Offline wojo12
#1 Posted : 04 January 2019 20:17:00(UTC)
wojo12
It is probably 40 years since I sold my childhood Marklin railway. It consisted mainly of the track with the three actual rails, together with some new-fangled stud centre rail track pieces!! I have just been offered a collection of rail pieces, points, controller (6177) and a couple of signals. This lot is all with the stud centre "rail"- I assume this is referred to as M track. There are no locos or rolling stock included.
From my research so far, I cannot see how three rail locos can run on some of the modern track types.
So - should I buy this, which is of an era that I understand, or am I better off starting from scratch with new technology? I have no intention of going digital.
Some gentle advice would be greatly appreciated
MrB32
#2 Posted : 04 January 2019 21:06:07(UTC)
I think it all depends on what look you are looking for and how much money you want to spend.
If it is the nostalgia of your childhood or a budget question, then M-track (centre studs, metal trackbed) or 3600 (centre rail, metal trackbed) track might be just what you need. The track is inexpensive and readily available on the second hand market. The beauty with Marklin track types and that they are compatible with each other. So you can start with M-track and extend with C-track using adapter tracks. C track will give access to greater radii (R3, R4, R5), and your locos will run on any of them. You can also buy brand new c-track to run all your analogue gear. There is no difference in the analogue technology other than the way you attach you power feeds or accessories to the track (different connectors).
Whatever you are going for,:
I would not invest in any old transformer and buy a new one (ref. 6647 or 66471).
If you buy used track, you are likely to encounter rust/oxidisation issues, so a good track rubber and some isopropyl alcohol is a must. So is a good pair of small pliers.
Offline wojo12
#3 Posted : 04 January 2019 21:58:47(UTC)
wojo12
Could someone please post a photo of the underside of a piece of C section track? From the illustrations I find online, it is also hard to see how the track sections connect physically and electrically.
#4 Posted : 04 January 2019 23:37:57(UTC)
Sorry cant post pics but I would go for C track. Decoders fit under the track to avoid a lot of wiring and are not seen. The track just slots together and a complete oval can but done and taken apart again in minutes. I would suggest buying a Marklin start set and spend as much as you can feel you wish to spend to get the most up to date equipment which will pay in the long term. Running qualities of C track are very good.
Offline TEEWolf
#5 Posted : 05 January 2019 00:35:46(UTC)
Have an intensive look into these brochures you may find you are looking for.
http://www.ccbrailroad.c...nuales/marklin_via_c.pdf
https://www.maerklin.de/...C3%A4nzungspackungen.pdf
Offline wojo12
#6 Posted : 05 January 2019 03:35:45(UTC)
wojo12
Unfortunately, I can't read German, but thanks.
Offline PMPeter
#7 Posted : 05 January 2019 04:16:25(UTC)
PMPeter
John,
You were looking for an under track photo of the C track connection. What Teewolf sent you in the first link shows that photo on page 15, c/w how the red and brown cables connect to the track.
Offline TEEWolf
#8 Posted : 05 January 2019 04:21:28(UTC)
Indeed the one brochure is only in German, but if you scroll down to the last page you see C-tracks pictures from the underside, as you requested.
The other brochure is in German and English. It gives an short overview of the C-track programm and the geometry in an English description.
Also here is quite a helpful software translation program
https://www.deepl.com/translator
which may help you too.
Indeed without knowing German, it is not easy to understand the written text, but the pictures explains quite often more than the text. For more underside pictures of C-tracks see here (even the text is in German too). It shows the flow of the current.
http://www.schnug-modell...n.de/Tipps/Kogleis-c.htm
http://www.modellbahnkel...chalten/Kontaktgleis.htm
If you use Google search by the words "Maerklin C-Gleis Verbindung" like this one:
https://www.google.de/se...amp;biw=1152&bih=536
or just this one
https://www.google.de/se...0i24.y8YaO-xT-9I#imgrc=_
This little red plastic sticks between the C-tracks connection shall interrupt the current flow at this pont of your layout.
https://www.maerklin.de/...s/details/article/74030/
https://static.maerklin....1eaaa744611537193894.pdf
It is not quick and easy finding you are looking for. In English you will not get a satisfying result, because most of the publications (even fromMärklin itself) is only in German. Märklin offers so called technical tipps you find in the section of the FAQs
https://www.maerklin.de/...quently-asked-questions/
#9 Posted : 05 January 2019 04:53:22(UTC)
Ask, and ye shall receive... hopefully this makes it clear how they connect BigGrin
Offline wojo12
#10 Posted : 05 January 2019 06:17:55(UTC)
wojo12
Thanks heaps, Cookee. It makes sense now.
#11 Posted : 05 January 2019 06:52:09(UTC)
Views messages in topic : 9,477
Mate,
It's like Playboy or Penthouse magazine - you only need to look at the pictures.. The words are not worth reading anyway.. RollEyes
thanks 7 users liked this useful post by xxup
Offline Br502362
#12 Posted : 05 January 2019 12:00:44(UTC)
Br502362
Spot on Adrian LOL LOL LOL
-Åke-
This page was generated in 2.172 seconds.
