Offline Brakepad
#1 Posted : 07 November 2009 23:52:16(UTC)
Brakepad
France, Metropolitan
Recently I received a BR141 in nice condition but with rusty handrails. This is, as far as I know, a quite common issue with older models.
Have you replaced these "rusty" handrails? How do you source them?
Thanks.
Offline TOC
#2 Posted : 08 November 2009 01:15:37(UTC)
TOC
Music wire
Old Bass strings.
I have removed handrails from stanchions, sanded them to remove rust, and clear sprayed them on other makes to great success.
Offline seatrains
#3 Posted : 08 November 2009 04:34:42(UTC)
seatrains
Brakepad, I have cleaned surface rust off with diluted rubbing compound and my dremelwith the polishing pads. TOC, the clear sealer is a good idea. Thanks for the tip...
Thom
Offline tekin65
#4 Posted : 08 November 2009 07:58:58(UTC)
tekin65
Turkey
Like TOC said but I use guitar strings (instead of bass); plain ones (G, D or E). Go for thickest ones.
Cem.
Now all eras but no ICE
Offline Brakepad
#5 Posted : 10 November 2009 08:00:43(UTC)
Brakepad
Thanks guys!
Offline TroyYang
#6 Posted : 10 November 2009 08:27:03(UTC)
TroyYang
Metal paper clips.
Troy
San Francisco, USA
Offline Brakepad
#7 Posted : 21 November 2009 11:12:28(UTC)
Brakepad
Troy', I'll try that out!
Thanks!
#8 Posted : 21 November 2009 12:08:45(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by TroyYang
<br />Metal paper clips.
Troy,
Very good idea !
thanks,
regards.,
Offline Brakepad
#9 Posted : 25 November 2009 21:46:06(UTC)
Brakepad
<br />Hi,
Cem.
Well, I tried paper clips but wire was too wide and I could not fit it into the handrail holes in the loco body.
But yesterday I went to a music store. I followed Cem's advice and the result is just perfect:
Before:
The solution:
And after:
I spent 1,10€. I have handrails for a LOT of locos.
Many thanks! Good advice!
#10 Posted : 25 November 2009 22:44:50(UTC)
I was just about to endorse Cem's advice, which I believe I introduced in the forum many years ago...
And it seems you have also found the glory of a good guitar string... Looks very good indeed... Cool
I have even repaired pantographs with a G-string (D'Addario 0.15) and it looks just great.
Guitar strings are very good mrr model material, you can use the thicker wound ones in the set to model fire hoses and such too...
And as a special treat - A young Webmaster playing his Gibson Les Paul DeLuxe in the late 70:s.... biggrin
#11 Posted : 25 November 2009 23:22:07(UTC)
Now I've seen everything biggrin biggrin biggrin biggrin
Offline jonquinn
#12 Posted : 25 November 2009 23:37:16(UTC)
jonquinn
if you have money to burn, you might consider a tool called the "grab handler" by Mission Models. I know I didn't pay much for mine (on ebay some time ago), but now they sell for about $80 US.
they're made with mostly armor modelers in mind, but would work equally well for trains.
#13 Posted : 26 November 2009 00:02:10(UTC)
The G-strings I know of cannot be used for pantograph repair biggrin[:I]
Offline Brakepad
#14 Posted : 27 December 2009 00:00:25(UTC)
Brakepad
Another picture from my '59-'60(I think) 3005 BR23, with replaced handrails (the guitar string is OK also for curved handrails):
#15 Posted : 27 December 2009 00:31:10(UTC)
Looks like new, regarding the handrails... Guitar strings "is the sh-t"... biggrin
#16 Posted : 27 December 2009 00:50:38(UTC)
<br />And as a special treat - A young Webmaster playing his Gibson Les Paul DeLuxe in the late 70:s.... biggrin
[:0][:0][:0][:0][:0][:0][:0][:0]....and he has a microphone for (dare I say it) singing!
You need a Brian May Red Special.......
http://www.brianmayguitars.co.uk
#17 Posted : 27 December 2009 01:15:10(UTC)
Off-topic comment:
No worries, David... Only "backup vocals", except for "Bad Moon Rising" which was slaughtered vocally by myself back then in the band...
#18 Posted : 27 December 2009 01:22:19(UTC)
<br />.... "Bad Moon Rising" which was slaughtered vocally by myself back then in the band...
biggrinbiggrinbiggrinbiggrinbiggrinbiggrin
"There's a bathroom on the right....."
Edited by user 30 May 2020 05:15:34(UTC)  | Reason: Not specified
This page was generated in 0.711 seconds.
