Offline BarneyG
#1 Posted : 14 July 2004 08:44:15(UTC)
BarneyG
I am a newby but have been reading the posts here for a while. Great assistance for me in expanding my layout. confusedconfused I have just bought a delta controller on ebay which didn't come with any instructions, so am not sure how to connect it. Am I correct in assuming that the red and brown wires from the feeder track go to the red and brown connectors on the controller? Do the yellow and brown wires go to the earth and accessory connect on the transformer? What are the other three connectors for (labelled I, II, and D)? If I have multiple feeder wires on the circuit, I presume they all need to feed into the Delta controller as well?
CheersSmileSmile,
David
M Track, Delta
Offline Lars Westerlind
#2 Posted : 14 July 2004 10:54:20(UTC)
Lars Westerlind
Hello David,
it seems correct. The multiple feeder wires all go to the red connector. BTW, use multiple brown wires as well, this will give better performance.
Is the D blue, right? You don't need it right now, it's used from a 6021 or something, in case you use the 66045 as a booster.
The I and II are grey, aren't they? They allow for connection of an extra hand control, dedicated for adress 80. It's very simple, and can be made by yourself; Rutger Friberg has a schema in one of his books.
Lars
#3 Posted : 14 July 2004 23:28:02(UTC)
Hi David - welcome to the Forum Smile
Offline HueyCE
#4 Posted : 16 July 2004 04:58:47(UTC)
HueyCE
Welcome to the forum.
This page was generated in 0.567 seconds.
