Offline Caplin
#1 Posted : 18 February 2008 17:31:19(UTC)
Caplin
quote:Originally posted by hemau (in the Digital Section - topic: mfx locs are not any more recognized by CS):<br />
...Or are we advised to put them first on a programming track? With a MS-operated layout you won't have a program track I suppose. Or should we take all loks off the premises as we enter a new lok?
For those of you having the MS that prefers an exclusive track for "installing" a new locomotive.
A simple way to select between a layout and a programming track when using a MS is for instance to mount a µswitch physically somewhere on the ugly box, electrically between the pcb and the track,
edited:
i.e. remove the red wire from the B terminal of the track,
connect (solder) it to the C (common) of the µswitch,
solder a new red wire from terminal B of the track to the NC (normally closed) contact,
solder a new red wire from an electrically isolated track to the NO (normally open) contact
and solder an extra brown wire to the flat sleeve connector at the [size=2]O terminal of the track.
Viola, you can select to run the layout or the programming track by throwing a switch. As an extra precaution operate only the switch with the MS in Stop mode.
Cover of the Ugly Box removed for access to the red wire:
A µswitch is installed and wired:
The added set of wires for the programming track is "parked" if not used:
The Ugly Box represents the layout and the perpendicular track to it a programming track. The µswitch pointing towards the track (shown) enables the layout/disables the progr. track and the opposite when pointing away:
Benny - Outsider and MFDWPL
Offline mmervine
#2 Posted : 18 February 2008 17:34:48(UTC)
mmervine
Benny:
Great idea and nice work!
r/mark
Offline MHauge
#3 Posted : 18 February 2008 18:34:35(UTC)
MHauge
I have been thinking about making somthing like this, my plan was to let the programming-track be a part of the layout, so i could drive a train onto it, then switch rest of the layout off, program the decoder, switch the layout back on, drive away.
This would require the uglybox to be the programming-track, and a couple of the small red things to disconnect the centre-track.
Then the switch would simply couple the programmingtrack to rest of the layout.
Michael
Märklin C-tracks, Mobile Station, Danish Ep 4
#4 Posted : 23 March 2008 13:47:10(UTC)
Nice instruction, Benny.
Offline svgeorgiad
#5 Posted : 23 March 2008 16:23:09(UTC)
svgeorgiad
I wonder if Benny's clever idea can be applied also in a Control Unit (6021) controlled layout. Thus, can I connect a MS programming track with a separate transformer to my 6021 layout and let the switch change from 6021 layout status to MS-programming status?
Symeon Georgiadis
#6 Posted : 23 March 2008 17:36:31(UTC)
Symeon, yes you can.
You have to take care, a loco parked between the two could cause problems = smoke.
In the digital section is right now a similar topic, Intruder has shown how he
has integrated the programming track in his layout.
https://www.marklin-user...ault.aspx?g=posts&t=9622
The kind of controller doesn't matter, if things are done right.
This page was generated in 0.656 seconds.
