Offline Thewolf
#1 Posted : 30 December 2017 15:41:48(UTC)
Thewolf
Hi everybody Cool
I have problems with telex locos and freight cars couplers : they do not couple
I suppose that a special coupler for telex is necessary, no ?
Which one ? I don't know
Thank you for your reply
Thewolf
#2 Posted : 30 December 2017 16:37:42(UTC)
There are different types of Telex couplers and there are different types of freight car couplers. Some are compatible and some are not.
In general the older Telex work well with older Relex wagon couplers and the newer Telex work well with the modern close couplers.
Offline Thewolf
#3 Posted : 30 December 2017 17:07:41(UTC)
Thewolf
Thank you RayCool
My locos was bought between 2012 and 2017. They are not certainly old telex.
Can you give me the reference for the couplers please old and new?
Thank you
Thewolf
#4 Posted : 30 December 2017 17:39:32(UTC)
Locos with old-style Telex were still in the 2011/2012 catalogue and maybe even later, so your locos could have old-style or new-style Telex couplers.
Maybe give us the ref. numbers of the locos.
Offline Thewolf
#5 Posted : 30 December 2017 18:01:54(UTC)
Thewolf
Ok Tom
Here the locos :
the steamer Br 44 (29440)
loco 37616
loco 36827
loco 36814
loco 37851
Thewolf
Offline Thewolf
#6 Posted : 30 December 2017 23:05:27(UTC)
Thewolf
Hi all Cool
Mike confirmed to me :
All of the locos on the list have a new style telex coupler so they should work with a coupler that looks like 46042 (by example). Marklin has only 2 couplers, relex, and close. Close couplers are installed on the majority of Marklin freight and passenger cars. Relex is found on older Marklin cars (pre 1990) and on some Hobby or Start-Up Marklin locomotive and cars.
And always according to Mike, this is me who commit a little mistake. I forgot the telex must be off for connecting the car.
Mike writes to me :
Make sure the telex is off when you try to connect to the car. You only tap the symbol on the CS2 when you want to disconnect.
Tests tomorrow
Have a nice evennng
Thewolf
Offline Richard556
#7 Posted : 01 January 2018 10:36:27(UTC)
Richard556
It sounds like you have locos with the newer telex coupler. The new telex coupler works with wagons with close couplers but will not work with wagons with relex couplers no matter how hard you try (a fact conveniently left out of the Märklin catalog when the new telex couplers were introduced around five years ago). You generally can retrofit close couplers to wagons with plastic relex couplers.
Offline Thewolf
#8 Posted : 01 January 2018 13:24:47(UTC)
Thewolf
Hi Richard556Cool
I appreciate your replys, because it is the perfect complement for the explanations of Mike
Thewolf
Offline WLAB
#9 Posted : 09 February 2018 21:43:28(UTC)
WLAB
Romania
Hi everyone. This is my first post here. I have a pair of Telex digital coupler ,at the begining they worked normally, after a while the loco was out of service , I encounter the follow issue, After actuating,the locking pin wont come back down by its own ,leaving the hooker moving freely and obivous, unable to pull the trains.
I have to push the pin down with a screwdriver in order to lock the hook back.
Firstly, I tougth maybe the pin is stuck , I sprayed some WD40 over it, then tried cleaning it with alcohol, nothing works.
There is no low voltage remaining over,it acts the same the next day.
Any toughts? I wouldnt replace them with Roco or Krois. Thank you !
#10 Posted : 10 February 2018 14:42:16(UTC)
See my post in your other thread.
This page was generated in 0.701 seconds.
