Joined: 08/03/2004(UTC) Posts: 113 Location: Antwerp,
Hello you all,
I've a sudden and strange problem with my Intellibox. When I was connecting some signals to a Viessmann 5211 modules, I first cut off the power of the IB by pressing the stop button. I made the connections and press the green button (Go), but nothing happened. I had to disconnect the IB from the current and reconnect it to get power again. When I repeated the maneuvre, the same happened again.
I thought first there was some short circuit somewhere, but every connection seemed correct. All signals worked as usual. A few minutes later, when I ran a loc, I pressed the Function button on the right side of the IB after putting the address of the loc and nothing happened. But when I did the same with the left side buttons, everything worked as expected. More strange, when I definied the function of the loc with the left button and passed the loc over on the right buttons, all the defined buttons blinked as they normally do, but if I pressed the off function button on the right, I was not able anymore to reactivate it.
A last strange behaviour was that when I pressed the off function button on the right, the lights of the loc turned on as long as I pressed the off button.
Does anybody have an explanation for such strange behaviours of an IB ? And what can I do to repair these anomalities ?
Thanks for all advice you'll tansmit me.
Bye, Chon |
Chon |
Joined: 19/10/2001(UTC) Posts: 2,379 Location: Lindome, Sweden
Dear Chon, your description doesn't give me many clues regarding the cause of your problems. A few notes I make though.
Taking control of the same loc at both sides seems rather unusual. There is an SO which controls wether this should be possible or not.
And your last note is absolutely normal, for the IB as well as for the 6021. Pressing 'off' means sending 'on' to the loco as long as the button is pressed, and 'off' when released.
Connecting a 5211 couldn't possibly affect the software of the IB, but I don't understand what you mean with 'nothing happened'. If you want help, I think you should tell more details. Do the LEDs of the IB change? Do you get voltage at track? Are you trying to do other maneuvers without desired result? What IS the desired result? And so on.
Kind regards, Lars
Hello Lars,
Thanks for the reply. I'll try to explain in large what happens.
The purpose was to connect 4 signals through a Viessmann 5211 decoder on my track. I did it as before and it always worked well. To prevent any short circuit, I put off the power from the IB to the tracks by pressing the 'stop' button (the red led enlightens). I made the several connections to the 5211 and hen everything is done, I press de 'Go' button to get back the current on the track and all the decoders. But nothing happened at that moment. The led on the IB was still red and the IB mentioned 'power off'. It's when I put off the current of the transfo and put it back again that I get current again on my tracks and the green led enlightened on the IB. If I pressed once again the 'stop' button, I lost the current and was anable to get the power back. That's the first thing I noticed.
Then, to control if everything else still worked, I put a loc on the track. With the left buttons of the IB, I fisrt inserted the address of the loc, than I pressed the 'function' button. The lights of the loc turned on as expected. I did the tests without problem. But it's when I changed the loc, via the right buttons of the IB, that I noticed that the 'function' button didn't work anymore (the F3 and F4 buttons neither). So, to convince me that it was not a general failure, I first addressed the loc with the left buttons and everything worked as exepected. Thereafter, I put the same loc-address on the right after changing it by another one with the left buttons, and it is then that I noticed that the led of 'function' button (that I previously had activated with the left button for that particular loc) turned on, meaning that the IB had remembered that I turned on the function. But if I then pressed the 'off' button ahead of the 'function' one on the right, the loc-lights turned off (as usual), but I was anable to turn them on again with that right 'function' button. No led enlightened neither.
It's only when I pressed the 'off' button (on the right) that the lights of the loc turned on as long as I pressed the button. But you say that this is a normal behaviour. I was'nt aware of it before (but never did such test).
So, the buttons on the right side of the IB that don't work anymore are : the 'Go', the F3 and F4 and the Function. F1 and F2 seems to work well, the leds enlightened as expected also. For the four others, the leds don't enlighten. If I want these functions to work, I have to address the loc first with the left buttons, then to readdress it with the right ones (after given another address with the left ones, so they don't conflict).
Is this explanation enough for you to understand what's happening ?
My desire is very simple : that the IB works as before : when I press a button, that the led enlightens and the appropriate command is transmitted.
Thanks for the reply, |
Chon |
Hi Chon!
I assume what you describe is failure of the IB to return to GO mode after you have pressed STOP by simply pressing the green GO button.
After you pressed the STOP button (red LED on), to restart press and *hold* the green START button for a few seconds and see if the IB returns to normal active mode (green LED on).
Hans |
Hans ... Epoch I to V, M-track, IB with MS |
Hi Hans,
I've tried what you suggest, but it doesn't work. I may press the 'Go' button as long as I wish, nothing changes, the red Led stays enlightened. I've no other alternative than to disconnect the trafo and reconnect it afterwards to get power again.
Thanks anyway for the suggestion,
Chon |
Chon,
Have you tried resetting the IB? Press the green and red buttons at the same time. RESET should show on the screen.
Jack
Hi Jack,
I've just tried. It doesn't work. The power goes off. It seems that the 'Go' button doesn't react anymore. I suppose the other ones do not either. But how can I solve that ?
Chon |
Hi Chron,
Try one more thing. Go into the Basic Settings Menu of the IB and you will find a prompt for Reset. This will reset the IB back to the settings it came from the factory with. If that doesn't work, I would contact Uhlenbrock and explain the problem. You may have blown something.
Jack
Hi Jack,
I think you're right. Something has blown inside. Have another question still. I'm considering to buy an IB-control (Uhlenbrock 65400). Should its 'Stop' and 'Go' functions also be affected or are they working independently from the main IB ?
Thanks for reply, |
Chon |
Chon,
I have two IB Controls. They are very good. However, they are really only slaves of the IB so when you hit the stop button on the IB Control it shuts the power off to the layout just like the IB itself. Now, if they would be affected from what has happened to your IB, I could not say, but my guess would be that they would recact the same. Since you are in Belgium, it should not be a big deal to ship it back for repair. I would call first to see if they have any suggestions before sending it back. Did you try the main reset?
Jack
Joined: 03/01/2003(UTC) Posts: 5,188 Location: Southern New Jersey, USA
Chon:
As a matter of policy, I avoid plugging accessories into my IB (or any electronic gear) while it is energized. Pressing the STOP button only kills track power, not the circuitry inside the IB. In the future I would recommend powering down completely before attaching accessories. |
With the very greatest respect, and bearing in mind that I myself frequently post in the "wrong" area in discussion fora, and that I do not really believe it is a big deal, shouldn't this and some other recent threads actually be in the digital section? I mean, I don't really mind, but some of us are analogue guys, you know... :-)
Hi Jack and Ron,
Yes, I've tried, Jack, the reset procedure. It didn't work. No, I think something has blown as you said before. And Ron must be right saying that cutting the power off on the tracks only is not enough. That will be the lesson, an expensive one [:(!].
I know that IB Controls are acting as slave of the main IB, but if the main IB still recognize the commands given with the left buttons when I pass the loc over to the right section, may I not suppose that the same behaviour will occur when I should use an IB Control ? It's maybe only the right buttons that are affected and not the underlying commands. In that case, I will get the 'Stop' and 'Go' feature temporarily back, no ? Otherwise, I don't understand why the commands could pass over from the left to the right.
But I've to confess, I know very little (to say nothing) about electronics and all that kind of stuff.
Anyway, thank you all for the time spending in trying to explain to me what I have to do. |
Chon |
Chon,
You may be right. I would not venture a guess if you would get the Stop and Go buttons back, but if you are going to get an IB Control, anyway, it may be worth a try.
Good luck and let us know what happens.
Jack
Joined: 13/02/2003(UTC) Posts: 37 Location: Thessaloniki,
Chon, Are there any boosters connected to the IB ?
George |
George |
Hi George,
No, I've no booster for the moment (I'm just at the beginning of the construction of a lay out and it takes much time, not because of a lack of time, but because Märklin is so expensive). But does it matter ?
Regards, |
Chon |
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by chon <br />Hi George,
Just guessing... BTW I have the same problem with you but only some times (IB is not turning to ON state after pushing the red button and then the green one). I didn't have the time to track down this problem, but my first thought was that it had something to do with the boosters being connected to the IB Regards, George |
George |
Well, I don't have a booster attched, but I experience a similar problem.
First the #1 key showed this phenomenon that a simple quick touch would no longer trigger activating the key. Later I noticed that the GO button would do the same. However, as I suggested to Chon, if I press and hold the keys, they will work.
But I have to report that this phenomenon of keys not responding to a qick touch seems to spread. More and more I find myself re-keying loco addresses because keys don't respond as quickly as they used to.
Am I looking at a slow deterioration of the key contacts?
The set-up is in a dry basement. Humindidty is well regulated though we do live in the Midwest with high humidity in the Summer.
Hans |
Hi George and Hans, Did you had the same problem in a similar situation (probably a short circuit, I guess) ? Or did the buttons refuse to respond suddenly ? In my case, it can't be due to humidity, I work in a very, very dry attic  By the way, does anybody here have a IB Control operating ? And in the case someone has, can he tell me if he can cut off and restore the power from the buttons on his IB Control ? Thanks, |
Chon |
Chron,
I have two IB Controls operating. Yes, you can shut off and restore the power from the buttons on the IB Control. As it is a slave unit, you can do almost the same things in controlling locos and power to the track as you can from the IB Control. Of course you can't do programming and change most of the SOs from the IB Control.
Jack
Chron,
The problem, as I recall, showed after a short-circuit. I have three boosters and a 6021 attached to the IB. Under normal circumstances I am able to turn off and then on the current on the IB.
George |
George |
Joined: 15/12/2003(UTC) Posts: 655 Location: Buenos Aires,
My IB is S/N 4nnn, an aged one. I've already replaced several buttons due to malfunction. Some of them needed to be strongly pressed to work, other didn't work at all. I'm not saying this is the same case, only what happened to me. The IB has 3 PCBs. If the problem resides in the upper PCB, the IB can work without it. This was my friend's case, I took the upper PCB out and sent it to U* for repair. Meanwhile, the layout was controlled thru an attached 6021 and two 80fs. So if you buy IB-controls, you'll be able to user them for layout control while your PCB is repaired. I suggest to talk to Uhlenbrock before taking the PCB out. Regards, |
Jorge Vilarrubí Buenos Aires ARGENTINA |
Joined: 01/02/2004(UTC) Posts: 7,464 Location: Scotland
Hi Cromarty. Not so much a transfer to the Digital section but as those into Marklin like me probably havent a clue what anyone is talking about maybe an IB section would be useful where those who use the system can have a blether. Also it could be used to explain just exactly what an IB does as at some point I will be considering the M central Station or an IB. Sorry that this is off topic David |
Take care I like Marklin and will defend the worlds greatest model rail manufacturer. |
...or maybe we need an Intellibox to decode all this stuff with... :-)
Jorge: Did you replace the buttons yourself? You describe what I was afraid of: deterioration of the key operation.
David: "blether?".
Thanks ... Hans |
Joined: 22/04/2004(UTC) Posts: 12,139 Location: New York, NY
Quote:[size=1" face="Verdana" id="quote]quote:Originally posted by cromarty <br />...or maybe we need an Intellibox to decode all this stuff with... :-)
... the Hyperbox [:p] |
I hope no one visits a poor Southener's layout in Brooklyn. Intruders beware of Gators. AT&SF, D&RGW, T&P, SP, WP, UP, BN, NYC, ARR, epI-III - analog & digital Marklin Classics only. CU#6021 FX-MOTOROLA DIGITAL SYSTEM. Fast as lightning and no trouble. What else ... Outlaw Member of BIG JUHAN's OUTSIDER CLUB. With the most members, worldwide
