Offline Zme
#1 Posted : 12 April 2023 16:22:32(UTC)
Zme
Hello Everyone, hope you are well.
The latest Trainini update may be downloaded from the link below:
https://www.trainini.eu/...Trainini_int_2023-03.pdf
Please let it download, it is a big file.
Enjoy. Take good care.
Dwight
Offline Toosmall
#2 Posted : 14 April 2023 02:00:54(UTC)
Toosmall
Making trains out of cardboard is impressive. It's hard enough making tiny things out of high impact styrene, sanding & painting.
I never thought of magnets for traction. Increased mass, traction tyres & magnet would be the ultimate, maybe other than a rack. That would be a challenge in itself.
This will be on the to do experiment list (probably ahead of projects that should be finished first!) even though I will not rip up my track as doing ballast is a pretty painful & time consuming task on Z gauge & don't want to do it a second time. But some steel under the track (probably gradients only uphill worth doing) & magnet in the bottom of the loco might just be enough.
I have previously bought some neodymium magnets for a GPS custom mount in the car which has a gap of about 6mm, but are much larger. Works brilliantly.
(Australia)
https://magnet.com.au/?_...xoT68WLFKvdK1NxAPYM9kIrb
Be very careful with larger neodymium magnets as they will crush fingers if they clamp at speed. Dangerous things.
Latest Trainini Update (Small scale)
by Zme 14/05/2024 21:54:51(UTC)
by Zme 18/04/2024 00:46:00(UTC)
by Zme 13/03/2024 21:17:29(UTC)
by Zme 22/02/2024 17:01:48(UTC)
by Zme 08/01/2024 22:14:00(UTC)
by Zme 12/12/2023 21:57:33(UTC)
by Zme 12/11/2023 01:19:08(UTC)
by Zme 13/10/2023 15:10:29(UTC)
by Zme 20/09/2023 01:28:45(UTC)
by Zme 10/08/2023 06:59:04(UTC)
by Zme 14/07/2023 05:03:05(UTC)
by Zme 14/06/2023 15:36:21(UTC)
by Zme 22/05/2023 06:25:00(UTC)
by Zme 17/03/2023 15:32:04(UTC)
by Zme 08/02/2023 17:18:54(UTC)
by Zme 12/01/2023 06:55:00(UTC)
by Zme 19/12/2022 16:51:28(UTC)
Latest Trainini update (Small scale)
by Zme 18/11/2022 23:23:40(UTC)
The latest Trainini update (Small scale)
by Zme 20/10/2022 16:45:05(UTC)
by Zme 17/09/2022 17:13:14(UTC)
by Zme 10/08/2022 14:37:12(UTC)
by Zme 14/07/2022 00:23:27(UTC)
by Zme 18/06/2022 00:08:19(UTC)
by Zme 13/05/2022 00:50:53(UTC)
Latest Trainini Update (200th Issue) (Small scale)
by Zme 11/04/2022 16:23:42(UTC)
by Zme 09/03/2022 16:55:30(UTC)
by Zme 04/02/2022 00:05:31(UTC)
This page was generated in 0.460 seconds.
