Offline Monique78
#1 Posted : 27 April 2004 16:29:57(UTC)
Monique78
I'm not happy with Marklin couplings. They don't always catch, they don't pre-couple properly, some old locos just bump against them, and if this happens at a far-end of your layout this is frustrating. Did anyone change to any other type of close couplings that fits the standard slot? the Roco couplings look nice but I have no experience with them. Do they pre-couple with Marklin electric C-track uncouplers? Any comments on Roco or other types?
many thanks
Monique
Offline Lars Westerlind
#2 Posted : 27 April 2004 17:15:57(UTC)
Lars Westerlind
I use Roco so called universal couplers instead of the Märklin ones. I had similair experience as you with the Märklin close couplers. Roco's couple much easier, also by a gentle push of the car. They pre-uncouple with standard decouplers, yes. It's as hard to uncouple manually as Märklin, but when you have learnt the trick it's OK. One single problem though: they are not good togther with locos with hooks, nor TELEX couplers, as there isn't any full loop. It's OK on straight lines, but in tight curves, and when pushing, it's not working properly.
Lars
Offline Winst0n
#3 Posted : 28 April 2004 21:04:01(UTC)
Winst0n
Lars, are those roco universal couplers compatible with Märklin close couplers ? I'd like to know because some non-Märklin coaches can have problems with the Märklin ones, when coupled the couplers scratch along the underside of the buffers or can get stuck on it in a bend...
Regards, Winston
Offline KLB
#4 Posted : 29 April 2004 01:04:21(UTC)
KLB
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
#5 Posted : 29 April 2004 01:09:05(UTC)
Hi Kevin Smile !
Thanks for guiding us - looks great [:p][:p][:p][:p]
But - will it survive the hard world of playing confusedconfusedconfusedconfusedconfused
#6 Posted : 29 April 2004 12:39:57(UTC)
I liked the look of the Viessmann current couplers... I don't have the number at the moment.. Are they any good??
Offline rschaffr
#7 Posted : 29 April 2004 16:19:52(UTC)
rschaffr
Adrian:
They are Viessmann #5048, but they are having a production problem with them at Viessmann (according to the Lok Shop). I have had some on order since November.
-Ron
#8 Posted : 30 April 2004 01:40:40(UTC)
Lars Westerlind
[size=1" face="Verdana" id="quote]quote:Originally posted by Winst0n
<br />Lars, are those roco universal couplers compatible with Märklin close couplers ? I'd like to know because some non-Märklin coaches can have problems with the Märklin ones, when coupled the couplers scratch along the underside of the buffers or can get stuck on it in a bend...
Regards, Winston
Yes indeed they are. One Roco and one Märklin is better than two Märklin. When coupled it's difficult to see the difference. It might be that Roco make it a little bit less close, half a mm or something.
I've also experienced the problem you tell, I don't think there is any major difference in this respect.
/Lars
Offline McLae
#9 Posted : 30 April 2004 06:10:30(UTC)
McLae
I have all three types of Roco couplers; loop, close, and universal(UC).
Loop is Marklin.[:p] Actually, the Roco loops work better than Marklin's for me.
Close is rather odd: from the side it looks like a solid bar. But they do connect well together. Not so good with loops or UC.
Universal has a "hook" intead of a loop. This item gives a very strong connection. You can only separate by pushing up from the bottom of the coupler or by twisting (not easy to do). Best part: the 40351 comes in two parts, which can slide up and down for easy height adjustment (no bending metalbiggrin). NEM, of course.
The easy height adjustment is the best feature! I have several older Marklin and Roco cars (pre NEM 362 socket) where the heights are not standard. These have to be coupled by hand.[xx(]
I have a couple of Roco sets that came with both Close and Loop couplers. I use the close inside the string, and put a loop on each end (for Loks).
Hope this helps!
The McLae
#10 Posted : 30 April 2004 13:07:45(UTC)
I like Roco close couplers. Very easy to remove a middle coach without disturbing the whole train.
David
#11 Posted : 30 April 2004 20:29:24(UTC)
Hi all!
M's "modern" close-couplers [:(!][:(!][:(!] produced several derailments when in a row with older cars (they never ever do that alone) - my trusty Relex couplers beat that junk forty miles by sunday !!!!!!!!!!!!!
Those trains are here for playing [:p][:p][:p][:p][:p] so I switch each new car back to Relex immediately after purchase
#12 Posted : 30 April 2004 20:33:43(UTC)
Did I mention M lets us pay extra money for a troublefree run ? [:(!][:(!][:(!][:(!][:(!][:(!]
#13 Posted : 01 May 2004 00:41:21(UTC)
I run 460s and the SBB coaches... The close coupler rubs on the 460s buffers and after a while you get the occassional decoupling of the loco from the train... Very annoying, but I doubt new couplers will help here.. Unfortunately the picture below is not very clear...
On straight and level track the problem is not noticeable, but even a gentle upward curve can be a problem..
Offline cierra555
#14 Posted : 24 July 2004 04:58:09(UTC)
cierra555
Finally, I decided on the Kadee Couplers here in the USA and so far they are much more reliable and friendly that others that I have tried, and simple to apply to Marklin cars and loks.
#15 Posted : 24 July 2004 13:50:58(UTC)
Hello...
Which Kadee part number did you use? I have heard someone else mention these couplers for the 1 gauge, but I was not aware that they serviced HO as well..
Offline HueyCE
#16 Posted : 25 July 2004 02:15:37(UTC)
HueyCE
Welcome to the forum Richard.
#17 Posted : 26 July 2004 11:36:14(UTC)
Welcome back Richard Smile
Offline digilox1
#18 Posted : 26 July 2004 12:12:14(UTC)
digilox1
Seems the Viessmann couplers are basically Fleischmann "Profi"-close couplers.
The best about the Fleischmann couplers is their look.
They need a hard, or even very hard push to engage and have to be perfectly aligned.
In my opinion, Kadee couplers are unmatched.
Manfred
Offline digilox1
#19 Posted : 26 July 2004 12:18:23(UTC)
digilox1
Monique,
The Kadee item ## are 17-20.
And don`t forget to order the coupler trip pin plier in order to adapt these uncoupler pins to the necessary clearance when travelling
through turnouts and crossings with their elevated PUKOs.
manfred
Offline Peter Neumann
#20 Posted : 29 July 2004 05:46:27(UTC)
Peter Neumann
Try www.kadee.com
These are Kadee couplers made with NEM362 shafts, of various shaft lengths. Available from dealers only.
16 European Coupler (long coupler; short box) 2 pr. 3.30
17 NEM 362 Very Short 7.11 mm (.280 inch) 2 pr. 3.95
18 NEM 362 Short 8.63 mm (.340 inch) 2 pr. 3.95
19 NEM 362 Med. Long 10.76 mm (.400 inch) 2 pr. 3.95
20 NEM 362 Long 11.68 mm (.460 inch) 2 pr. 3.95
Peter Neumann
Florida
#21 Posted : 29 July 2004 05:51:13(UTC)
Peter Neumann
One other point about couplers: because of the size of the Märklin close coupler, they interfere with the buffers on ROCO passenger cars when on a curve, easily causing derailment.
I also use the Fleischmann Profi-Couplers which, as stated earlier, are more rigid and require more coupling force, but provide the closest buffer-to-buffer operation of all close couplers. Hint: the uncoupler pin which faces straight down on the Fleischmann Profi-Coupler hast to be shortened in order to avoid "hang ups" on (K-track) center studs at switches. I cut them half-way in length, then use my soldering iron to melt the plastic to a small ball to keep it in place, since the pin has a mushroom-shaped end.
The Märklin close couplers, as described earlier, also do not consistently couple together.
Peter Neuman
Florida
#22 Posted : 13 August 2004 12:14:36(UTC)
I solved my 460 coupling problem by using the Marklin 72060 Relex Couplers.. The distance between the loco and the first passenger wagon looks a bit long, but it can now take the smaller radius curves without any problems..
#23 Posted : 21 August 2004 13:08:31(UTC)
<br />Hi all!
But at least they do very well when on their own. My new close-coupler-only "Orient Express" runs perfectly troublefree [:p] - just learned a new lesson: NEVER MIX THOSE COUPLERS ... [xx(]
This page was generated in 1.130 seconds.
