Offline leesauer
#1 Posted : 07 October 2008 03:27:15(UTC)
leesauer
Hi Folks,
I just received the Mehano TGV I ordered. What I hadn't quite expected was that it would be "digital ready" meaning that it has a slot to accept a decoder.
OK, fine. Time to learn something new. What I'm having trouble figuring out is what converter or conversion kit do I buy to make this train one I can run with my MS or CS1 (which I have now) or my CS2 (which I'll have as soon as they start shipping them to the US).
I searched through the Marklin database using the keyword decoder and also looked through the Veissmann catalog, but I couldn't figure out what it is I should be ordering. Can anybody help?
Am I going to need to do anything else besides plug in the decoder (and set an address) as part of this process?
Thanks in advance for the help!
Lee Sauer
Sacramento, CA
Lee Sauer
Sacramento, CA
Offline mascagni
#2 Posted : 07 October 2008 07:13:15(UTC)
mascagni
There is a LokSound v3.5 that has the sounds for this train. The problem there is the CS1/CS2 will only allow you to get access to at most 8 functions. However, you can also install a LokSound MFX. Note, if you upgrade to v3 on the CS1, you will be able to control it via DCC. Advantage: the LokSound v3.5 is generally cheaper than the LokSound MFX. Have fun, learn to program a decoder, grow.--MM
Michael Mascagni, Tallahassee
#3 Posted : 07 October 2008 12:09:56(UTC)
Lee, first you should find out what connector the loco has (e. g. NEM 651 or NEM 652).
If you take the ordinary ESU LokPilot you'll just have to plug it in and the loco should run (address 3 is factory default).
If you go for ESU LokPilot mfx then the loco should register automatically (this probably is the better choice for you since you ordered a CS2).
If you want to add a LokSound decoder you'll have to find a place for the speaker.
AFAIK only ESU produces mfx decoders - and M* only lists mfx decoders with 21-pin-connectors.
Offline plavnostruev
#4 Posted : 08 October 2008 02:45:19(UTC)
plavnostruev
Lee,
Your TGV came with Loksound 3.5 installed already.
Select address 3 from either MS or CS and sound off!
Offline leesauer
#5 Posted : 09 October 2008 03:22:27(UTC)
leesauer
[size=1" face="Verdana" id="quote]quote:Originally posted by plavnostruev
<br />Lee,
You're right, Mike!!! I made the mistake of just going by the documentation that came with the train which only indicated a socket. But when I opened it up to check what type the socket was, I was surprised to find the decoder and speaker already present. I then went back and looked at the web site, and sure enough, it said that it was digital and came with sound.
What a pleasant surprise!!!
Lee Sauer
Sacramento, CA
Lee Sauer
Sacramento, CA
This page was generated in 0.282 seconds.
