Offline rhopke
#1 Posted : 15 February 2003 20:28:20(UTC)
rhopke
I just got a 29856 digital starter set and just completed setting it up. I have the 6001 power supply and 6021 control unit. everything appears to work properly when I first turn it on, the 99 appears in the let display on the 6021 for a second and then both trains start moving. They will not respond to commands except the stop command and go. I think this is some sort of conventional operation, but how do I change the mode to digital.
Offline perz
#2 Posted : 15 February 2003 21:05:03(UTC)
perz
Open up your locos and check that they are configured to valid addresses. The valid address setting alternatives should be found in the instructions coming with the set. If this is correct and it still doesn't work I have no ideas.
Offline perz
#3 Posted : 15 February 2003 23:50:25(UTC)
perz
Hi Rhopke, all,
The following may be a bit technical for the purpose of solving your problem, but I think it can be of common interest:
I think there was a similar problem discussed earlier, and I think the cause was that the loco had the "idle" address set (all 8 dip switches off). In the decoder, this is a valid address, and can be used if you have control equipment that can command it. According to http://spazioinwind.libe...it/scorzoni/motorola.htm the 6021 sends an idle code with data value 0 at start up. This does not cause the locos to move. My suspicion is that the 6021 actually sends out something else than 0 at the idle address during start up. I don't have a 6021 myself so I can't check.
I have also tested other invalid settings of the dip switch, but it is only the valid settings and the "idle" setting that work. With other invalid dip switch settings, the loco is just "dead", even if you send codes that would match the actual setting.
#4 Posted : 16 February 2003 01:36:57(UTC)
You have been a member since:: 25/07/2001(UTC)
Rhopke, welcome to the forum..
This sounds very strange indeed, since nothing should move until you address it... What happens when you address a loco and try to control it? Do you also know what addresses the locos have? If you are not sure, open them and tell us the switch settings.
The 6021 can be "told" to recall the last running addresses & speeds set, but that requries a certain key combination as I understand - not by default when you power it up...
Sorry to ask this, but are you sure you have wired everything correctly (of course you have...) according to the manuals that came with the set?
If the wiring is correct, it would indicate a faulty 6021 control unit from factory, I have never seen one so far but maybe it is so...
Offline McLae
#5 Posted : 18 February 2003 01:16:26(UTC)
McLae
This sure sounds like a wiring problem.
From the 6001 comes a brown and yellow wire to the 6021. From the 6021 comes a brown and red wire. The two brown wires can touch and no problem (ground). The yellow (gelb) wire from the 6001 must NOT touch the red output from the 6021, and the track center rail must be connected ONLY to the red wire.
If this does not help, maby the 6021 is bad.
The McLae
Offline Thanos
#6 Posted : 18 February 2003 08:37:23(UTC)
Thanos
Hi Rhopke and welcome to the forum!
Hi all!
I am not sure but I have the slight impression that our fellow Marklinist Rhopke did only what is mentioned in the post and the solution is much simpler!
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote>
...just completed setting it up!
... the 99 appears in the let display on the 6021 for a second and then both trains start moving... They will respond only to the stop and go command
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=1 id=quote>
Each locomotive has to be addressed by the 6021, individually! I am guessing that after the 99 appears on the led display and when the trains start moving the led display displays nothing! Right?
Rhopke, first of all each locomotive inside the starter set has a user manual! In there you will find a table that has all the available locomotive addresses that you can set by yourself as well as the different digital functions that each locootive has! One of these addresses is in bold typing! This is the address of the respective locomotive! type that address using the 6021 keypad! When you see that address on the led display you are able to address that specific locomotive! Everything is in the manual...
Thanos
"When everybody fails, just read the manual" <img src=icon_smile_cool.gif border=0 align=middle>
Thanos
Offline tayloma
#7 Posted : 18 February 2003 12:20:36(UTC)
tayloma
I have to disagree with Thanos - when you first turn on the 6021 nothing should happen - the loks should not start moving of their own accord until you select one and give it a command. The guy's problem is that when he turns on the power everything starts moving at teh same time - I think the 6021 is defective or the wiring is wrong. Are the red and brown wires connected correctly to the track? Red is the encoded command signal and brown is the earth. Red must feed the center studs...
Mark
Mark
Offline john
#8 Posted : 18 February 2003 13:20:37(UTC)
john
Maybe its stupid but have you ever consider that the locos are addressed for analog operation.
If you put an analog loco to a digital circuit that excactly is what happened
Regards John
Offline PeFu
#9 Posted : 18 February 2003 13:49:30(UTC)
PeFu
Hi Rhopke, all,
I agree with John, it might be that the addresses are set to "off", i.e. analogue/conventional. Are the 8 dip switcheas of the loco decoder set according to this table? (i.e. not set to "off")
http://peter.funck.net/Digital_Addresses.htm
<img src=icon_smile_cool.gif border=0 align=middle> Peter
Offline perz
#10 Posted : 18 February 2003 19:44:54(UTC)
perz
Hi John, Peter, all,
All switches set to "off" sure means analog operation for old 4-dip-switch Delta locos.
However, the digital starter set contains fully digital locos with 60901 decoders. For these decoders, the "all off" setting is just like any other valid address setting. If you really send out the digital codes corresponding to the "all off" a.k.a. "idle" address, the locos with all switches off will be commanded by the data part of the codes. So, with these decoders there is no "AC/analog" setting.
The 6021 should transmit to the "idle" i.e. "all off" address before any loco is selected. It may be, as I suggested a few posts up, that this initial idling actually contains a data part corresponding to a non-zero speed. In that case the mystery is solved.
Unfortunately I don't have a 6021 so I cannot test its startup behaviour. Maybe someone else could do that ?
(You may wonder how I know that the "all off" address works as a normal address ? I have tested. I have a direct drive equipment and can send all possible codes from my PC.)
Offline Thanos
#11 Posted : 19 February 2003 08:26:07(UTC)
Thanos
Hi all:
<BLOCKQUOTE id=quote><font size=1 face="Verdana" id=quote>quote:<hr height=1 noshade id=quote>I have to disagree with Thanos - when you first turn on the 6021 nothing should happen - the loks should not start moving of their own accord until you select one and give it a command.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana" size=1 id=quote>
Mark, most probably you are right and this is a case of bad wiring or defective 6021. <img src=icon_smile_approve.gif border=0 align=middle>
However, there is a chance that locomotives will start running the moment you turn on the 6021 plus nothing will be displayed in the 6021 panel.
I had to take off the IB and reinstall the dust collector 6021 <img src=icon_smile_evil.gif border=0 align=middle> to test it but here's how such an incident, like the one rhopke describes, could occur.
Place a locomotive or two on your layout, select it with the 6021 and let it do a couple of loops while you also turn on one or two of it's digital functions! Now, while the 6021 is turned on and the speed knob is is pointed to, let's say 150, the locomotive is running smoothly and it has it's lights on, pull the plug of the 6021!! Just like that, pull the plug and don't change anything on the 6021.
Now, that the 6021 is turned off turn the control knob to the left like shutting down the locomotive. Give it a second and then plug the 6021 back in! <img src=icon_smile_big.gif border=0 align=middle>
Observe what happens! ... "the 99 appears in the led display on the 6021 for a second and then both trains start moving". The locomotive starts to run as you have programmed it, before the 6021 was unplugged! Same speed and all the lights are on <img src=icon_smile_shock.gif border=0 align=middle> Now, the only way to stop the pre-programmed locomotive is to address it...
Well, strange isn't it? Now, isn't it possible that the dealer used the 6021 and the two locomotives on a layout before and unplugged the 6021 the way I described? <img src=icon_smile_wink.gif border=0 align=middle> Rhopke never mentioned that he addressed the locomotive...
Thanos <img src=icon_smile_cool.gif border=0 align=middle>
Thanos
Offline KLB
#12 Posted : 19 February 2003 13:23:41(UTC)
KLB
My two €'s,....<img src=icon_smile.gif border=0 align=middle>
If you have wired according to Märklin's 'old' practiced the layout in a closed loop(i.e wired from both sides) then I have seen this behavior before.On our ETE modules this was the case,both the red(+) and the brown(-) were wired in a closed loop.Since it was under manual control,we had to adjust the the speed of each train so one would not run into the other!<img src=icon_smile_blackeye.gif border=0 align=middle> The loks simply did not respond to commands,so it was shut down time which didn't please either ourselves or the crowd!<img src=icon_smile_blush.gif border=0 align=middle> Once we removed the red from the closed loop,the loks did respond to commands,....no need to worrry about the brown,...that is not the problem.I can not remember but it has something to do with the digital signal and the closed loop that causes this.
Kevin!
Moderator,Märklin Bar&Grill
http://groups.yahoo.com/group/MarklinBandG/
Kevin!
Offline rhopke
#13 Posted : 21 February 2003 23:12:58(UTC)
rhopke
Sorry it took so long to get back, I got called to go to Seattle to clear up a problem up there.
Now for the HO digital problem. I got it fixed thanks to Perez.
After reading the reply from Perez, I decided to reinput the addresses for the engines. I checked them before but never touched them. The engines were set for: br101 = 80 and the cargosprinter =70.
I reset the switches and everything is now working ok.
thanks
This page was generated in 0.956 seconds.
