Offline thomasparks
#1 Posted : 18 February 2015 22:55:31(UTC)
thomasparks
Where can I buy headlight bulbs for Marklin DA800? How do I find part number for them?
Offline SteamNut
#2 Posted : 19 February 2015 01:40:54(UTC)
SteamNut
I believe DA800 is the same as 3005. Part # 60 000 which is the same for the old M track turnouts. On EBay you can see pictures if it matches. The data base on Marklin's web has a data base for 3005 not DA800 hope this helps - Fred
Online H0
#3 Posted : 19 February 2015 08:14:43(UTC)
Hi, Thomas,
Welcome to the forum.
It should be easy to find the five-digit spare part numbers for the light bulbs (not my area of expertise).
Märklin changed to six-digit spare part numbers decades ago - simply add a 0 add the end.
They switched to spare parts in larger quantities not so long ago - simply add an E at the start.
So instead of "60000" search for "600000" or "600 000" and for "e600000" - sellers use different notations.
Offline Ken Mitchell
#4 Posted : 19 February 2015 14:23:12(UTC)
Ken Mitchell
Hi Thomas,
I have both the DA800 and slighter later model 3005. The lamps are part number 60000 and fit both models. You can find the parts lists on the Marklin website as follows. https://www.maerklinshop...partslists&gaugeid=2
Regards Ken
Online H0
#5 Posted : 19 February 2015 15:53:16(UTC)
The lamps that had the spare part number 60008 are now listed as E600080.
And similarly 60000 and 600000 refer to the same lamp like 60030 and 600300 refer to the same brushes (but the Märklin Shop will only find them when you search for E600300).
New longer numbers due to a new numbering scheme. You'll have more hits if you search for all three numbers.
Märklin E600000 on eBay:
http://www.ebay.de/sch/i...E600000&_sacat=22128
BTW: On eBay you find cheaper offers without the "E".
Offline thomasparks
#6 Posted : 19 February 2015 21:42:41(UTC)
thomasparks
Thanks to all of the above responses. You've been very helpful.
Replacement Light Bulbs (H0-scale)
by Don Mebius 20/10/2018 22:51:19(UTC)
This page was generated in 0.467 seconds.
