Offline Mille
#1 Posted : 25 January 2024 05:33:55(UTC)
Mille
Whats the best way to get the bridgepillar at the right
place before i screw them on my layout
Im gone have S shaped bridge
Any good ideas?
thanks 1 user liked this useful post by Mille
Online marklinist5999
#2 Posted : 25 January 2024 11:57:55(UTC)
Don't screw them down until the track is in place. Use putty or tacky wax to test fit them. When you get them where you want, then screw them down. There is always a need for adjustments. Even height of the pillars.
Offline Willem99
#3 Posted : 25 January 2024 16:00:19(UTC)
Willem99
Put them in place and move them where you need them.
Then use some sillicone around them to keep them there.
You can cover that with landscaping.
No need to screw them down.
That is what I did last time, going to follow the same process this time around.
Tim
thanks 1 user liked this useful post by Willem99
#4 Posted : 26 January 2024 00:57:43(UTC)
I also glued some down, and the plastic pillar sections together.
Offline Mille
#5 Posted : 26 January 2024 09:10:01(UTC)
Mille
Thanks for the advice
This page was generated in 0.325 seconds.
