marklin-users.net community
| Forum
Home
Community Forum
Login
or
Register
Forum
Active Topics
Login
Register
OK
The Projects & Workshop area
Model railroad wiring
Booster 60175
2 Pages
1
2
Go to Page...
Booster 60175
Email this topic
LinkBack Topic URL
Retweet this Topic
Share Topic on Google+
Like this Topic
Share on Facebook
Digg this Topic
Reddit this Topic
Share on Tumblr
Watch this topic
Print this topic
» Normal
Threaded
Previous Topic
Next Topic
Thewolf
#51
Posted :
06 March 2019 23:59:29(UTC)
Retweet
- a single track with wiring ''B'' and ''O'' and a switch for the booster section 2
- a single track with wiring ''B'' and ''O'' and a switch for the booster section 3
- the''0'' between boosters 2 and 3 is connected together as well as with the''0'' of booster 1 and cs2
- the control leds of the boosters 2 and 3 shine.....
but the cs2 does not operate the 2 switches
I think it's no longer a wiring problem ....but a booster problem
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
User Profile
View All Posts by User
View Thanks
Thewolf
#52
Posted :
07 March 2019 14:23:44(UTC)
Retweet
Hi everybody
This morning this will be my last test : the 60145 terminal 2
I will connect booster 2 and 3 to terminal 1 which works with booster 1.
if booster 2 and 3 work, it's a problem of 60145 terminal 2
Have a nice day
Serge
1 user liked this useful post by Thewolf
Crazy Harry
User Profile
View Thanks
Thewolf
#53
Posted :
07 March 2019 17:21:42(UTC)
Retweet
After several days, I found the flaw.
Terminal 2 60145 is not working properly.
Booster 1, 2 and 3 work correctly with terminal 1
The cs2 operates the switches
I will change the location of the elements and place only one terminal.
I'm also going to change the separation of the layout.
Terminal 2 is going to be forgotten: it's going to be sent back to Mike. He'll do what he wants with it: feed if he wants.
Have a nice day
Thewolf
2 users liked this useful post by Thewolf
Crazy Harry
Legless
User Profile
View Thanks
Crazy Harry
#54
Posted :
07 March 2019 18:09:35(UTC)
Retweet
Glad you figured out your problem. Unfortunately, it did take a long time and caused some stress.
Harold.
User Profile
View Thanks
Thewolf
#55
Posted :
07 March 2019 18:58:48(UTC)
Retweet
Harold.
Hi Harold
Anyone who claims to find a problem in the digital railway in 5 minutes can only be a liar.
I know from experience that you have to consider all the possibilities of failure and it takes time, a lot of time and...especially calm.
The digital is complex and terribly delicate... especially with these osties de calisse de tabarnak of sockets and wire 0.14mm2.
At least it has the advantage of calming me down, although sometimes I want to throw everything out the window.
I continue the job under ....this grrrr table
Thewolf
Crazy Harry
User Profile
View Thanks
Posted :
07 March 2019 20:08:52(UTC)
Retweet
Originally Posted by: Thewolf
However, I wonder:
could the distance between the different boosters play a role?
Boosters 2 and 3 are placed 250cm from the second terminal 60145 which itself is placed more than 360cm from the first 60145.
Booster 1 is placed 200 cm from terminal 1
Serge
Yes, the distance will be a problem and has an effect on the operational reliability. Hence Märklin recommends a maximum of 100 m lenght by a minimum of 30 devices at the CAN bus main lines (there is a CAN bus high and CAN bus low. At the end both lines are connected and terminated by a 120 Ohm resistor). The length of the stub to a device shall have a maximum lenght of 2 meters. Dr. Stefan Krauß depicts it on his website and articles about the CAN bus as well. To achieve an operational reliability he recommends to follow Märklin's guidelines, even it may be possible these guidlines may be exceeded by facts sometimes.
Because of these guidelines Märklin offers all its various cables for CAN bus devcies with a maximum lenght of 2 meters. How did you achieve the lenghts of 3,6 m or 2,5 m?
WWW
User Profile
View Thanks
Thewolf
#57
Posted :
07 March 2019 20:37:38(UTC)
Retweet
However, I wonder:
Serge
Wolfgang hi
Have you read that the problem of the boosters2 and 3 is solved?
Have you read that I'm repositioning the elements?
So the distances for which I was wondering are no longer a source of questioning
Have a nice evening
Thewolf
User Profile
View Thanks
Posted :
07 March 2019 20:40:23(UTC)
Retweet
Just a clarifying comment on a very early post in this thread on voltage measurements taken with a MAS830B (a digital multimeter to measure voltages).
These devices by themselves don't give you an accurate reading of the voltage levels on the track because of the square wave digital signal data.
If taking a DC measurement, you will likely get an average voltage (and as the digital signal has the voltage moving up and down to encode the digital data on top of the total amplitude actual voltage level, your will get a much lower voltage reading than it really is).
The AC measurement setting is generally configured to give you AC voltages in the 50-60Hz range of frequencies and of sinusoidal waveform. Again the digital square wave signal nature will not give you a proper voltage reading. You either need to put a circuit between the track and your multi-meter terminals to filter out the digital data so you read the DC level, or use an oscilloscope to see the waveform and view the voltage.
My Layout Thread on
marklin-users.net:
InterCity 1-3-4
1 user liked this useful post by Minok
User Profile
View Thanks
Thewolf
#59
Posted :
07 March 2019 20:48:36(UTC)
Retweet
Thank you Mino
I didn't know that.
In other words, I should change my multimeter
Thewolf
User Profile
View Thanks
Posted :
07 March 2019 20:59:32(UTC)
Retweet
Thank you Mino
I didn't know that.
Thewolf
Not only changing buying an oscilloscope. But as you wrote, you are not Croesus .......
WWW
User Profile
View Thanks
Posted :
07 March 2019 22:27:05(UTC)
Retweet
I don't think you need it, as long as you remember that you readings are not accurate.
Compare the readings on your CS ( 18,xxV ) with the readings on your multi-meter ( 12,xxV ) and just remember this factor.
If you want a better multi-meter, it doesn't have to be expensive, it just have to be able to measure "true RMS".
It should be in the specifications.
These should all fulfill your needs:
https://www.ebay.com/sch...om=R40&_nkw=true+rms
Some of them are probably cheap sh**; but OK for low voltage
User Profile
View Thanks
2 Pages
1
2
Go to Page...
Booster 60175
General topics
- General MRR
- H0-scale
- Small scale
- Big scale
- Prototype
--- Videos
----- Steam
----- Electric
----- Diesel
----- Accidents
- Digital
- Model railroad software
- Model railroad photography
Reviews
- Loco Reviews
- Reviews of rolling stock
- Accessories reviews
- Model kit reviews
Collector's Corner
- Collector's Corner general
- Märklin Sprint
- Construction kits
- Steam engines
- Tinplate toys
- Märklin Factory Layouts
- Track plans
- Painting & Weathering
- Model railroad wiring
The Club Corner
You
cannot
You
cannot
You
cannot
You
cannot
You
cannot
create polls in this forum.
You
cannot
vote in polls in this forum.
Powered by YAF.NET
YAF.NET © 2003-2024, Yet Another Forum.NET
This page was generated in 0.399 seconds.
