Offline applor
#1 Posted : 19 June 2004 04:48:54(UTC)
applor
Hey everyone,
I've got 2 bottles of glue for plastik modelling, one new and one I've had for a while, and they're both clogged or something.
I'm just wondering what I can do to clean out the nozzles. They are too thin for a needle to fit through.
I tried soaking them in methylated spirits, to no avail.
How can I clean them out? My old one was working at one stage but they clog so easily even if I put the cap on right after use. I bought a new one hoping it would work but it was clogged when I got it!
So very frustrated, help please.
Offline franciscohg
#2 Posted : 19 June 2004 05:37:49(UTC)
franciscohg
Chile
Perhaps just let the little Gremlins to workbiggrin
I bought sometime ago a bottle of Revell glue, it arrived clogged to my place too, i put it away, sometime later i was decided to make it work, and OH surprise, it worked perfectly, what happen, i don't now.
Offline jorge_vilarrubi
#3 Posted : 19 June 2004 05:47:28(UTC)
jorge_vilarrubi
Use heat. I use my soldering tool for having the needle clean. Press the bottle gently while heating the nozzle so the air flows thru it. So simple.
Regards.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
Offline rschaffr
#4 Posted : 19 June 2004 08:08:25(UTC)
rschaffr
I took one wire off a wire brush. Works great. Keep it taped to the bottle.
Added thought: I bought a bottle of Testors glue at a local train store. I really like the Faller Professional, but I was out and needed something. The Testors doesn't set as quickly as the Faller, but it comes with a cleaning wire that fits both types.
-Ron
Offline perz
#5 Posted : 19 June 2004 13:35:40(UTC)
perz
I use one leg of a 1N4148 diode to clean the nozzle. Works well.
#6 Posted : 19 June 2004 13:48:13(UTC)
Hi I use some thin fuse wire which works really well.
Clean the nozzle with a tissue after use and also keep the inside of the cap clean.
Faller is good and I use it all the the time.
David
Offline Frostie
#7 Posted : 19 June 2004 15:00:32(UTC)
Frostie
I use the Tamiya line of glues which come in a glass bottle. The glue comes with a glue brush attached to the lid and it is easy to control application and no problems compared to squeezing glue out of a nozzle. The glue comes in various curing types as well
I used to build 1/35 armor models and got tired of what you guys are talking about.
CS/MS Digital Era 1/2
#8 Posted : 20 June 2004 01:16:29(UTC)
I pull the needle from the plastic bottle, hold with a pair of pliers, and then use a cigarette lighter to heat the whole needle so the glue residues burn away... After the needle cools down, I put it back. Works like a charm, and is also a sensible use of a lighter... My local dealer told me this tip, his main business is plastic models and everything around them...
Offline applor
#9 Posted : 20 June 2004 03:54:27(UTC)
applor
thank you all for your imput
Offline franciscohg
#10 Posted : 20 June 2004 04:19:49(UTC)
franciscohg
Chile
Oh, with all these technic answers i feel a little dumb with my previous semifunny post[:p]
#11 Posted : 25 June 2004 21:07:43(UTC)
Hi Francisco, all:
Don't feel dumb, it's perfectly ok - like my little Gremlins, too [:p], they're sooo helpful, sometimes
This page was generated in 0.325 seconds.
