Offline Marty
#1 Posted : 14 July 2008 02:19:35(UTC)
Marty
Maybe someone here can dig up some information on these motor brushes as listed in the 1954 Märklin catalog:
The 497/3 P motor brushes are described as brushes for almost all HO gauge locomotives. These brushes look like the usual cylindrical copper mesh and carbon brushes.
The 497/3 LP are described as "similar to 497/3 P for especially slow drive. To be used only in pairs".
What is the difference? And why would one type of brush be better for slow speed running?
Marty
Offline spitzenklasse
#2 Posted : 14 July 2008 04:09:58(UTC)
spitzenklasse
Hi Marty, My best guess would be higher resitance to the commutator from the brushes for slower speed. They are talking back in 1954. That was the old flat style commutator. I'm not sure if even the base 3000 clas 89 Loc. still has it. Use only in pairs is specified because you replace both brushes, never just one. Old and new parts don't mix well. as in the brakes on a car, you want both sides of pads to wear equally the same.
Offline Marty
#3 Posted : 15 July 2008 04:15:45(UTC)
Marty
That sounds about right; use higher resistance brushes to compensate for the transformer's voltage range. I'm sure those old transformers started at 4 or 5 volts, so for a lower voltage, Märklin just increased the resistance at the brushes...
Thanks for the response,
Marty
#4 Posted : 15 July 2008 21:52:04(UTC)
Some of the old Märklin transformers even started at 7 volts, like the 6117 from 1962.
This page was generated in 0.323 seconds.
