Offline Tahoetom
#1 Posted : 21 April 2002 00:25:43(UTC)
Tahoetom
hi, does anyone have any thoughts or experience with weathering c track? I want to have a very realistic layout and would like to weather my track.
Offline perz
#2 Posted : 11 January 2003 00:26:29(UTC)
perz
This was answered in another thread but I put it here too since this is a more correctly labeled topic.
I have not made any weathering of a complete C track layout since I use M track for the moment. But I have made some tests for the future.
Here is a picture of a weathered C track:
<img src="http://home.swipnet.se/perz/brown_ballast.jpg" border=0>
The track is weathered using water colours. The watercolour can be removed from the upper surface of the rails and from the center studs using a damp cloth or sponge. There is no need for masking and it is therefore a rather quick method. The track is surrounded with Heki 3173 ballast that matches the "rust" colour quite well.
The picture just shows a quick test. I'm convinced that you can make it better after you get some practice. The good thing with water colour is that you don't risk the track. If you are not satisfied with the result you can just "wash up" the tracks and they are like new again.
Offline PeFu
#3 Posted : 13 January 2003 11:13:20(UTC)
PeFu
Hi Perz, all,
Looks great! Have you done something similar with your M tracks? E.g. what ballast are you using?
<img src=icon_smile_cool.gif border=0 align=middle> Peter
Offline perz
#4 Posted : 13 January 2003 20:33:20(UTC)
perz
I have done no weathering of my M tracks. A few tries very long ago didn't turn out well (rust !). Actually I'm not much into weathering at all yet. But I try to learn, the picture is from one of my "training sessions".
My current layout is not permanent, it is modular and stowed away most of the time. The reason is I don't have room for it. I can't occupy the whole living room with it all the time. When I stowe it away I remove the tracks so that I can build small temporary layouts on the floor. My own and some friends' children like to play with it that way. Therefore I haven't put ballast around the tracks like on the picture of the C track. I do use ballast flat on the ground beside the tracks. There I use natural sand (from two different beaches, coarse and fine) mixed with medium ground black pepper. This mixture blends in very well with the M tracks, but since the tracks just lay on top of it the impression could be better.
Offline grattieri
#5 Posted : 22 January 2003 16:15:38(UTC)
grattieri
Hi Perz
I have seen the picture regarding C track weathering :
very good job ! Only one question : how do you paint turnouts
in order to have the correct electrical and mechanical functionality ?
In other terms do you paint the internal part of frogs and
the internal flat part of the inner rails of the turnout?
Regards Marco
br01
br01
Offline perz
#6 Posted : 22 January 2003 17:37:29(UTC)
perz
As I mentioned in a previous post: I do not use C-track normally, this was just a test to see if I could get a good looking result. I haven't tried to do it on turnouts. However, if you use water colour, it is very "forgiving". You can easily remove the paint if it comes somewhere where it should not be.
Offline McLae
#7 Posted : 18 February 2003 01:29:07(UTC)
McLae
I tried this yesterday, and was happy with the results. (have not tried turnouts yet.)
The McLae
Offline Bill
#8 Posted : 30 April 2003 01:49:14(UTC)
Bill
So that is the same paint color on the rails and ballast? Anyone else try to weather C track?
Offline GDamen
#9 Posted : 23 May 2003 17:24:46(UTC)
GDamen
Not yet, but have a look at the following pictures to get an idea of the looks using Busch 7069 C-rail compatible ballast.
Overview:
Detail:
Gino Damen
__________
IB Digital,EP-III, DB&ÖBB
Märklin DB - DC USA UP/BN - IB Digital
Offline perz
#10 Posted : 15 July 2003 01:05:48(UTC)
perz
Thanos has also posted some good pictures on C track weathering. Here is a cross-link to that topic: https://www.marklin-users.net/fo...fault.aspx?g=posts&t=511
Offline jcegido
#11 Posted : 16 October 2003 14:03:51(UTC)
jcegido
I´m wondering about how will acrilics do the work to weather rails instead of more permanent options like Humbrol. Any suggestion or experience to share?
Juan Carlos
Weathering C tracks - howto (Painting & Weathering)
by Steven86 16/11/2005 23:24:20(UTC)
This page was generated in 0.343 seconds.
