Offline rugauger
#1 Posted : 29 July 2004 17:28:08(UTC)
rugauger
I need to buy a transformer, but I want a bit more power than the old 6001. On the M* web site, there is a 60052 (the new 60VA transformer) for 220V. I cannot find a 110V equivalent anywhere!
Anyone got any ideas? Just go and buy any 16V AC transformer I can get my hands on? For example, Eurorailhobbies.com have a Wall Plug Transformer 110V - 120V Output 16.5 VAC/40VA designed for Roco Sets i.e 10761.
OR run a 2nd line from the dryer outlet?[B)]
Thanks!
Richard
Richard
Offline rschaffr
#2 Posted : 29 July 2004 18:00:45(UTC)
rschaffr
Bill Ott (Modellbahnott.com) has a 130va transformer for sale for 159.95.
http://www.modellbahnott...omepage/digitalproducts/
I built my own (560VA with 10 4-amp breakered outlets) I posted a picture somewhere else on this site.
-Ron
Offline rschaffr
#3 Posted : 29 July 2004 18:07:59(UTC)
rschaffr
Found it. I used a 35amp (peak load 70amp) 16v filament transformer and broke the output into 10 4 amp circuits. I don't recall where on the net I found the transformer, though.
-Ron
Offline kgsjoqvist
#4 Posted : 29 July 2004 18:34:53(UTC)
kgsjoqvist
Huub Maskant has a description on his homepage on how to make a bigger power supply:
http://www.floodland.nl/trein/info/elektro_en_0.htm
He divides the output into 6 lines, each protected by a fuse. There is a limit to how much power you can use in a circuit - in case of a shortcut the wheels could get welded to the track (or worse if you have your fingers nearby...).
Of course every circuit need its own booster, if you run digitally!
Offline McLae
#5 Posted : 30 July 2004 02:42:38(UTC)
McLae
I have a Titan trafo. Don't remember where I got it from, could have been from RJFtrains.com or Curthel.com
The McLae
Offline rugauger
#6 Posted : 23 August 2004 15:59:20(UTC)
rugauger
Hi all, and thanks for your replies. I have now located a 18V 65VA transformer, so my question is: will the extra 2V fry my 6021 (short term or long term), or will it be OK?
Richard
Offline Davy
#7 Posted : 26 August 2004 00:44:28(UTC)
Davy
18v will be to strong.
M-track with a CS2.
Offline dikken
#8 Posted : 26 August 2004 02:13:32(UTC)
dikken
hi richard,
If you use a ringtransformer converting 230v~ to 18v~ nothing will get fried. The 18 volts are outputvoltage, noncharged. If you measure the output of your 6002 transformer you will also find 18V~ or even a little more. Once you put some load on it, the usable voltage will quickly drop to 16V~. So Huub Maaskant's project is perfectly safe. I'm considering building one myself. The cost would be around 130,00€ for all parts used. Looks like a good deal since one 6002 rates over 60€. Maaskants powersupply offers you 6x 50VA trafo's for less than half of the total price you would pay for 6 mä6002!
Dikken
Check out my site:
http://www.modelspoorhobby.be
Offline dikken
#9 Posted : 26 August 2004 13:17:41(UTC)
dikken
[:I][:I][:I][:I][:I]
Sorry richard,
After further research it seems that the 18 volt is the output under load. the Uncharge output is 19,25 V . I dont know if the two volt extra will make a lot of difference. According to huib maaskant you can use a 17 volt transformer without problem.
sorry again for the misinformation
Dikken
Check out my site:
Guest (4)
This page was generated in 0.312 seconds.
