Offline madhu.gn.71
#1 Posted : 06 February 2017 19:15:03(UTC)
madhu.gn.71
India
Team, I have few questions. Few minutes back I tried running my GP9 2, PROTO 2000 series DCC(?) with my MS2. I used a 2 rail track and connected the brown and red wires as shown in the below pictures. I set the DCC address to 3 and tried switching on the MS2 by pressing STOP button. All I could hear was a buzz indicating that there was a short circuit. MS2 swtiched to STOP mode. Here are my questions
1. I want to reconfirm if my wiring from 60113 to the 2 rail track is correct?
2. Does this loco really have a DCC fixed ?
Please help..
Edited by user 07 February 2017 15:00:01(UTC)  | Reason: Not specified
#2 Posted : 06 February 2017 19:38:38(UTC)
You have been a member since:: 12/08/2006(UTC)
I can´t see decoder in the locomotive...
It seems you did bought an model prepare for the DCC but without decoder.
P.S.
What is all diodes for??
Offline michelvr
#3 Posted : 07 February 2017 03:15:13(UTC)
michelvr
P.S.
Goofy is correct there is no decoder, just an 8 pin plug. You will need to get an 8 pin decoder for that locomotive.
Michel
Offline madhu.gn.71
#4 Posted : 07 February 2017 08:25:56(UTC)
madhu.gn.71
India
Thank you Goofy and Michel for your inputs.
P.S.
This is what I could get after searching on Google
One URL http://cs.trains.com/mrr/f/88/t/203635.aspx said
"the earliest Proto GP7, GP9 units uses a large bank of diodes for the constant lighting circuit"
This link says the diode bank should be removed before installing a decoder.
http://www.digitrax.com/...tuff-they-dont-tell-you/
#5 Posted : 07 February 2017 10:42:56(UTC)
The loco is indeed "DCC ready". For going digital - see snapshot.
Offline madhu.gn.71
#6 Posted : 07 February 2017 11:28:21(UTC)
madhu.gn.71
India
Thank you AK. Bottomline - buying a decoder is inevitable
#7 Posted : 07 February 2017 22:02:16(UTC)
Yep, the Pico DC controller you have will likely work, but DCC is a constant DC voltage (sorta) with digital signal cut into it, so you need a DCC decoder to interpret and drive the motor.
The diodes (I'm guessing as I'm not a DC modeler) are to allow the DC voltage to be applied in either way (+ left or + right) and still produce a consistent result - it routes the + and - to the motor in a consistent way.
Though its highly sketchy (though maybe common) to have the DCC logo on the box without indicating DCC 'ready' vs DCC 'onboard' or installed. But thats a problem within the DCC manufacturers space that they cannot seem to get straight.
#8 Posted : 07 February 2017 23:05:40(UTC)
Found in my archive.
This page was generated in 0.560 seconds.
