Offline nicky52
#1 Posted : 19 September 2003 03:16:37(UTC)
nicky52
Hello crew!
I have to do some electrical repairs on some of my locomotives. I have broken solder joints and wires disconnected. What kind of soldering gun do you use? Also I need to know which type of solder is the best to use on such delicate connections. These are analog locomotives, no modules, yet, but in the future I may digitize them. Any recomendations?
Thanks! Nick in Idaho[^]
Offline perz
#2 Posted : 19 September 2003 13:13:36(UTC)
perz
You should have a soldering iron which is temperature regulated or at least with selectable temperature. (I have one with 3 selectable temperature alternatives, and that is OK). It should be rather small, aimed for electronics. It should have replacable tips, one very small tip and one tip which is somewhat bigger. Straight tips are easier to work with (there are hook tips available as well). A good brand is Weller.
The solder should be standard 60%Sn/40%Pb or 63%Sn/37%Pb solder with embedded resin cores, and not too thick (0.5-0.7 mm is OK).
Offline Charlie
#3 Posted : 19 September 2003 16:07:54(UTC)
Charlie
Hi Nicky,
Lucky for us, they sell the Weller brand here in the USA as well. For the "simple" joints you have to fix right now, any small soldering iron will do. But if you do not have one, and plan to digital conversions in the future, I would buy the one with adjustable temperature, that Perz is talking about. You will find it in better tool stores or electronics suppliers.
#4 Posted : 20 September 2003 01:04:49(UTC)
Weller is certainly German quality all through, we have them at work. It might kind of overkill if you get the more expensive models. But those are real professional tools.
Otherwise, almost any cheaper temperature regulated soldering station is ok as long as you can change the tips and vary the temperature. I myself use a Velleman VT-SS30 Digital soldering station and am very happy with it. Much cheaper than Weller too... wink
It is worth the extra money to buy a soldering station instead of that cheap low-power soldering iron in the hardware section of the nearest department store... Smile
Do a search for "Weller soldering station", and you get tons of US electronics shops selling them... Even Micro-Mark has one of their cheap models as their only offering in soldering stations...
This page was generated in 0.280 seconds.
