Offline WelshMatt
#1 Posted : 05 August 2008 17:52:38(UTC)
WelshMatt
I've been looking at the older Marklin digital controllers of late, and while the 6021 seems to be fetching higher prices than when it was available new of late there seems to be little interest in the original system.
What disadvantages would a 6020-based system have? As I understand it I would need 6020, 6035 and a transformer? I don't have any MFX locos and the only function wagons I have are a 49960 messwagen and the digital version of the six-wheeled crane. Would the original system be able to talk to those? The MS I have at the moment can't control the 49960 anyway, and as I understand it the 6020-based system would enable me to have digital point control and multiple throttles with more power?
Matt from Wales.
Offline Sander van Wijk
#2 Posted : 05 August 2008 18:23:47(UTC)
Sander van Wijk
Hi Matt,
Although I don't own the 6020 myself, I'm pretty sure it is based on Motorola I: which implies that it is not possible to control the functions f1-f4. Only f0 can be controlled, which usually means that only the lights of a locomotive can be used. Hence, the six-wheeled crane can not be controlled with the 6020. Anyway, correct me if I'm wrong, as my knowledge on the 6020 is getting a little rusty... wink
Sander
#3 Posted : 05 August 2008 18:50:54(UTC)
The 6020 was production in 1984-1993.
The 6036 control 80 or6036 control 80f (up to five functions) can connect with 6020.
Interesting on ebay?
http://cgi.ebay.co.uk/Ma...rksid=p3286.c0.m14.l1318
#4 Posted : 05 August 2008 18:51:49(UTC)
Hi Matt You mean I can sell my 6021 for more than I paid. Sounds good to me.
David
Offline Hoffmann
#5 Posted : 05 August 2008 19:30:22(UTC)
Hoffmann
Hi Matt,
The # 6020 is just a Central Unit you also need a 6035 to run your trains.
However the # 6020 can be expanded with a Control 80F then you all most have a # 6021.
Martin
marklin-eh
Offline spitzenklasse
#6 Posted : 05 August 2008 19:48:07(UTC)
spitzenklasse
Correct, the 6020 connected to a 6036. The later 6021 had the two combined with the expanded Motorola format for extra functions. It has 4 coding switches on the back for selecting original, or expanded fprmat so as not to confuse earlier digital locs. and cause Led's to blink in excess.
Offline WelshMatt
#7 Posted : 05 August 2008 20:38:10(UTC)
WelshMatt
Thanks chaps - I've done a little research in the meantime and found I need a 6020/6036 to get function control.
David, I was basing that on the fact that they seem to go for very good money on ebay. This is likely to continue until "Systems" is 100% reliable and people are satisfied with it, as from what I see here a lot of people are reluctant to give up their older controllers with a proven track record.
The other part that appeals about the old equipment (apart from it being a fraction of the cost of a CS) is that you don't have to register locos with the unit. Instead you just type in the address and drive off when a new loco arrives.
Thanks Steven, I was looking at that - might well have a bid if nobody else shows an interest. I can't afford to go over about £60 at the moment so I doubt I'll get it, but older digital oddments such as a lone 6020 do seem to pop up regularly for not a huge amount. I'd have no worries about building up a complete system from parts.
One other query - can 6035/6/6f be mixed to provide extra throttles, and if I do that would the 6036/6f keep the ability to control the extra functions?
Edit, I have also seen Arnold-badged versions of a "Control 80f" that looked identical to the Marklin one. Are these compatible with the Marklin kit? They don't seem to attract much interest when they do come up, presumably as people have no idea what they are!
Matt from Wales.
Offline Maxi
#8 Posted : 05 August 2008 21:29:18(UTC)
Maxi
Yes Certain Arnold devices will connect up with a 6020 or 6021 and are fully compatible.
I think you might want to at least try to get a 6021 if your budget permits as this unit would be about as full featured as one might need. If you are wanting to control your layout with a computer then you would also need a 6050 or 6051.
Start adding up the dollars and you migh even want to consider an intellibox as an all in one solution which has two controllers, computer control, multiple protocol capability and you can still add extra modules to it either Uhlenbrock based or Marklin or Arnold based to name a few.
So many possibilities but in the end as long as what you have meets your needs now and somewhat down the road is what really counts.
Offline WelshMatt
#9 Posted : 05 August 2008 21:50:25(UTC)
WelshMatt
Thanks Maxi - the Intellibox and CS are right out, it's a case of having a 6020-based setup vs only having an MS. The advantage with a multi-box setup is that I can buy parts when I can afford to and spread the cost out. Plus who doesn't like having a huge bank of buttons and readouts for a control panel? :D
That ebay set has already attracted a bid so will probably go well out of range. Might have a try for the 6043 memory unit though as that would work with either a 6020 or 6021. Would I need a 6040 as well to control points? I understand what the 6043 does, just not sure if it can be used as a straight (digital) point control box.
What do 6041 and 6038 do?
Matt from Wales.
Offline Lars Westerlind
#10 Posted : 05 August 2008 22:10:24(UTC)
Lars Westerlind
It's perfectly OK to use a control 80f (6036) with the 6020, giving 1+4 functions in principle. However, 6020 supports only Motorola I protocol; with 6021 you may choose I and/or II. The difference in I and II are:
- f1-f4 are sent in a completely different manner. Which means, a decoder understands I OR II, normally not both. Messwagen is I think; six wheel crane possibly II. Messwagen will be controlled by 6020 but not MS!
- Direction info is supplied with II; normally not very important; but may be used to check protcol (lift loco, change direction, set down).
- 6020 has fewer slots (10) in the refresh cycle; not important with modern decoders, but older needed get refresed info about speed. Of course, the number of control 80f etc are then limited to 10; which I don't regard as limited.
You could also get hold of a central control, which was supplied in some start sets, two variations exist. Those are a combination of 6020, throttle with four available addresses (10,20,30,40) and four fixed turnout buttons. It's a real 6020 inside, so with connected Control 80f and keyboard (or interface) you'll still get 80 locos and 256 turnouts...
/Lars
Offline WelshMatt
#11 Posted : 05 August 2008 22:22:26(UTC)
WelshMatt
To be honest the ability to have the Messwagen do its thing properly is another big draw - the crane can go on an isolated section controlled by the MS. The MS can't control the Messwagen. Limited slots are not a problem, I intend to have two or three throttles at most.
Do you have a part number for that central control?
Matt from Wales.
Offline DasBert33
#12 Posted : 05 August 2008 22:41:44(UTC)
DasBert33
No offence but why on earth would you want to spend money on completely obsolete electronic items? There is plenty of up to date controllers available that give you more value for the money (CS, Ecos, Commander, IB, Tams EC, ...) . Get a cheap CS when the new one is announced, I can imagine that prices will drop even more than now.
I have worked (played wink) with 6021, IB and Ecos. And I must say:
6021 < IB < Ecos.
Sure a row of old marklin digital control boxes looks impressive but I bet you will regret spending the money when you see what they really can (can't) do.
Bert
Offline WelshMatt
#13 Posted : 05 August 2008 22:55:16(UTC)
WelshMatt
A bit of ferreting about should get me a 6020 and the other kit to make it work for under £100. I haven't seen a CS for less than three times that.
Matt from Wales.
Offline DasBert33
#14 Posted : 05 August 2008 23:07:31(UTC)
DasBert33
Assuming you already have a transformer of some kind:
You need one 6020, two 6035/6036, at least one 6040 to get the minimal functionality you want. If one box costs 50 euro you are already down 200 euros. That for a system that doesn't properly support modern (motorola 2) decoders and without warranty. You can't connect your MS, nor have I calculated the interface (6051) and memory (6043) functionality you get with a CS.
Bert
Offline WelshMatt
#15 Posted : 05 August 2008 23:19:20(UTC)
WelshMatt
Well I won't be paying €50 a box - I see them for about half that on ebay UK.
It may take a while but the bargains are there, and now I know that I can use 6022 and/or the Arnold Control 80f boxes that gives me even more options.
Matt from Wales.
#16 Posted : 06 August 2008 00:09:13(UTC)
Sander van Wijk
[size=1" face="Verdana" id="quote]quote:Originally posted by Lars Westerlind
/Lars
This is interesting, I also thought that it was not possible to control a pure Motorola I function decoder with the MS. However, recently I've found out that the Kelnerwagen (4998) and the Danswagen (4999) are controllable with a MS. Given that those items are both released in 1988, I think it is safe to assume that these are equipped with Mot I decoders. Therefore, it seems to be possible to control those with a MS and extending this line of thought, it should be possible to control the Messwagen with a MS as well?
@ Matt: Sorry for hijacking your topic... [:I]
Sander
Offline Maxi
#17 Posted : 06 August 2008 00:41:42(UTC)
Maxi
[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33
<br />No offence but why on earth would you want to spend money on completely obsolete electronic items? There is plenty of up to date controllers available that give you more value for the money (CS, Ecos, Commander, IB, Tams EC, ...) . Get a cheap CS when the new one is announced, I can imagine that prices will drop even more than now.
Well I can understand the logic behind the decision of older equipment.
Easier to use, can be fixed loacally instead of sending to Märklin service for most problems, to date more reliable, quicker power on to use time.
I actually went through the process of buying more modules for my 6021 setup and do not regret doing so. I might actually consider he thought of selling my CS and ECOS if I don't feel that it is satisfying my needs and interest. Bells and whistles are not always the best options.
#18 Posted : 06 August 2008 00:46:52(UTC)
Lars Westerlind
Well,
I'm a bit uncertain about MobStat and Motorola I; I thought it was falsely announced to be able to control Tanzwagen and Kellnerwagen, but in the end showed up to only support Motorola II. But don't know.
The list of Motorola I only items is rather short anyway. Here's a start
- 4999 Tanzw
- 4998 Kellner
- 49960 Messwagen (?)
- Old stationary crane decoder
- Home built equipment built on the Motorola chip, for example following Rutger Fribergs book, the original.
The central controls were not sold separately, but inofficially still had numbers 6022 and 6023.
6023 was Central control -i.
6023 controlled accessories 1,2,3,4 instead of 253,254,255,256.
6023 also had a built in computer interface, which I think took ascii commands; but not sure.
/Lars
Offline Maxi
#19 Posted : 06 August 2008 00:49:20(UTC)
Maxi
<br />Would I need a 6040 as well to control points? I understand what the 6043 does, just not sure if it can be used as a straight (digital) point control box.
I think you would need a 6040 as well since the 6043 would simply record information or sequences and replay them back when certain buttons are pressed or conditions reported from the S88 reply modules.
The 6041 is identical to the 6040 in purpose of use but the lights and buttons are to be attached extenally so that you can make a track diagram board.
Marklin 6038/6039 - 25" and 72" extension cables for attaching various digital units to one another.
Offline WelshMatt
#20 Posted : 06 August 2008 00:57:14(UTC)
WelshMatt
Ok - might still have a bid on that 6043 to put aside for future use if it remains cheap enough. As I said, this may take a few months but financially it's my best bet for getting a decent Marklin control system. The MS is somewhat underpowered if you have a few 6080/Delta locos on the layout as I do.
The MS will not control Motorola 1 function decoders, at least, it won't work with my messwagen which just sits there in Km/H mode with the head and tail lights blazing. Thanks for the part numbers - I'd found 6022 but not 6023. Will be cruising ebay for one at a sane price from a seller who accepts Paypal.
Matt from Wales.
#21 Posted : 06 August 2008 01:07:39(UTC)
Matt depending on how long you wish to wait I have a 6021 and memory which I do not use. When the new CS is available I will have the old CS for a backup and will sell the 6021 and memory for whatever is within your budget. Both items are as new and complete with books etc.
David
Offline WelshMatt
#22 Posted : 06 August 2008 02:49:39(UTC)
WelshMatt
Thanks for the offer David, but I'm not sure when I'll do this or even if I will. Marklin is currently competing for my funding with Land Rover bits, so I'd best say thanks but no thanks.
Matt from Wales.
#23 Posted : 06 August 2008 10:12:53(UTC)
Lars Westerlind
You need one 6040 at least to borrow, in order to program the 6043! But then, a 6040 is not needed, if the buttons on 6043 are sufficient.
Remember, a 6040 can be adressed for any 16-group av point adresses; however, changed only when powering down. So if you have &gt; 16 points, you need more 6040s.
6043 might also need a new battery inside, as it would be old today. I would perhaps not buy it on ebay without checking this. I don't know what battery is needed, but it's use is to remember the programming during power down. All other units are either not programmed or use DIP-switches.
/Lars
#24 Posted : 08 August 2008 00:04:16(UTC)
<br />The 6020 was production in 1984-1993.
Sold for £102.00, Thats a high price with serious buyer.
Offline Maxi
#25 Posted : 08 August 2008 01:46:49(UTC)
Maxi
<br />Sold for £102.00, Thats a high price with serious buyer.
For the three items that is a fair price.
Offline kgsjoqvist
#26 Posted : 12 August 2008 13:39:55(UTC)
kgsjoqvist
<br />I've been looking at the older Marklin digital controllers of late, and while the 6021 seems to be fetching higher prices than when it was available new of late there seems to be little interest in the original system.
The 6021 can be found on ebay.de for about 100€, and it is better in every aspect than the 6020. But it is very hard to justify investing in a 6021-based setup if you don't have one already...
Function F1 on 60901 always on with 6020? (Digital)
by Hobbit 20/03/2006 04:06:49(UTC)
This page was generated in 1.011 seconds.
