Offline HvR
#1 Posted : 23 May 2003 14:45:48(UTC)
HvR
Hello All,
Can someone please exlain the following strange issue:
As recommended in the Marklin digital handbook, I installed 1.5k resistors on all isolated track sections longtime ago. I also installed "track occupation" detectors, in combination with s88 decoder, as outlined on the following website: http://www.heise.de/ct/R...cm/buch/digit_8.html#GB8
All worked fine for a long time. Even when a loc is in the isolated track section (f.i. before signal), still a "track occupied" signal is given, detected through the small current flowing through the resistor.
However, some time ago I bought my first loc with a 5 pole motor (green persil dampfspeicherlok) which is acting strange in this setup (I only had 3 pole motors before). This specific loc makes a soft but anoying whistling sound while entering the isolated track section. After some experiments I changed the 1.5k's into 4.7k's. Result: whistling sound almost disappears, isolated loc still listens to commands from 6021 and "track occupation signal" is still working. When going to higher resistor values, track occupation signal is no longer given.
I asked Marklin where this whistling sound came from and if it could hurt/damage the decoder, but all they answered was that I had to remove the resistors to make the whistling disappear. No further explanation.
But then my track occupation will not work any more. Question to this forum: I am still wondering where the sound came from and if it is hazardous.
By the way: It can't be that bad, because the system works for half a year now without problems.
Hans
Offline KLB
#2 Posted : 23 May 2003 19:36:04(UTC)
KLB
Hi Hans,all,
I thought that 1.5 resistors,in these track sections was for the old 6080/early 6090 decoders,so they won't lose their memory(?).Do you have some of these loks?
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Kevin!
Offline Lars Westerlind
#3 Posted : 23 May 2003 20:13:53(UTC)
Lars Westerlind
Hi Kevin,
I think you are right, they are not 'needed' for modern decoders. However, to me it appears that Hans has another use for them, to detect track occupancy. But I have no clue to his problem, listening with interest...
/Lars
Offline Maxi
#4 Posted : 23 May 2003 20:22:36(UTC)
Maxi
I have noticed the same thing when I added the braking section to my layout. I removed the 1.5K resistor and all is fine. It is my understanding that the 6021 unit keeps sending the commands over and over during operation where the 6020 does not.
For train detection I just isolated one of the running rails and connect it to the S88 module, I connect multiple sections of track to one S88 input. The wheelset on the locomotive or railcars will complete the circuit and show if a section of track is being occupied. This method allows me to scan the whole layout to see if a railcar is where it is not suppose to be. The only section of track I do not check is the turnouts.
This setup has worked very well for me.
Offline HvR
#5 Posted : 26 May 2003 14:41:47(UTC)
HvR
Hello everybody.
Thanks for your reply. Here are some return comments.
- Yes, I still have about 10 loks equiped with "old style" decoders that need the resistors for preventing a memory loss. Replacing them by new 5 pole ones would be very nice, but simply exceeds my budget. There are nicer ways to spend my money to my opinion. Again, using 4.7k resistors works fine instead of the 1.5k ones.
- at the time I started my layout, I still had a 6020 (bought way back in the eighties). Just recently when I got my first lok with additional functions I bought myself a 6021.
- The nice way of using the described track occupancy detectors is that they can be easily retrofitted on existing layouts without changing track sections. I have primarily the old metal track and this way of detection works perfect with that type of track. Isolating single rails is not easy on M-track. Last but not least, this occupancy detector costs less than 1 euro per track section, including self made print circuit. Also the s88 decoders (or should I say encoders) are self made.
So basically the existance of the resistors is not so much a problem. The described way of train detection is highly preferred and recommended by me. I am just still wondering where the noise comes from and if it can do any potential harm to the decoder or motor.
By the way, it is strange to observe that marklin advised to use the 1.5k resistors in its digital handbook when in the same book the use of a 6021 + the new decoders were mentioned as well. No single line about the need of removing them while replacing the 6020 by a 6021.
Hans
Offline Nuno
#6 Posted : 27 May 2003 22:57:04(UTC)
Nuno
Dear Hans
I have 2 five pole locos with the whistling function. I am building my layout, which is quite large and I have a lot of turnouts and double crossings in the station area. When I put the whistling function on, as well as the lights, the locomotive whistles and the lights ficker a lot and "hesitate" to advance. I thought it was due to dirt, so I have cleaned the track carefully and the problem persists. So I think that I will have to put some more feeder wirings, because the contacts may become not so good (although it is track "C") due to many turnots. What do you think ?. Also, each time the lights flicker, the whistle goes on, as the whistling function is on and after a very brief current interruption the loco interpretes the information coming from the 6021 as a new command for whistling (I think!). Maybe it is something similar to what happens to you.
Nuno
This page was generated in 0.420 seconds.
