Offline fvri
#1 Posted : 20 January 2003 16:45:03(UTC)
fvri
I'm trying to control my track by sending simple commands to the control unit Ma6021 by means of a PC(Pentium 2, Win98, COM1 port; RS232port, C program) and the Ma6051 interface. So far I only succeeded in succesfully sending the emergency stop and release command respectively the ascii decimal values 97 and 96. I can see that the leds on my control unit 6021 light up or disappear. But, I'm not able to send any working locomotive commands. Thus, I'm not able to start running a (digital)train. Eg. if I want to start train with address 2 having speed 10. I would simple have to send the ascii values 10 and 2. I'm doing this in C. In basic it is PRINT#1, CHR$(10);CHR$(2);. I didn't try it in BASIC as I'm not longer having a BASIC development environment running on my computer.
I'm also able to turn on/off the functions F1, F2, F3, or F4. But not the auxiliary function (done by the ascii value 16).
What can be the problem?
The program, the interface 6051 or the control unit 6021.
- The program is plain C, it's simple and sends just simple commands to the serial port. I don't think anything is wrong here as I'm able to send the ascii values 96 and 97.
- The control unit 6021 works fully without the PC and 6051.
- The 6051; it's able to send commands from PC to 6021. Of course not all commands are interpreted.
- All trains are running with the control unit 6021.
Can it be that my 6021 is not working well?
Thanks in advance!
Bye,
Frank Vieren
Offline PeFu
#2 Posted : 20 January 2003 16:57:34(UTC)
PeFu
I suggest you test the concept using a commercial software like Railroad & Co, there is a demo you can download on http://www.railroadandco.com. If that would work, you probably have a software bug. The Bankquay site http://home.wxs.nl/~rvdhof/start.html maybe could be a reference for you (under "Digi Train Control" / "Motorola Protocol" / "Software"). Myself, I use it as a reason not to enter into model railroad programming...
<img src=icon_smile_cool.gif border=0 align=middle> Peter
Offline fvri
#3 Posted : 20 January 2003 23:17:45(UTC)
fvri
Hi Peter,
Thanks for the tip. Indeed using a commercial software proves that all hardware is functioning fine! I downloaded the software and it works fine. In fact after running it my own program works also. May be what I did wrong I set the control unit also to the number of the train I wanted to control with my PC. You can only control the train with one unit. Thus when using the PC your control unit should be set on an address that is not used by the program. Thus for example 0.
Thanks again!!!
Bye,
Frank
#4 Posted : 21 January 2003 00:48:00(UTC)
When I wrote my own test programs some years ago, I noticed that the 6051 had some "garbage" bytes buffered that had to be read and "forgotten" to clear the communication channel (RTS/CTS signalling) for further use while establishing the connection...
Offline perz
#5 Posted : 21 January 2003 01:06:57(UTC)
perz
I have also noticed that in rare occations the serial port on my PC just "dies". This has happened with my own programs as well as other programs. When it happens, I have usually been running two different programs after eachother that both use the same serial port. The only cure I have found for this is to reboot the PC. Something similar may have happened to you.
Guest (5)
This page was generated in 0.277 seconds.
