Offline GSRR
#1 Posted : 05 October 2010 17:40:59(UTC)
GSRR
I am interested in using the CS2 both as a standalone unit and with PC control software. Some of the reading I have done points to two possible items of interest.
1. Unlike the ECoS and CS1, the CS2 will not/cannot sync it's database with PC software?
2. The feedback on the CS2 is slow or poor due to it's feedback polling?
3. What if any role does the GFP Track Format Processor play in Q.1 and Q.2?
Would appreciate if anyone could shed some light on this, and if there is a possible fix in the works?
(I am aware of the LDT HSI-88 serial/USB)
r/Thomas
edit: To add some clarity to my questions. I have searched the internet using English terms, which has brought minimal result. As I am not conversant in either German or Dutch I cannot avail myself of the other language forums or searches.
Edited by user 06 October 2010 07:07:16(UTC)  | Reason: Not specified
Offline Fredrik
#2 Posted : 05 October 2010 19:54:26(UTC)
Fredrik
Hi there BigGrin
1 - WRONG! It is possible...!
2 - True.
3 - It produces the digital signal on the track(s).
There is also (in addition to the HSI-88) a similar CAN-module "PC-Snitt" (using the CAN-bus instead) on which, unlike the S88-bus, the modules must not be inserted in a serial row. And it can contain up to 99 detector modules (TrackReporters each with 16 inputs). This "PC-Snitt"-interface has a USB-connection for the computer.
The TrackReporters can also be inserted directly in the CAN-bus of the CS2 - and they will automatically send any state-changes over the CAN-bus which (in contradiction to the S88-bus) is automatically sent to a connected computer (works on 1.3.0(1)), where it can be proccessed if the software has it implemented. It does work, but not recommended from the manufacturer, and if used: OPTO-insulation of the inputs must be used!!!
Fredrik.
WWW: MJ-fjärren
Offline dntower85
#3 Posted : 05 October 2010 23:57:18(UTC)
dntower85
2 - True.
2A feedback on the CS2 - How does it compare to the 6021 with the 6051 interface... Faster or Slower?
DT
Offline Fredrik
#4 Posted : 06 October 2010 00:20:09(UTC)
Fredrik
I haven't done any actual timing but:
In both cases (6051 interface and 60213/4) one (the computer) has to ask for the information. This is what I consider "slow" - "fast" would be the central to send the data automatically (and preferrably only new/changed data like CS1/ECoS).
But physically I would expect the 60213/4 (ethernet-) connection to be faster than the 2400 bps connection of the 6051 interface. But I do not know.
Fredrik.
WWW: MJ-fjärren
Offline GSRR
#5 Posted : 06 October 2010 07:16:08(UTC)
GSRR
Fredrik wrote:
Hi there BigGrin
2 - True.
Fredrik,
Q.1 Could you please provide a specific example of PC software that will sync the database with the CS2. Brand name?
Q.2 I am aware of the workaround for the slow feedback polling using an interface or Schnittstelle. What I am looking for is the specific reason for this slow polling. Is it the CAN-bus, the CS2 software, etc? And is there any intent to "fix" this?
Offline GSRR
#6 Posted : 06 October 2010 07:25:03(UTC)
GSRR
Just by reading the description posted by Steamer01 / Riekus in the Digital » CS2 60214 Known issues thread post #26 and #36 it seems to me that this is a feedback polling issue perhaps, or not?
r/Thomas
Offline Fredrik
#7 Posted : 06 October 2010 11:25:45(UTC)
Fredrik
Hi again,
Q1: My software CAMR (previously RailNet) does this (see link in signature). It can import both engine- and accessory-data from the CS2. Due to an upcoming relocation it is currently not available for download for the public (as I right now am unable to work on it as my layout has been "dismantled" and will be rebuilt - there will be a story about this on my web-site when started...). CAMR is written for CS2, with adaptions for other systems... BigGrin
Q2: It is the CS2 software that do not pushhe feedback information autmatically to the computer. ThumbDown It has nothing to do with the CAN-bus.
Fredrik.
WWW: MJ-fjärren
Offline GSRR
#8 Posted : 06 October 2010 16:20:03(UTC)
GSRR
Fredrik wrote:
Hi again,
Fredrik,
Thanks for the info.
Q.1 To sync with the CS2 database for the Loks and accessories does CAMR go through the Ethernet connection, or do you have to make a USB backup from the CS2 and then import to the PC?
Q.2 So the slowness of S88 feedback is due to the current state of the CS2 software protocol which does not yet support an event driven system regarding the S88 feedback or track occupancy?
Is there any indication on the forums that Marklin recognizes this and a fix is coming?
r/Thomas
Offline Fredrik
#9 Posted : 06 October 2010 22:05:22(UTC)
Fredrik
Q1: It uses the Ethernet connection.
Q2: Yes!
If Märklin will release a event-driven version I don't know - but I hope they will.
Fredrik.
WWW: MJ-fjärren
Offline fvri
#10 Posted : 07 October 2010 17:12:43(UTC)
fvri
Indeed remarkable anno 2010 M is still using a polling instead of an event driving model for track occupancy. Luckily I bought an ECOS 1. If that one breaks down I can rely on my M6021/6051 robust duo :).
Frank
Offline GSRR
#11 Posted : 07 October 2010 17:17:48(UTC)
GSRR
Q2: Yes!
Thanks Fredrik.
r/Thomas
Offline GSRR
#12 Posted : 07 October 2010 17:19:41(UTC)
GSRR
Frank
Hello Frank.
Can you give some background about the difference between "event driven" and "polling"?
r/Thomas
Offline fvri
#13 Posted : 07 October 2010 18:05:44(UTC)
fvri
Hi Thomas,
By polling is meant: the system needs to readout frequently the state of the S88. With an event driven system each time a state changes in the S88 an event is published by the control system(CS1 or ECoS1/2).
A big disadvantage of polling is that states can be missed, thus if the time for polling is bigger than the time between 2 states have changed you will miss one. When occupancy detection is based on contact rails this is usually not a problem. Thus for a control software progam it is more reliable to have an event driven system, every state change can be trapped with ease.
I hope this make it more clear to you.
Frank
Offline GSRR
#14 Posted : 07 October 2010 18:23:53(UTC)
GSRR
fvri wrote:
Hi Thomas,
Frank
So with an event driven system a change in the s88 "an event is published by the CS1 or ECoS"
Would this be correct? With an event driven system the s88 sends the feedback to the CS1 without being interrogated or polled, with a polling system the trigger can only be recognized and acted upon with the next interrogation or polling cycle from the CS2?
r/Thomas
Offline Fredrik
#15 Posted : 07 October 2010 18:34:04(UTC)
Fredrik
No - not quite!
With the event-driven system of CS1/ECoS the CS1/ECoS sends the feedback to the computer once a change is detected. The CS1/ECoS "constantly" polls the S88-bus (no idea at what "rate").
This is why I myself use the CAN-system (with it's own interface) - it is truly event-driven: Once the decoder (TrackReporter) detects a change on one of its inputs - the data is immidiately sent on the CAN-bus. Intercepted by the interface it's is directly sent to a connected computer! Much better!!! BigGrin
Added: The S88 never sends anything - it can only be polled!
Fredrik.
WWW: MJ-fjärren
Offline dntower85
#16 Posted : 07 October 2010 19:13:21(UTC)
dntower85
Fredrik wrote:
No - not quite!
So even the Ecos and CS1 are polling the s88? and they are just sending the event as soon as they see a change occurring. This would be ok if the system is polling the s88's so fast that it doesn't miss anything and if the s88 is on a separate buss and it can continually poll so it doesn't poll then send commands before it polls again.
DT
Offline Fredrik
#17 Posted : 07 October 2010 19:16:30(UTC)
Fredrik
Correct! ThumpUp
That is exactly how it works. Cool
Fredrik.
WWW: MJ-fjärren
Offline fvri
#18 Posted : 07 October 2010 19:22:39(UTC)
fvri
Frederik, indeed you are correct, but I didn't stated that the S88 has intelligence to implement an event driven system it is located in the controller(CS1,....).
Frank
Offline Fredrik
#19 Posted : 07 October 2010 20:25:02(UTC)
Fredrik
Hi Frank,
I know you know hos it works! BigGrin
My reply was not written as a response to yours - only as a reply to the posting above it.
Fredrik.
WWW: MJ-fjärren
Offline fvri
#20 Posted : 07 October 2010 23:21:13(UTC)
fvri
Hi Fredrik,
No hard feelings :).
Sorry I'm always writing your name wrong, probably because in Belgium it is usally written like this : Frederik.
Frank
#21 Posted : 08 October 2010 02:48:45(UTC)
Thomas, the CS2 can read the loco and solenoid databases on a CS1, so I should imagine it can synch with PC based software.
Offline GSRR
#22 Posted : 11 October 2010 19:30:44(UTC)
GSRR
Frank
Frank and Fredrik,
I understand the function of the s88, I got turned around a bit. Thank you both for providing some input to my questions.
r/Thomas
http://users.telenet.be/loccommander/
http://www.camr.se/
Offline Danlake
#23 Posted : 18 September 2012 08:25:55(UTC)
Danlake
Originally Posted by: GSRR Go to Quoted Post
Fredrik wrote:
Hi again,
r/Thomas
Has the issue in Q2 above been solved by Marklin in software upgrades or is it still using a polling response rather than event driven for the S88 modules?
Reason I ask is if I should use the LDT-HI-USB option rather than using the CS2 to report state to my PC controlled layout? I will only have about 5 S88 modules mainly hooked up to contact tracks.
Thanks in advance!
Brgds - Lasse
Offline Fredrik
#24 Posted : 18 September 2012 17:44:18(UTC)
Fredrik
Fredrik wrote:
Hi again,
r/Thomas
Thanks in advance!
Brgds - Lasse
Yes - the CS2 is now automatically sending out changes to listening devices on the ethernet-connection. Although still internally polling the S88-bus. However the software must no more ask for changes.
Fredrik.
WWW: MJ-fjärren
thanks 1 user liked this useful post by Fredrik
Offline betania
#25 Posted : 16 April 2013 21:00:26(UTC)
betania
Hello!
It seems that Märklin vers. 3.0.1 (1) works with S88 and Train Controller vers. 8.0 B1
KOS
Central Station 60214, 60215, Booster 60174, TrainController 8.0 Guld, m / rail slightly off c-rails, Marklin from the 50's and 60's. Tried to create Marklin-story combined with Swedish locomotives and wagons from 1900 to the present.
thanks 1 user liked this useful post by betania
This page was generated in 0.896 seconds.
