Offline perz
#1 Posted : 08 October 2003 12:19:08(UTC)
perz
I wonder which the correct base frequency for Märklin digital system is ? Rutger Friberg states 40 kHz, but I have seen others stating that it is 38.4 kHz. I use 38.4 kHz in my home-made system, and it works well, but I want to know which frequency that is the really correct one.
Offline Lars Westerlind
#2 Posted : 08 October 2003 13:05:18(UTC)
Lars Westerlind
Perz,
I use A Scorzoni as reference in this matter, as he made thorough measurements. He states 38.4 kbaud. I doubt you will find any official statement from Märklin, both not about nominal value, and not about tolerances either. I also know that Rutger has admitted that there was some error in his original books; I don't remember the nature of it though; possibly it was an error in suggested values for the RC-bridge determing the frequence of the Motorola chips. BTW, I also got the impression that tolerances have been getting smaller over the years; not surprising.
/Lars
Offline perz
#3 Posted : 08 October 2003 14:44:45(UTC)
perz
The frequency is controlled by crystals in both the Control Unit and the modern decoders, so there shouldn't be much variation. It is easy to measure if you have a 6021, but I don't have one.
#4 Posted : 08 October 2003 16:15:04(UTC)
Lars Westerlind
At last we've found a use for a 6021... :-)
Do you doubt then that Andrea is right? He obviously measured on a 6021? And why do you ask?
/Lars
Offline perz
#5 Posted : 09 October 2003 00:29:06(UTC)
perz
Andrea has made the comment "Comment:this is the clock frequency of the old 6020". Should that be interpreted as if 6021 is different? I don't think so but I don't know.
I ask because I have made a simple control HW that allows me to use the PC as a "control unit" without having to go to real-time programming like DDL. That HW is based on a PIC processor. It uses 38400 Hz since it is 4 x 9600 Hz and I run 9600 baud from the PC. The PIC program becomes much simpler that way, and it has worked very well so far.
Now I am planning to build a new version which is a more full blown control unit (except the booster part, I have a separate booster). I will use a much more capable processor and it is not necessary to match the track frequency to the serial communication baud rate any longer. Of course I want to be as close as possible to the correct nominal frequency to get the best possible reliability.
Offline fredstevens
#6 Posted : 19 October 2003 04:09:28(UTC)
fredstevens
Hi Perz,
As i've developed my own digital system i can asure you the base frequence is 38400 Baud. Or a 26us bitrate. For function decoders like k83,k84 the frequence is twice as high: 76800 baud.
I generate the MM format using a PIC processor at 20Mhz connected directly to the printer port of my laptop. (And my own software!)
Fred
Model Railroad.. more than just a hobby..
Base frequency of Märklin digital (Digital)
by perz 08/09/2004 01:17:32(UTC)
This page was generated in 0.402 seconds.
