Offline Z-nerd
#1 Posted : 20 December 2014 14:51:42(UTC)
Z-nerd
I recently bought the 8891 Tender loco and attached about 8-10 freight waggons to it. I noticed that the
loco clearly was affected by the weight that it had to pull and that it lost quite a lot of speed.
Now I wonder if the Märklin H0 version of the same loco (the 3091)would
have better power scalewise to pull the same amount of waggons.
Offline SteamNut
#2 Posted : 21 December 2014 00:17:10(UTC)
SteamNut
I have a 3048 on a analog layout and ten cars are no problem but my old 3047 and can out pull anything, other members have had similar experiences because of the way it was geared.
#3 Posted : 21 December 2014 00:43:49(UTC)
I would say most Marklin HO locos can pull 8-10 freight wagons with no significant struggle.
Offline ozzman
#4 Posted : 21 December 2014 06:14:31(UTC)
ozzman
A couple of factors might be in play here. Firstly, is that a 195mm curve? The sharper the curve the more drag on the wheel flanges of your wagons or coaches. Secondly, Z scale locos are light, relative to their size, meaning that they may not have as good traction as their big HO brothers. Or a combination of the two.
Gary
Z Scale
Offline Janne75
#5 Posted : 21 December 2014 08:18:24(UTC)
Janne75
Does Z scale locos have traction tires? If no, then this has a big difference in traction vs. H0 scale. Most H0 locos can pull almost anything. Only some very lightweight small H0 locos have sometimes problems with 8-10 cars. I have "fixed" this issue by adding lead weights to my most lightweight H0 locos and now they pull very long and heavy trains like the bigger ones.
I believe the axle weights are not as big in Z scale than H0 scale scalewise and this is the reason why these smaller ones can have traction problems.
Janne
#6 Posted : 21 December 2014 08:20:04(UTC)
Another important factor: Z scale locos typically do not have traction tyres.
Model cars have a higher friction than prototype cars. To compensate for this, H0 models typically have traction tyres.
I don't know if an H0 model without traction tyres can pull more cars than a similar Z scale model. But most likely smaller scales will reduce the pulling power.
Offline ozzman
#7 Posted : 21 December 2014 10:32:35(UTC)
ozzman
Marklin doesn't put traction tyres on Z scale locos. I did try out Bullfrog Snot on a couple of mine, but all it did was to reduce the traction of the driving wheels it wasn't applied to.
Gary
Z Scale
Offline ozzman
#8 Posted : 21 December 2014 10:37:23(UTC)
ozzman
Gary
Z Scale
Offline hgk
#9 Posted : 25 December 2014 04:42:56(UTC)
hgk
40+ see answer #8 in the link below. Although it's a reference to the MTL brand it should be similar for Marklin, but it would be interesting-fun to do a test with Marklin:
http://www.val-ease-cent.../ZSR/Z-ScaleRails_4.html
-George
This page was generated in 0.462 seconds.
