Offline jowe7
#1 Posted : 02 April 2004 00:09:56(UTC)
jowe7
Hello
I have just bought 3 pcs of Viessmann 5217 s88 decoders to use for occupied track detection. These are my first s88's ever. I will use Märklin C-tracks and convert them to contact tracks by cutting the ground connection between the outer rails.
I have set up a test track with three contact sections and connected them to one of the 5217's. Then this only 5217 it is connected to the IB.
I have configured the IB to use only one s88 unit. The software version of the IB is 1.302.
I switch the IB to s88 mode. No what happens: All indicator rectangles are filled up on the IB, despite of how many track sensors are connected or what s88 module adress is selected or if there is a veichle on track or not. The "open circles" never show up. I have also tried to switch the 5217 modules, without result.
Have anybody a clue what the problem is?
BR
Johan Westling
Offline KLB
#2 Posted : 02 April 2004 04:39:17(UTC)
KLB
Johan,all,
Did you check the plug and made sure it was insert correctly?
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Offline gtegos
#3 Posted : 02 April 2004 11:06:48(UTC)
gtegos
[size=1" face="Verdana" id="quote]quote:Originally posted by jowe7
BR
Johan Westling
Hello Juhan,
Did you test each section with an Ohmometer to make sure the two rails are separated ?
George.
George
#4 Posted : 02 April 2004 12:32:16(UTC)
Guys the key here is that it happens no matter how many track sensors are connected or even if another (not connected) s88 address is selected.. So maybe are looking at an upside down plug or a dud unit?
If only five sensors were connected, then only five circles would be filled if the contact track was permanent connected to -ve (or brown or earth)
Offline gtegos
#5 Posted : 02 April 2004 13:29:17(UTC)
gtegos
<br />Guys the key here is that it happens no matter how many track sensors are connected or even if another (not connected) s88 address is selected.. So maybe are looking at an upside down plug or a dud unit?
Adrian,
It should be easy to disconnect the cable to the s88 module and see if the IB shows empty circles. If circles are still filled it is a problem with the IB, otherwise maybe the cable is not properly connected.
George
George
#6 Posted : 02 April 2004 14:14:24(UTC)
Yes.. I forgot that the IB might be faulty.. Good test, but too horrible to contemplate if it really is faulty..
Offline jowe7
#7 Posted : 02 April 2004 23:41:11(UTC)
jowe7
Hi folks,
Thank you all for your suggestions. I have double checked the connection between
the 5217 and the IB. Also switched the connecting cable with another one, also
disconnected all sensor cables to the 5217. No changes occur in the IB - all s88
positions lighted.
I have also disconnected the s88 bus from my 5217. Still same indication on the IB. It
seems that the problem is in the IB. However, all other functions that I use in the IB
(loco and turnout control) seems to be OK.
Hardware or software problem?
BR,
Johan
Offline rschaffr
#8 Posted : 03 April 2004 00:08:18(UTC)
rschaffr
I think the current version is 1.5xx. You should consider upgrading. May not fix your problem, but if you have a software glitch it might
-Ron
#9 Posted : 03 April 2004 01:22:33(UTC)
Have you tested with one input of the 5217 connected directly to the transformer brown? If this doesn't show an indication, something is electrically wrong in either the 5217, cabling or IB... I assume you have checked each of the leads in the cable for conductivity to make sure none of them is broken...
It should work fine also with the 1.302 IB software...
Hmmm... We have member in Gothenburg, Sweden, who is an expert at this...wink
Offline jowe7
#10 Posted : 03 April 2004 22:52:16(UTC)
jowe7
<br />Have you tested with one input of the 5217 connected directly to the transformer brown? If this doesn't show an indication, something is electrically wrong in either the 5217, cabling or IB... I assume you have checked each of the leads in the cable for conductivity to make sure none of them is broken...
I have tested my track connections by using a simple lamp, and it works fine. It seems to be the IB that is not working properly. All s88 indicators are lighted in IB even if no s88 module is connected.
Anybody who knows where to repair an IB in Sweden?
/Johan
Offline jowe7
#11 Posted : 04 April 2004 22:29:29(UTC)
jowe7
Update:
Now, I have tried this:
1. Disconnected all 5217
2. Configured number of s88's to 0 in IB
3. Reset IB with solenoid decoder option
... and all s88 boxes/indicators are off. Seems OK so far!
Next,
1. I connect one 5217 and connects 3 sensors (sensor function is double checked
with lamp)
2. Configure IB with 1 s88
3. Start rolling on the test track
... and no reaction on s88 indicators in IB
If i now turn power off and on again on IB, all s88 indicators are lighted on first
module. No changes if I roll off the track. Puh....
I'll try to upgrade the IB software before sending my beautybox away. (Maybe that will
render a thread on M-U.net as well...)
BR
/Johan
Offline jowe7
#12 Posted : 05 April 2004 00:31:29(UTC)
jowe7
Well, I don't give up too early!!
I have recognised some kind of "logic" behind my error. I disconnect all s88's and cables. I configure the IB for 1 s88 connected, reset the IB via solenoid reset option and turn power off and on - then "decoder 1" in display shows all 16 positions on. Decoder 2 and up positions are all off. If I configure for 2 decoders, reset and power on/off, decoder 1 and 2 are shown as fully occupied, number 3 and up are off, and same if I configure for 3,4 or more decoders. If I configure for 0 decoders decoder 1 will show off for all positions. Strange huh? And in all cases no reaction from my 5217 if I try it connected.
Any suggestions before I send the d-n thing in?
/Johan
#13 Posted : 05 April 2004 02:11:32(UTC)
I have followed your problem both here and on the B&G... Sounds strange indeed... Since you don't seem to have a "real" s88 to test with, I could send you one even if it probably would not make any difference if the IB is broke... Contact me via e-mail if you want to test with a Marklin s88 before you send the IB in...
Offline jowe7
#14 Posted : 05 April 2004 18:42:46(UTC)
jowe7
<br />I have followed your problem both here and on the B&G... Sounds strange indeed... Since you don't seem to have a "real" s88 to test with, I could send you one even if it probably would not make any difference if the IB is broke... Contact me via e-mail if you want to test with a Marklin s88 before you send the IB in...
Thanks for your proposal. I have a friend coming by on Friday with a Mä 6088. We try and see what happens then...
#15 Posted : 06 April 2004 02:07:59(UTC)
Well, I can be there with an s88 within 3 hours... winkCoolbiggrin
Where did you buy your IB? In Sweden, or directly from Germany? You can send it directly to Uhlenbrock for repair, but you'll probably have to contact them first and ask for details.
I have never heard of problems with the IB feedback, except for the nr of s88 setting, so I am a bit confused here...
Karl S had some good thoughts on the IBX, but if you can still drive the trains the power stage is certainly not blown...
I hope you get an answer soon from Uhlenbrock, since you said on the IBX that you have sent them a mail...
Guest (10)
This page was generated in 0.435 seconds.
