Offline Crocodile
#1 Posted : 17 August 2014 16:42:25(UTC)
Crocodile
How can the directional travel be changed so that #1 on cab is forward. Have same issue with my 103. Both loco's are MFX. Thanks
#2 Posted : 17 August 2014 18:00:29(UTC)
There is a cv which sets the direction of travel. Can't remember which it is at the moment, sorry.
#3 Posted : 17 August 2014 19:46:15(UTC)
There is CV29 you can set direction.
But it´s for DCC protocol.
I´m not sure if it does work with mfx decoder.
#4 Posted : 17 August 2014 20:34:39(UTC)
Märklin made the vast majority of BR 103 models so that cab #2 will be the default direction. You get the best tractive effort with slider forward. So why change it?
With some decoders you can change the default direction, with some you cannot. We'd need more information.
Offline Dimi194
#5 Posted : 17 August 2014 23:56:19(UTC)
Dimi194
Really? Why is that? (Thanks for the heads up, didn't know this!)
#6 Posted : 18 August 2014 08:07:05(UTC)
Originally Posted by: Dimi194 Go to Quoted Post
Why is that?
The pivot points of the trucks are above rail level and the coupler is also above rail level.
That's why the leading axle of each truck gets lifted, that's why the leading truck gets lifted.
For Märklin's E 17, MIBA measured a tractive effort of 181 gr with cab 1 forward - and 330 gr with cab 2 forward.
E 17, E 18 and E 19 are other locos that usually have the slider under cab 2.
In 1:1 gauge they use special mechanisms (Tiefanlenkung in German, weight transfer linkage (?) in English) to compensate this.
#7 Posted : 18 August 2014 09:16:34(UTC)
Good explanation, Tom.
I always think of the comparison with front wheel drive and rear wheel drive in cars. Rear wheel drive cars are less likely to break traction on acceleration than front wheel drive cars.
This page was generated in 0.573 seconds.
