Offline sirgawain123
#1 Posted : 28 July 2004 22:49:57(UTC)
sirgawain123
After 25 years frozen,and now being a father of a 4 year old kid, my marklinism reappeared a couple of months ago as the kid convinced (was he, or was i?)me to buy a delta start set. So , in this months the illness is getting bigger, and i have converted to delta/digital the lokos i kept from when i was young, and am building a mixed C/M layout.
The greatest advantage i find in digital is being able to drive several lokos in the same track. But having only one 4f,its either me or the kid, but not both of us simultaneously, controlling one loko each of us.In order to do that, the marklin route would be buying a delta pilot.but delta pilot a/is hard to find at dealers.
b/is expensive for what it does c/is limited to controll lokos only at a given address (80?).
Now to the question:
AS its easy to find cheap 4fs at ebay:is ther a way to interconnect two 4fs (even by connecting their insides, not external connections)so they run simultaneously on same track, given the same delta loko adress is not selected at same time by both 4fs?
That would provide much more playability for me and the kid
Best regards from Spain
#2 Posted : 29 July 2004 00:14:50(UTC)
Hi, and welcome to the forum.
To interconnect 2 66045 units is not "doable"...
And certainly not connecting them to the same electrical track circuit...
You can make your own "Delta pilot" easily, but the address 80 limitation is of course still there.
What would be perfect for you, would be an Intellibox (2 throttles), but it is a bit on the expensive side...
I am sure our member Lars will tell us about Daisy as an alternative. In fact, I myself would like to know more about the Uhlenbrock Daisy as alternative to Delta...
#3 Posted : 29 July 2004 01:59:23(UTC)
sirgawain123
thanks for welcome and answer:
by "not doable", you mean its not doable, or what you mean is "not doable without opening/tinkering/solding...inside the 66045 ´s?
how can i make a delta pilot?url? Lars, please.........
i NEED a 2nd CHEAP throtle now (better if not limited to address 80), but happy keeping in Delta until all the hype regarding M systems settles down and the real (if any) advantages get clear from the marketing.I see the future with 2 mobile stations....(so i dont want to dump big cash on this stop-gap 2nd throttle)!!
#4 Posted : 29 July 2004 02:59:14(UTC)
Offline jorge_vilarrubi
#5 Posted : 29 July 2004 07:10:56(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:I see the future with 2 mobile stations
Hmmmmm.... two Mobile Stations in the same layout?
It would be the first time two digital systems can work together without damaging each other... I wouldn't bet...
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#6 Posted : 29 July 2004 11:35:38(UTC)
Welcome, Sirgawain123 Smile
Offline kgsjoqvist
#7 Posted : 29 July 2004 11:53:34(UTC)
kgsjoqvist
[size=1" face="Verdana" id="quote]quote:It would be the first time two digital systems can work together without damaging each other... I wouldn't bet...
Shouldn't be a problem, because one of the Mobile Stations is the master, and the other just sends its instructions to it. The only problem would be if both try to run the same loco, but I suppose that the loco address is "locked" to prevent that.
You can get the same functionality with a Daisy combined with Fred, if you prefer Uhlenbrock equipment. I doubt that it would be cheaper, however...
A much cheaper solution would be to divide the layout in two halves, connect a Delta 4f to each part and run them separately. When the loco leaves the area, you have to change to the other trafo (just in the good old analogue days). I would recommend a transition track fed with "pure AC" between the digital circuits, to avoid confusing the signals. With this setup you can be two simultaneous users, as long as you stay on your own side of the layout. And you can have 4 locos on the layout - having 2 of them under immediate control and 2 standing still or rolling in constant speed.
#8 Posted : 29 July 2004 15:23:23(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:Shouldn't be a problem, because one of the Mobile Stations is the master, and the other just sends its instructions to it.
Afaik, one Mobile Station could be slave to a Central, not sure if it can be a slave to another Mobile Station. Anybody can answer?
[size=1" face="Verdana" id="quote]quote:You can get the same functionality with a Daisy combined with Fred, if you prefer Uhlenbrock equipment. I doubt that it would be cheaper, however...
Motorola and DCC, 256 turnouts, 9999 Loks, but no feedback from still-to-be-seen Mfx Decoders.
[size=1" face="Verdana" id="quote]quote:A much cheaper solution would be to divide the layout in two halves, connect a Delta 4f to each part and run them separately. When the loco leaves the area, you have to change to the other trafo (just in the good old analogue days).
Anyway you are limited to 5 addresses that are the same in both systems
[size=1" face="Verdana" id="quote]quote:I would recommend a transition track fed with "pure AC" between the digital circuits, to avoid confusing the signals. With this setup you can be two simultaneous users, as long as you stay on your own side of the layout. And you can have 4 locos on the layout - having 2 of them under immediate control and 2 standing still or rolling in constant speed.
Whenever AC current gets into the Digital Central, all of them, the output stage of the unit gets fried. At least one, sometimes both Darlington transistors get damaged. I don't know what method could be used for the isolation segment. In old times, when Märklin= was launched, they recommended a car light bulb in series with the DC fed track section used to resolve the DC-loop problem. The risk of a failed experiment is a couple BDX33/BDX34 transistors put into orbit...
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#9 Posted : 29 July 2004 15:45:04(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by jorge_vilarrubi
<br />Afaik, one Mobile Station could be slave to a Central, not sure if it can be a slave to another Mobile Station. Anybody can answer?
Hi Jorge Smile: I asked the very same question some days ago in another topic and Dikken knew the solution - when running two Mobile Stations that on Port I of Ugly Box is always the Master.
Best Regards
#10 Posted : 29 July 2004 23:47:16(UTC)
sirgawain123
in fact, my statement that i could see two mobile stations in the future was led by Dikken post. But this future has not arrived yet, and i want a stop-gap device.
Two electrically isolated circuits is not what i want. i want to drive a loko through the whole layout while my kid drive his own one. The QnD Delta pilot would be a right solution if it wasnt for the adress only nr.80 limitation.
pitty the grey connection on 4f is an analog input only.
thanks n regards
today sunny although windy.
#11 Posted : 30 July 2004 00:55:02(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote: when running two Mobile Stations that on Port I of Ugly Box is always the Master.
This could resolve the addressing problem, power consumption remains pending. The power stage from the slave unit will not feed the track, since the Ugly Box is the only connection to the track. Boosters are only a project so far.
Anyway, you can control 2 Loks simultaneously with 2 Mobiles.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#12 Posted : 30 July 2004 01:57:08(UTC)
sirgawain123
<br /> Boosters are only a project so far.
One more reason to wait longer.
[size=1" face="Verdana" id="quote]quote:Originally posted by sirgawain123
<br />I see the future with 2 mobile stations....(so i dont want to dump big cash on this stop-gap 2nd throttle)!!
Future not yet here, then.[}:)]
Still cant understand how a 4f can talk to a PC, but not to another 4f [:(]
best regards
Offline perz
#13 Posted : 30 July 2004 02:13:26(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Still cant understand how a 4f can talk to a PC, but not to another 4f
It isn't the 4f that can talk to the PC, it's the PC that can talk to the 4f. There is "direct drive" SW that can drive a booster directly from the PC. Since the 4f can be used as a booster, you can drive your layout from the PC through the 4f.
#14 Posted : 30 July 2004 04:14:36(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote: Since the 4f can be used as a booster,
Hi Perz, a friend of mine wants to use a D4f as a booster and I don't have the knowhow. Could you please tell me how to do? Thank you!
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#15 Posted : 30 July 2004 18:57:50(UTC)
<br />Anyway, you can control 2 Loks simultaneously with 2 Mobiles.
Fine that's all I need on a small digital layout. Well, although there's still no delivery of the real mccoy we become wiser every day ... Smile
Offline perz
#16 Posted : 31 July 2004 01:02:58(UTC)
perz
This describes how to use the 6604 as a booster. It should be the same with the 4f.
http://www.marklin.nl/digital/images/schema-6604.gif
Another interesting link I found shows that it is possible to patch an old 6604 to get the equivalent function of a 4f:
http://www.marklin.com/tech/digital1/images/6604+.jpeg
Offline laalves
#17 Posted : 31 July 2004 01:28:27(UTC)
laalves
Yes, I can, just read the online manual for the Mobile Station. An adapter will be released to connect a Mobile Station to the Central Station plug in the ugly box. This will become the Master Mobile, the other will be the slave. Current limited to the Master's output rating. Further, AFAI could understand, even with two Mobiles, you're still limited to 10 addresses.
Luis
#18 Posted : 31 July 2004 04:04:22(UTC)
sirgawain123
is it possible to download the online manual for the Mobile Station?where?
many thanks
Offline perz
#19 Posted : 31 July 2004 17:05:30(UTC)
perz
#20 Posted : 31 July 2004 21:59:10(UTC)
jorge_vilarrubi
[size=1" face="Verdana" id="quote]quote:Originally posted by perz
<br />This describes how to use the 6604 as a booster. It should be the same with the 4f.
Thanks for your answer. I've installed several Delta 6604 as boosters. 6604 works as an amplifier, taking the input from the red wire. The problem I see with 66045 is that the red wire is missing, thus I don't know where to input the digital signal.
Jorge Vilarrubí
Buenos Aires
ARGENTINA
#21 Posted : 31 July 2004 22:59:39(UTC)
sirgawain123
I have just spent some time "googling", and only info found related to delta as booster, is about "old" 6604, NOT 66045 new delta 4f. So,m if any1 Knows a URL, please...share
Offline perz
#22 Posted : 31 July 2004 23:59:39(UTC)
perz
[size=1" face="Verdana" id="quote]quote:The problem I see with 66045 is that the red wire is missing, thus I don't know where to input the digital signal.
There should be a blue connector marked "D" somewhere that replaces the red wire. But I do not know exactly where, since I have never seen a 66045 in real life.
#23 Posted : 02 August 2004 11:10:38(UTC)
<br />The mobile station manual online:
https://www.marklin-users.net/fo...ault.aspx?g=posts&t=1559
Sorry that link doesn't work, sending you in circles all the time ... [xx(]
Edit: Now it works just fine - many thanks, Per Smile
Offline perz
#24 Posted : 02 August 2004 15:34:02(UTC)
perz
[url]Sorry that link doesn't work, sending you in circles all the time ... [/url]
The link sends you to another forum topic, that links to the manual. But anyway, here is the direct link:
http://www.maerklin.de/systems/bda-60652.pdf
Offline Lars Westerlind
#25 Posted : 02 August 2004 15:41:56(UTC)
Lars Westerlind
Correct. The 66045 should be used exactly as an 6605, using the blue connector for digital input. Meaning, the loco selector should be set in the rightmost "stop" position, and the two grey connector should be connected.
Uhlenbrock Daisy is surely an alternative which I like best in that situation, but it's not that cheap. With two Daisy handles, and one Power2 to connect the track (=one Daisy set, and one extra Daisy) you have a full digital system with two user friendly controls (not comparable with the Delta controls), allowing for f1-f4, DCC, turnout and signal control etc. It allow for 2 A which is skightly more than the expensive Mobile. And the system is rather cheap to extend with it's brilliant LocoNet bus. However, it's about EUR 300, probably more with that setup, and it's not known wether it will be able to control all functions of the new mfx decoders from Märklin.
Lars
#26 Posted : 02 August 2004 20:16:36(UTC)
sirgawain123
keeping in mind that regardless of the minDIN connection to the ugly box (connection track), at the end of the day, what we get from the ugly box is still the traditional red and brown to the track:
Shall we assume that 66045 (Delta 4f) is still usable as booster for Mobile station?confused
(my knowledge of both electronics & model railroad is sooo short......!!!)[}:)]
About having two daisyS, not time for big investment until mfx two way comms compatibility is achieved.
What i (and others) need is a CHEAP (so cheap it doesnt matter if it is not future proof) two throttle, no function, no isolated tracks, solution until the path to the future is clear. Two 66045 4fs would be an answer. pitty it is not. [:(]
¿can the 66045 be opened & manipulated to allow Delta pilot adress to be selectable out of adress 80 to any other of the four delta adresses? finding a feasible way to do that may be a good quest for the summer for those who really know about Marklin electronics.[:p]
Offline nico van zon
#27 Posted : 02 August 2004 20:38:56(UTC)
nico van zon
<br />.....Shall we assume that 66045 (Delta 4f) is still usable as booster for Mobile station?confused
I don't think so! Because with the new System, the booster is inside the Mobile station. And this booster is probably of a different type. (H-bridge instead of +/- commutation)
Offline perz
#28 Posted : 02 August 2004 22:20:39(UTC)
perz
[size=1" face="Verdana" id="quote]quote:I don't think so! Because with the new System, the booster is inside the Mobile station. And this booster is probably of a different type. (H-bridge instead of +/- commutation)
I don't agree. The booster is inside the Mobile station just as much as the booster is inside the 6021 or the IB. The Mobile station probably uses an H-bridge, but that doesn't stop you from using a 66045 as external booster. It only means you need to use different transformers for the Mobile station and the 66045, and not connect the ground wires of the two transformers together. But you would probably want a separate transformer for your extra booster anyway, wouldn't you ?
#29 Posted : 02 August 2004 22:57:15(UTC)
nico van zon
Perz, what I meant to say: if the MobStat uses a H-bridge, where other boosters use direct ground connection, the two won't work together. You would need a special interface to transfer the control signal to the fixed grounded booster in order to prevent a short cicuit. (if ever there is a possibility to get a control signal from the MobStat)
The big problem in understanding the new system is that Märklin provides lots of text about the system, but next to no information on how it sticks together technically.
Offline perz
#30 Posted : 03 August 2004 01:26:43(UTC)
perz
[size=1" face="Verdana" id="quote]quote:Perz, what I meant to say: if the MobStat uses a H-bridge, where other boosters use direct ground connection, the two won't work together. You would need a special interface to transfer the control signal to the fixed grounded booster in order to prevent a short cicuit. (if ever there is a possibility to get a control signal from the MobStat)
There are two cases:
1. Using 66045 as a booster. This is what we are mainly discussing in this topic. For that specific case, your comment about H-bridge or not is definitely invalid. There is no problem. Look at the link I provided in an earlier topic! The control input to the 6604(5) is taken from the "red" track power, and the ground to the 6604(5) is taken from the "brown" track. The signal is there on the track, and it will look the same, whether the Mobile Station has an H-bridge or not doesn't matter.
The drawback with using the 6604(5) as a booster is that there is a delay through it, which means you can get problems when locos cross over between the "normal" and the boostered section. This problem is however exactly the same whether you use a Mobile Station or a 6021. That's why it is usually recommended to use the 6604(5) as an accessory booster and not as a track booster.
Another drawback (or maybe feature ?) with using 6604(5) as a booster is that an over-current situation on the booster will not feed back a stop signal to the system, as will be the case with a real booster.
2. Using a real booster, such as 6017. In this case you use the 5-wire booster interface. The 6017 has a 0 to +5 V signal referenced to track ground. We do not know anything about the booster interface of the Mobile Station yet. We do not even know if there are any plain booster signals in its interface. My guess is that the master and slave Mobile station use some other more intelligent protocol to communicate. Maybe the future "boosters" will do the same and maybe they will not just be simple amplifiers as they are today.
So probably the 6017 can not be used as a booster to the Mobile station without building some kind of interface. If you accept the same limitations as with the 6604(5) such an interface is very simple: it consists of two resistors to take down the voltage from 20 to 5 V, and a diode to short out the negative pulses so that only the positive pulses remain.
Offline kimmo
#31 Posted : 07 August 2004 11:42:56(UTC)
kimmo
<br />Another drawback (or maybe feature ?) with using 6604(5) as a booster is that an over-current situation on the booster will not feed back a stop signal to the system, as will be the case with a real booster.
I am using delta as an accessory booster. I once encountered an over-current situation, when I had a faulty accessory decoder in the circuit. Due to this, the delta unit kept tripping its internal over-current protection, giving a constant "clicking" sound from inside. Nothing got damaged, though, so the inside over-current protection was doing its job OK, even when the situation was permanently on. But it is true that it doesn't shut off the main output from the CU.
Kimmo
This page was generated in 0.997 seconds.
