Offline Sang Joon Oh
#1 Posted : 30 January 2017 01:31:20(UTC)
Sang Joon Oh
Hello.
I have a question about detecting location of train.
I know about that we can detect location of any trains with S88 & circuit track 24994.
When train pass over on circuit track, I want to detect which kind of train pass over.
Is it Possible or not.?
Best Regards.
Offline ixldoc
#2 Posted : 30 January 2017 07:20:31(UTC)
ixldoc
Tricky to detect specific trains but possibly by attaching a passive RFID to the loco and have a reader beside the track. The tags are tiny, require no battery, but it would have to be a low power version or it could be detected while the train was anywhere on the track. They are available with a 10cm read distance I believe.
Alternative would be a barcode on the side or under a carriage and reader beside or under the track.
Other more qualified members may be able to suggest other ways.
Welcome to the forum.
Howard.
Offline Danlake
#3 Posted : 30 January 2017 08:16:17(UTC)
Danlake
Yes with pc software control and railcom from Lenz only.
This has always been the biggest disadvantage with the various train controller: they can detect and manage sequence route logic etc. but they don't know what train triggered a feedback sensor....
Brgds Lasse
Online H0
#4 Posted : 30 January 2017 08:24:37(UTC)
Can also be done with RailCom and ESU ECoS. Even without PC control this can be done to some extent.
I think mfx will be able to do the same once the RailCom patents expire ...
#5 Posted : 30 January 2017 21:46:49(UTC)
As mentioned, RFID would be a current technology one could use - placing small (grain of rice) sized passive (no battery) RFID chips on the bottom of the locomotives (and cars I suppose) and then installing under track RFID transceivers that are RF shielded to focus the signal up in a narrow band - thus being able to read the sensors as they passed by. But thats a project onto itself.
The decoders IN a locomotive could technically transmit their ID out, paired with a sensor ID they just drove past, on the digital stream, but as H0 mentioned, some of the key technology seems to be patented by Lenz and they are releasing it free only to the DCC community. US patents run 19 years, so whenever the patent started,.... we can wait. I suspect Märklin are not going to invent a new technology if they don't have to.
#6 Posted : 30 January 2017 23:27:37(UTC)
Using the standard Märklin products, no. However the reason for this is that it is totally unnecessary. Here is why.
Say you have a goods train and a passenger train.
Say you start with the trains like this:
====goods train>===== s88 #2 ==========s88 #3======passenger train> ====== s88 #4 ===== s88 #5=====
if s88 #2 triggers your software can 'know' that it is the goods train.
if s88 #4 triggers your software can 'know' that it is the passenger train.
It is trivial for the software to track what the state of the trains is. State includes current position, type, speed, colour etc.
See http://cabin-layout.blog...11/computer-control.html especially section called "Train identification systems"
Offline Piper
#7 Posted : 31 January 2017 07:32:38(UTC)
Piper
Hi Minok, good concept. Have a look at Littfinski LDT who has a product that can do this.Cool
https://www.ldt-infocenter.com/d...doku.php?id=en:rfid-home
Pieter
Era I-V / HO / C-Track / MS2, CS2 & CS3 Z gauge. Insider
Member of Märklin Modellers Group
thanks 1 user liked this useful post by Piper
Online H0
#8 Posted : 31 January 2017 08:20:52(UTC)
With RailCom the ECoS can tell a freight train from a passenger train and treat them differently.
This "unnecessary"feature makes a PC "unnecessary".
The s88 solution makes it necessary that the PC software knows all trains (type, length, position). If a power failure or manual re-arranging brings layout and software out of sync, then the software might treat passenger trains like freight trains and vice versa.
Uhlenbrock Lissy is another system for the detection of loco positions.
#9 Posted : 31 January 2017 19:06:12(UTC)
Every digital system uses a computer of some sort (central unit). The lower levels ones do not track the layout state. More sophisticated software does.
In all the years I have been operating my trains I do not recall there ever being a power failure. If that did happen, all the trains would stop and when power comes back on I may have to tell it the locations of a few trains. This is such a trivial task it is not even worth further discussion.
Offline perz
#10 Posted : 01 February 2017 23:19:27(UTC)
perz
I think RFID is (at least theoretically) the optimal technology if you want identification (not just detection). But as Dale Schultz points out, it is hardly necessary to have more than just detection, if you are just interested in the positions of the trains. The SW can keep track of which train is where.
I think RFID would make sense if you e.g. try to implement an automated shunt yard. With a tag in each car you can keep track of each car separately. That won't be easily doable with "just detection" techniques.
Looking att the Littfinski RFID system, however, it seems poorly optimized. Someone should put the effort to fully adapt the technology to the MR conditions to really make it fly.
Bar code was also mentioned. There has been some equipment out there, but it does not work so well in the MR environment.
Beside RFID and bar code, there is also IR communication. Uhlenbrock has (had ?) the "Lizzy" system, and I have built something similar myself. My home made version of it (http://www.persmodelrailroad.com/ir.html) is extremely reliable and quite cost efficient , but it is rather complicated to integrate the transmitters into the locos.
This page was generated in 0.632 seconds.
