Offline mike@complexplastics
#1 Posted : 30 December 2023 19:23:37(UTC)
while to most this must sound stupid but i just bought some parts and i can not see how to connect the transformer to this feeder track
mike knopfler
Offline PMPeter
#2 Posted : 30 December 2023 19:38:11(UTC)
PMPeter
I'm not sure if either of these items are Maerklin. I just tried to do a search on both of those numbers and came up with zero results. Can you post some pictures?
#3 Posted : 30 December 2023 20:19:56(UTC)
I think the transformer is 6646, but I cannot guess which feeder track is being used.
If the track is 24088, then you will need to find a Märklin cable with a round plug at one end and two blank wires at the other end. Or make a DIY solution.
Märklin E610718 is the cable from Mother M.
Online marklinist5999
#4 Posted : 31 December 2023 10:40:37(UTC)
Yes, or if m track from the 70s through 1999 feeder track has wires attached from factory. Otherwise brown wire from transformer to the outer rails and the red wire to the center studs.
This page was generated in 0.362 seconds.
