#1 Posted : 08 May 2006 12:39:20(UTC)
TOday I picked up a Lok that I got on Ebay. It is a Shunter ans has the number D71729 stamped on hte underside of the body.
I would like to identify the item. Runs beautifully and even old has had no running. Still stiff.
Hope that someone can help
Photo here( I take terrible photos)
Nev.Smile
Online xxup
#2 Posted : 08 May 2006 12:46:12(UTC)
It's a 3000... If it is running on your digital layout then it should be a delta version 3000.20 3000.30 or 3000.40 from startsets 2602, 2915 or 29205 respectively..
#3 Posted : 08 May 2006 12:49:08(UTC)
Originally posted by xxup
<br />Nev there is an extra %20 in the path to the image - that's why we can't see the picture...
Thanks Adrian.
Fixed, it was a Enter that did it.
Nev
#4 Posted : 08 May 2006 12:56:32(UTC)
#5 Posted : 08 May 2006 13:05:56(UTC)
<br />Try Here,
http://www.bahn.hfkern.d...aerklin/Dt_Loks_D89.html
Thanks Ray, looks like it is a series 3000 (7) 1963-67.
Nevbiggrin
Online xxup
#6 Posted : 08 May 2006 13:11:17(UTC)
Not if it ran correctly on a digital layout - 1963-67 is an analogue locos...
Look further down the list for all versions with a 89 006 number... There are three others to choose...
#7 Posted : 08 May 2006 13:18:16(UTC)
<br />Not if it ran correctly on a digital layout - 1963-67 is an analogue locos...
Adrian,
R So I did not look carefully enough so it must be one of these:
2602 1987-1991 Dig.6080 SFCM III 89 006 DB schwarz, 3 Lampen
2915 1992-1996 Delta SFCM III 89 006 DB schwarz, 3 Lampen, Set
It has 3 Lamps on front 3 dummys at rear.
I set the address at 6 and it ran. (that was the address that I was given)
Nev
Online xxup
#8 Posted : 08 May 2006 13:26:01(UTC)
Yep - she's a Delta...
Offline Hemmerich
#9 Posted : 08 May 2006 13:58:52(UTC)
Hemmerich
...has the number D71729 stamped on hte underside of the body.
That tells that this loco was originally contained in the set 2602. Cool
Lutz
Online xxup
#10 Posted : 08 May 2006 14:37:06(UTC)
That makes it a 3000.20.. Smile
#11 Posted : 08 May 2006 14:58:44(UTC)
Lutz
Adrian, Lutz, thanks very much.
NevSmile
#12 Posted : 08 May 2006 15:00:12(UTC)
<br />Try Here,
THnaks Ray.
Nev
This page was generated in 0.403 seconds.
