Offline Caplin
#1 Posted : 23 July 2008 02:32:38(UTC)
Caplin
Hi.
While waiting for my BR 44, I managed to acquire a nice looking and running BR 01 (3048) from the local QXL. It was already digitalized with a 5-pole motor as well as a smoke generator.
However, I have found that the front bogie is shorting when passing my curved turnouts (the only turn-outs I have on my small oval). Expecting that the higher pukos are the source. In the bottom picture it is clear to see, that the front wheels have burn marks. In order to eliminate the shorting I placed a piece of tape on the lower surface of the bogie. Surprise - it worked - no more sparking. So for now the problem is minimized but not solved.
Is there an issue with the very old locos running on C-track?
The front bogie with burn marks and tape attached:
Benny - Outsider and MFDWPL
Offline DasBert33
#2 Posted : 23 July 2008 10:32:19(UTC)
DasBert33
Check the wheel distance. I had the same with an old nohab (same burnmarks on the wheel of the bogie with the slider). I managed to completely fix it by enlarging the distance to the correct value.
There was a thread in here somewhere about that, with a discussion about the correct wheel distance dimensions, but I can't seem to find it. AFAIK It should be around 14.0mm for Marklin, and around 14.2mm for NEM/DC trains.
Bert
#3 Posted : 23 July 2008 13:16:33(UTC)
Congratulations, Benny - one of M's most beautiful classic heavy-metal steamers SmileSmileSmile
Offline Caplin
#4 Posted : 24 July 2008 03:19:14(UTC)
Caplin
[size=1" face="Verdana" id="quote]quote:Originally posted by DasBert33
<br />...There was a thread in here somewhere about that, with a discussion about the correct wheel distance dimensions, but I can't seem to find it. AFAIK It should be around 14.0mm for Marklin, and around 14.2mm for NEM/DC trains.
Here is one of Henrik's:
<br />One of the reasons could be the gauge; Märklin normally needs 13.8-14.0 mm inside space between the wheels, while the DC-norm is around 14.3mm. This is the most common reason fro derailments (on switches).
I think you are spot on, thanks. I measured the distance (back to back of the bogie wheels) on both my brand new BR 64 and the old BR 01. The BR 64 measured 14,1 mm whereas the BR 01 measured only 13,6 mm. I will try to increase the distance and see what happens.
Offline Caplin
#5 Posted : 24 July 2008 03:25:30(UTC)
Caplin
<br />Congratulations, Benny - one of M's most beautiful classic heavy-metal steamers SmileSmileSmile
Thanks John. It is heavy. Looking forward to make it run properly by adjusting the wheel distance.
#6 Posted : 24 July 2008 11:22:38(UTC)
Look at the wheelsflange...! [xx(]
It´s awful... [xx(]
Very extrem high... [xx(]
#7 Posted : 24 July 2008 18:07:34(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
<br />Look at the wheelsflange...! [xx(]
It´s awful... [xx(]
Since not RP25 such is perfectly OK, Goofy Smile - keeps the train on track Smile[^]
I'd rather bother with that rotten wheel #4 ... biggrin
Offline Caplin
#8 Posted : 17 August 2008 00:41:20(UTC)
Caplin
Oops - forgot to follow up. When the wheel distance was corrected the sparking was gone.
This page was generated in 0.415 seconds.
