Offline tekin65
#1 Posted : 09 November 2007 17:30:50(UTC)
tekin65
Turkey
Hi to all,
some time ago i have posted my redux of a 3060 (not Santa-Fe but New Haven) as part of my "trainz-that-never-existed" project. here's the link: https://www.marklin-users.net/fo...ault.aspx?g=posts&t=8159
here's the digitizing part of the work:
for the conversion i have used a 4 function decoder for older Marklins (an amazing decoder made by a friend of mine): no need to the change magnet Smile works really good.
i wanted a light set-up as such: the lower light would be the regular and would change to red in reverse. the upper would be separately controlled far-lights and would go off in reverse. so i had to use a relay to give power to far-lights according to direction.
reversing switch removed along with other cables.
the decoder + decoder plate
decoder attached to te plate with shrink tube and mounted in place
soldering done as usual.
building a cowling for led lights
separate rooms for leds so lights wont mix (especially red)
leds in place - all surrounded with aluminum foil for better insulation
relay in place
used precission sockets for easy maintenance
cowling in place
some progress made
after a few hours work is done
body on the chasis
so here's your TCDD DE15000 series loko. TCDD never had F7 locomotives. TCDD diesels are numbered after the pulling power of the engine (1500 hp --> DE15000, if it was 2200 hp it would be called DE22000)
regards,
cem.
Now all eras but no ICE
Offline jorge_vilarrubi
#2 Posted : 09 November 2007 19:27:41(UTC)
jorge_vilarrubi
Nice job, cem, congratulations!
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#3 Posted : 09 November 2007 22:55:27(UTC)
Excellent work, Cem.Smile
Offline hmsfix
#4 Posted : 10 November 2007 00:27:56(UTC)
hmsfix
Great work! Smile
BTW what decoder is it? From the photos I have got the impression that the loco has still an SFCM motor with field coil, isn't it?
The head lights are really cool. Using a red light on a F7 is completely unknown in the US. But on this side of the Atlantic ocean this is a quite normal feature, and it's natural to assume that a TCDD F7 had such specialties.
Hans Martin
#5 Posted : 10 November 2007 00:55:11(UTC)
Cool job, Cem - congratulations [:p]
Offline tekin65
#6 Posted : 15 November 2007 11:45:58(UTC)
tekin65
Turkey
Hi to all,
sorry for late reply - busy time of year :)
thank you all for your praises.
[size=1" face="Verdana" id="quote]quote:Originally posted by hmsfix
<br />Great work! Smile
Hans Martin
Hans hi,
you're right; the loko still have the SFCM motor and field magnet. the decoder is developed by a friend of mine to be used on older Marklin models - requires no modifications at all. it works just fine with one minor hick-up (happens when powering the system).
the series "trainz that never existed" stands for its name: TCDD never had F7 locomotives so headlight arrangement is "made-up" by your humble modeller wink but just like you say TCDD would most probably prefer such light arrangement.
all the best,
cem.
Offline Trainingtime
#7 Posted : 15 November 2007 16:34:23(UTC)
Trainingtime
Wonderful work.
Offline Katchina
#8 Posted : 29 January 2008 11:34:02(UTC)
Katchina
Hi Cem,
As I'm in the process of completely restoring old F7s in very poor conditions that I picked up on eBay, I find your 2 posts very inspiring. Controling the lower and upper lights with different functions seems obvious now, but I hadn't thought of it ;-)
This page was generated in 0.485 seconds.
