Offline morsing
#1 Posted : 08 September 2014 20:42:13(UTC)
morsing
I put decoders in two of my points so I could operate them via my MS2 but it occurred to me that as my layout grows it will be pretty cumbersome to:
1) Remember the addresses of all the points, unless visibly labelled
2) Scroll to the switch/signal address on the MS2 to operate it
So, to digital users that haven't gone fully computerised, how to you operate them:
a) With your hands
b) Old fasioned elctromechanically (blue box with buttons, where you still have to know which button operates what)
c) Addresses in MS/CS
d) Board with drawing of station and toggle buttons for the points/signals
e) Something else?
Marklin C-track + CS3+
Offline PMPeter
#2 Posted : 08 September 2014 21:14:58(UTC)
PMPeter
Great question as I too am struggling with the same issue. I am still using a 6021 with 6040 keyboards. So far I have 64 decoder addresses for switches and uncouplers before I have added a single signal.
Impossible to keep track of what is what without my labelled SCARM layout.
Offline Chris6382chris
#3 Posted : 08 September 2014 21:23:13(UTC)
Chris6382chris
2) Scroll to the switch.signal address on the MS2 to operate it
So, to digital users that haven''t gone fully computerised, how to you operate them:
a) With your hands
e) Something else?
On my layout I have 44 turnouts controlled digitally. I use 11 Switchpilots that's can control 4 turnouts each. The switchpilots are all routed to by ECOS 2, where I have diagrams of all the areas of my layout so I can simply touch the switch or the route and all switches are then thrown properly.
I also have switches in the yard area that are not controlled by any motor or mechanism and those switches are thrown manually.
thanks 1 user liked this useful post by Chris6382chris
Offline MikeR
#4 Posted : 08 September 2014 21:35:47(UTC)
MikeR
a) With your hands
e) Something else?
Hi Morsing
The CS2 allows the user to draw switchboards of parts of the layout with all points, uncouplers, turntable etc. on the switchboard. It is therefore unnecessary to remember the number of a point and much easier to simply pull up the requisite switchboard and operate the required point or other device. Switchboards can also be linked so touching the end of a track on one switchboard will move you to the next logical switchboard attached to that track. It is therefore easy to set up a route by calling up the required switchboards in sequence. I have set up my layout (over 60 points) and find this facility on the CS2 a major step forward from having to remember the numbers of all my points etc.
Member of ETE
Offline morsing
#5 Posted : 08 September 2014 21:46:27(UTC)
morsing
I did not know that...
Another reason to get a CS2! Love
Offline Harvey
#6 Posted : 09 September 2014 02:33:31(UTC)
Harvey
I use a combination of approaches to control switching tracks
- in full automated running, reed switches and S88 will control the two hidden yards (each with 4 switching tracks). Signals are also connected to S88 (with K83s) to control traffic flow on the passenger and freight line.
- For 'manual operation' I use the CS2 keyboard or layout functions. I have a WinTrack printout of the layout and labeled all signals and switching track addresses.
-my freight yard is operate by the layout functions - I drew the yard in the layout tool.
Each works fine. Only issue is some switching tracks in the freight yard need extra attention - don't always work. The layout tool is a bit sensitive but it is definitely a real positive for the freight yard.
Harvey
#7 Posted : 09 September 2014 07:41:03(UTC)
My CS1 and the ECoS can do that, too. AFAIK the Viessmann Commander also does it.
Not a unique feature of the CS2 - if you want it, there are several controllers to choose from.
Offline sjlauritsen
#8 Posted : 09 September 2014 10:43:00(UTC)
sjlauritsen
Some manual, some controlled digitally.
Some will never be digital, especially around the yards and depots. I think it adds to operating realism if the loco driver must think for himself.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#9 Posted : 09 September 2014 13:41:15(UTC)
a) With your hands
e) Something else?
My method is:
My layout is small, and only has 12 turnouts and 6 signals at the moment. Some of these turnouts are paired, as are the signals that are associated with them, which means that one button push will change up to two turnouts and 2 signals. I currently have 8 pairs of switches on my blue control boxes in use, so it's not that hard to remember which is which.
I have resisted the urge to make them digital because my layout can also become analogue at the flick of a switch, which means that I would still need the analogue controls anyway in parallel with the decoders.
All my electromechanical accessories at the moment can be controlled from a bank of four of the blue control boxes. I would start thinking about alternatives If I were at the stage where I would need more than eight boxes.
Offline pab
#10 Posted : 09 September 2014 14:05:02(UTC)
pab
I control my trains digitally with an Ecos (1).
The control of points, signals and so on is still the old fashioned way. The same for moving objects and the city and street lights.
I can switch with the switch boxes (white or blue), but most of the signals are also changed by circuit tracks from green to red and vice versa. A lot of turn outs are set in the right direction by circuit tracks.
For occupation detection I use relays and circuit tracks in my shadow station,. That way I avoid incoming trains on a occupied track and the incorrect setting of signals and turn outs.
Since I'm a little bit older I have a drawing of my lay-out with numbers for all the items. The boxes are numbered accordingly. I have 40 blue and white boxes.
thanks 1 user liked this useful post by pab
Offline LeoArietis
#11 Posted : 03 October 2014 23:09:13(UTC)
LeoArietis
I use toggle-swiches on a drawn board. Analogue, with feed-back-indication LED:s.
Current layout:
The former project:
thanks 4 users liked this useful post by LeoArietis
#12 Posted : 03 October 2014 23:49:08(UTC)
Digitally with MS2 and Lenz LS150(turnout decoder).
Only with DCC protocol and also with locomotivs.
Offline morsing
#13 Posted : 04 October 2014 09:40:21(UTC)
morsing
That's looks great - what are the red buttons for? De-couplers?
When you say feedback LEDs, do they actually get the position from the points?
Offline Janne75
#14 Posted : 04 October 2014 22:56:07(UTC)
Janne75
I control all my 25 C-track turnouts digitally with CS2. I use either keyboard pages or memory pages (for routes). I don't usually switch my turnouts from layout page as I don't find it very practical way to do it. Both other options above are somehow better for me.
I have 14 Märklin Hobby series signals and all of them are controlled manually with their own control boxes. They don't cut track power. I just change them according to how they should be vs. how the locos run BigGrin . I wanted to have some signals without the need to cut track power. This is ok for me.
Janne
This page was generated in 1.068 seconds.
