Offline Bilge Rat
#1 Posted : 07 June 2023 19:42:05(UTC)
Bilge Rat
I'm looking to add some 89401 signals to my expanded Z scale layout. However, I see from the instructions that they call for a 16v AC power supply and all of mine are DC output. I was wondering what others have used with success since the last thing I want is to fry the signals with a bad decision (electricity and I can sometimes be the worst of enemies - just ask my first computer).
Thanks for any recommendations!
Edited by user 09 June 2023 03:45:39(UTC)  | Reason: Not specified
#2 Posted : 07 June 2023 20:30:40(UTC)
The manual asks for 16 V AC - and that's the standard voltage of Märklin H0 gauge transformers.
Maybe you can find a 6646 from second hand market.
Offline Poor Skeleton
#3 Posted : 07 June 2023 22:46:53(UTC)
Poor Skeleton
Originally Posted by: Bilge Rat Go to Quoted Post
I'm looking to add some 89401 signals to my expanded Z scale layout. However, I see from the instructions that they call for a 15v AC power supply and all of mine are DC output. I was wondering what others have used with success since the last thing I want is to fry the signals with a bad decision (electricity and I can sometimes be the worst of enemies - just ask my first computer).
I checked out the instruction sheet for the signal and it says to use 16V AC or the accessory feed from the switched more power pack, which I happen to know is 12V DC. I'm not sure what to make of this, but I have been using 12V DC to operate turnouts for ages with no problems.
Chris
Offline Bilge Rat
#4 Posted : 08 June 2023 00:57:06(UTC)
Bilge Rat
Chris
I tried a test with the semaphore using the standard power supply. I just ran it in an automated loop and after a couple minutes that signal failed to reset (overheating issues?). That's when I dug out the instructions and actually read them (and it's 16V AC, not 15, oops).
I've never had issues using the regular turnouts but those show only a need for using the main (12V) power supply. Silly that a single piece of Z apparatus needs more power than everything else.
Offline Toosmall
#5 Posted : 08 June 2023 06:15:31(UTC)
Toosmall
I have a 12v DC supply for points.
Offline BenP
#6 Posted : 08 June 2023 14:55:10(UTC)
BenP
Surprised that newer semaphore requires 16v ac. The 8940 requires 10v ac, which is accessory power from marklin z transformer. Have you tried 10v ac?
Alternatively, I have been using inexpensive 16v ac transformers from amazon to power boosters and vintage ac lights (for ho layout). They include short and overheat protection like marklin 6646 transformer.
Ben
#7 Posted : 08 June 2023 21:30:45(UTC)
Poor Skeleton
That's interesting - I assumed that the feed to the signals was just momentary, as with the turnouts, and wouldn't have expected them to be energised for long enough to get them hot. Maybe they actually need to be energised continuously whenever they're in one of the positions in which case they may get hotter with DC than with AC.
Hope your signal recovers when it has cooled down.
Chris
Offline veloboldie
#8 Posted : 16 June 2023 03:38:33(UTC)
veloboldie
You will need to use Universal relay 7244 which has to be powered by Marklin 6646, 120 Volt, 32 VA AC transformer for these series of signals to work. Marklin_Gleisanlagen_Buch_1996_3.pdf (7,908kb) downloaded 19 time(s).
thanks 1 user liked this useful post by veloboldie
Online hxmiesa
#9 Posted : 16 June 2023 06:47:17(UTC)
You can also insert a couple of diodes en series with the lamps.
Anti-parallel if it is for AC.
Each diode will drop the voltage about 0,7V.
You dont need them for every lamp, just at the output from your power source.
Offline rovertino
#10 Posted : 23 June 2023 15:53:55(UTC)
rovertino
Chile
I've personally tested with 15V AC and it looks like it will brake or jump, it's just too strong and fast! I tried with standard Märklin Z transformer, 10V AC and works perfectly fine. You should give it a try!
Robert.
This page was generated in 0.831 seconds.
