Offline petestra
#1 Posted : 28 January 2015 19:14:26(UTC)
Hi Guys, I had recently been having some troubles with one of my Loks (37485 BR120) in that when running with other Loks after a short time the power will
switch all Loks to stop on my MS2s, even while running alone or with only one other Lok at about 1/4 speed. If you run your trains often as I do you may want to
know what I did to fix this problem. The brushes on this Lok were replaced just last August so I knew that couldn't be it. I decided to clean the armature
on this lok. I did it the normal way I do with Q-tips and Ronsom lighter fluid. Well now it is fine and I just ran it with 3 other trains and no power cut off
happened. I will just have to clean this lok more often. Peter Love
This page was generated in 0.213 seconds.
