Offline James
#1 Posted : 06 June 2009 22:12:59(UTC)
James
Hello all:Smile
I have recently downloaded the latest upgrade for the CS2 and so far it looks great. However, I was wondering if anyone could help me with a small problem that I have been having(even before the upgrade).
Although the database of .png files is extensive, as we all know, it doesn't cover all of the locomotives that Marklin ever produced.[V]
Currently I am running a Rheihe K (#37055) in green livery, but the closest picture in the database only shows a BR 59 in the standard German black and red scheme. From what I've been told... I can upload a picture of my locomotive in a .png format and add it to the CS2 database. On several occassions I have tried to do this but so far... I have not been able to accomplish this.[:(]
First, I go to the Marklin site, copy the jpeg picture of the Locomotive then I compress it down to 4K and save it as a .png file using Photo shop 5. Then I save this file to a Memory Stick which I plug into the back of the CS2. I go to the Set-up screen of the CS and click on USB stick and then I click on the "update program section". The CS2 (apparently) does it's thing, but when I go to view the locomotive database, there is nothing.[:(!]
Obviously I'm doing something wrong, but I don't know what. Could anyone tell me where I'm going wrongconfusedconfusedconfused
____________________________________________________________________________________________________________________________________________
James Bannerman
Give me steam, and how you feel can make it real, real as anything you've seen. (Peter Gabriel)
Offline jonas_sthlm
#2 Posted : 06 June 2009 23:53:32(UTC)
jonas_sthlm
http://www.modelltag.se/viewtopic.php?f=9&t=15
end of this page wink
did you save the picture file inside a map called icons directly on the USB stick? then select update from USB
Offline James
#3 Posted : 07 June 2009 01:09:29(UTC)
James
I'm not sure what you mean when you say iconsconfused
James Bannerman
Offline jonas_sthlm
#4 Posted : 07 June 2009 01:30:21(UTC)
jonas_sthlm
[size=1" face="Verdana" id="quote]quote:Originally posted by James
<br />I'm not sure what you mean when you say iconsconfused
Create a folder with name icons and put the picture inside
Save the folder on your USB memory stick
Select inside CS2 upgrade from USB
biggrin
Offline James
#5 Posted : 07 June 2009 01:58:16(UTC)
James
Thanks Jonas... I'll give it a try.
James Bannerman
Offline James
#6 Posted : 07 June 2009 02:04:01(UTC)
James
Jonas:
Your information was excellent... thanks for the help. I tried it and it worked like a charm. Thank-you very much
Sincerely
James Bannerman
#7 Posted : 31 July 2009 15:44:01(UTC)
I have put new loco icons in the CS2 (The last update was sucessful) and there is still no sign on screen.[xx(]
Offline Bob R
#8 Posted : 02 August 2009 07:46:36(UTC)
Bob R
Maybe we can all share these files? I have a program that can convert jpg to png. I will list the ones I have converted later. I have installed them into the CS2.
Offline villefra
#9 Posted : 02 August 2009 13:39:17(UTC)
villefra
Hi All,
there are several resources in the internet for .png files. I have created a system where it is possible to upload .png files for sharing purposes: http://rasmus.villefrance.org/maerklindigital.htm
I have uploaded my own icons already.
Rsamus.
Offline SierraDelta
#10 Posted : 03 August 2009 13:26:54(UTC)
SierraDelta
This thread on Stummi's Forum has truckloads of CS2 .png files, sorted by model number:
http://stummi.foren-city...bilder-fuer-die-cs2.html
Søren
___________
CS2 60213 version 1.6.4(3)/GFP 1.40
2011 planned purchases - | nothing |
#11 Posted : 04 August 2009 14:21:02(UTC)
Locos still not on screen after 'The update was sucessful' message on CS2 screen.
That's why I want the 39891, 39572 and 39618.
Can you help?
This page was generated in 0.501 seconds.
