arcanjo Offline
#1 Posted : 10 June 2012 15:14:55(UTC)
arcanjo
Hi all!
I have a little problem with my turntable from Marklin (retrofitted with digital module). It is controlled through my CS2, but it has a strange behaviour, when rotating counter-clockwise the speed is greater than rotating clockwise, and I don't know why it does thatConfused . I have tried to programing the speed to no effect, in fact as of now it is programed at full speed. Anyone has any idea?
Another problem, when rotating clockwise the platform, do not get completely aligned with some of the tracks. It derails some of my steamers when passing from the platform to the track. Any suggestions to what to do?
Regards!
Artologic Offline
#2 Posted : 12 June 2012 15:48:55(UTC)
Artologic
Hello Arcanjo,
Maybe this is a stupid answer, but isn t it possible that the motor just simple runs slower in one direction to the other? I have loco s which have the same "issue". Does i run smooth?
To align it, you should be able to use the release lever to the opposite side of the house on the platform and "push" it gently in the right position, it should be aligned by then.
Hope it s worth anything to you
Kristof
kbvrod Offline
#3 Posted : 12 June 2012 16:29:36(UTC)
kbvrod
Hi all!
>I have a little problem with my turntable from Marklin (retrofitted with digital module). It is controlled through my CS2, but it has a strange behaviour, when rotating counter-clockwise the speed is greater than rotating clockwise, and I don't know why it does thatConfused . I have tried to programing the speed to no effect, in fact as of now it is programed at full speed. Anyone has any idea?<
Is the TT installed on the layout?Was it tested before?
The first one I installed has problems even though it ran fine on the workbench.The problem(s) was how it was installed on the layout.
Some of the extension pieces were actually 'pinching' the gears and the rotation of the bridge.
Dr D
arcanjo Offline
#4 Posted : 14 June 2012 09:38:05(UTC)
arcanjo
Hi there!
Thanks for the replies! I think i solved the problem (at least partially). I removed all the spoke pieces from the base of the turntable, and then I put them again in a random order, to avoid the pieces being put in the same previous place. For some reason this seemed to fix great part of the "jerkiness" (I don't know if this word is rightBigGrin ). Even the platform still runs at a higher speed on one direction, it runs smoother and with more constant speed.
Thanks again!
Artologic Offline
#5 Posted : 15 June 2012 16:27:08(UTC)
Artologic
Hey Arcanjo,
Always nice to see you that you fixed the problem! I wouldn t be to worried about the running speed of the turntable, my old one does that too :-)
Kristof
arcanjo Offline
#6 Posted : 20 June 2012 17:24:26(UTC)
arcanjo
Thank you Kristof for the feedback!
Regards!
Miguel
This page was generated in 0.342 seconds.
Map
See the web site statistics
Bookmark and Share
