrong side...
/Lars
Offline Gregor
#9 Posted : 21 September 2004 10:40:32(UTC)
Gregor
In my previous analog layout I fed power to the ramp through a relay. 18V when going uphill, 12V when going downhill, worked perfectly. Steen, will your layout be digital or analog ?
Gregor
Offline Eisenhower
#10 Posted : 21 September 2004 12:42:58(UTC)
Eisenhower
[size=1" face="Verdana" id="quote]quote:Originally posted by Gregor
<br />.....Steen, will your layout be digital or analog ?
Gregor
The layout will be 100% digital.
Steen
Steen
Offline Hannu
#11 Posted : 21 September 2004 13:09:36(UTC)
Hannu
I had 6.7 % slope with R2 and R3 curves in my last layout. Most locomotives had no major problems at normal speed with 3 or 4 long passenger cars, when I used R3 to go up and R2 to go down. However, if some loco had a little old rubber traction tires, it could not go up. Also some locomotives stopped at low speed. So, I recommend that if you will use long trains, it would be better to use larger curve radius.
Offline Gregor
#12 Posted : 21 September 2004 16:10:16(UTC)
Gregor
In a couple of weeks I will be starting the construction of a double storage helix. I want to realise 120 mm height difference per turn. To keep grades down I made an oval, with 2 extra straight sections in one direction and 3 straight sections in the other directions. This results in 3% slope. I'll post a picture tonight.
Do you have space to expand the circle into an oval ?
Gregor
Offline rugauger
#13 Posted : 21 September 2004 18:59:19(UTC)
rugauger
[size=1" face="Verdana" id="quote]quote:Originally posted by Eisenhower
<br />...The outer length of the wooden circle (15mm plywood) is 210 cm which approx. gives 0.06 cm incline per. 1 cm - which again is app. 6% incline.
Hmmm, not sure what you mean by "outer length". According to the good old calcs using Pi (3.141), a full R1 circle should be 226cm approx. and a full R2 circle should be 266cm.
Your 270 degree turn should then be approx. 170cm track length for R1 and 200cm track lenght for R2. A 12.5cm height difference then works out at 7.35% for R1 and 6.25% for R2.
Now that looks - admittedly on paper only - quite steep to me. Especially the 7.35% for R1, unless it will be used for downhill traffic only.
I agree with the others that testing, testing, testing will reveal potential problems. However, you will obviously only be able to test with your current rolling stock. We all know each other well enough wink that it is safe to say that your collection will "probably" biggrin grow in the future. So what then? OK, if you buy locally, you could ask the kind dealer if you could give the loco a little test run on your layout before you make a decision, or borrow an identical model off a friend, or take a 1:1 replica of your helix into the store, or... (You can see where this is going...biggrin).
Perhaps you can try and use a combination of the suggestions made here - reduce the height difference, use larger radii, use an oval shape. In any case, I strongly suggest you stay around the 3-4% mark.
Richard
Offline kimmo
#14 Posted : 21 September 2004 19:39:57(UTC)
kimmo
[size=1" face="Verdana" id="quote]quote:Originally posted by rugauger
<br />In any case, I strongly suggest you stay around the 3-4% mark.
If you have enough space, this would be ideal of course. But if the space is limited, 4-6% will be OK in most cases. If you go over 6%, you can rapidly run into problems. On my layout, where the space is very limited, all slopes are between 4-6% and they still work OK with the rolling stock I have now. Only one short section is 7% and it is clearly not as good as the rest. And this section is almost straigth.
Kimmo
Offline Eisenhower
#15 Posted : 21 September 2004 19:50:13(UTC)
Eisenhower
I want to show you what im talking about - here are 3 pictures.
You are absolutely right Richard in your calculation - the way I have done it is totally wrong - thx wink
I will redo everything !!
Im trying to reach the left section 12 cm higher than level 0. But what I will do instead is starting goin uphill rightmost - just above the radiator and then turn left goin upwards - that way I will get a longer straight where I still can go upwards before I reach the middle section (no frame). Doin this will also keeping me from crossing the tracks again and therefor I could accept less than 12 cm.
The actual track crossing will first be on the left most section.
Therefor I have lots more track length to reach the 12 cm, and also keeping under 3-4% incline as many of you suggest. Smile
Steen
Offline drstapes
#16 Posted : 23 September 2004 03:23:29(UTC)
drstapes
4 percent incline is the limit, less is better. On a previous layout I tried to bend the rules but the resultant slippage or stopping was so disappointing I had to rebuild. my incline. Try a test run with your favouite loco and 3 or 4 long coaches, you will see what I mean
Geoff (UK)
This page was generated in 0.505 seconds.
