#1 Posted : 26 March 2014 05:23:31(UTC)
AS Noted I have a 451 Crane.
What would be the most desirable Voltage to apply to this Wonderful item.
Any clues as to the AMPs that it draws??
I do have a 14V AC transformer which on a takeoff Leads I could fit a resistor to bring the VOltage down to desirable.
TA in advance
Nev
PS: do not really want to use the Blue or White Controllers as a Source.
#2 Posted : 26 March 2014 06:18:53(UTC)
The Marklin transformers will work the best, but I guess any similar AC power supply that outputs 18v or so would be good - 14v might be too low.
As the crane uses LFCM motors, the rule of thumb would be 10VA per motor, 1VA for each of the lights, and goodness knows what for the magnet, but say 5VA.
#3 Posted : 26 March 2014 07:26:30(UTC)
I have seen this one moving at a Nice slow speed and the powerwas supplied from an old Blue transformer. at about 1/2 speed so what would that voltage be??
NN
Offline Renato
#4 Posted : 27 March 2014 19:58:18(UTC)
Renato
You have been a member since:: 19/03/2004(UTC)
Hi Nev,
You can try to power the crane with the red-brown output sockets on the transformer, regulating the transformer voltage with the red knob, so you can set the desired speed and measure the voltage with a multimeter (if you have any).
But please do not change the direction with the knob, otherwise you have 24 V (too much...)
I do not know if the older 451 crane had a nominal voltage of 20 V, instead of 16 V of the more recent 7051 model.
Renato
thanks 2 users liked this useful post by Renato
#5 Posted : 27 March 2014 23:46:30(UTC)
Originally Posted by: Renato Go to Quoted Post
Hi Nev,
Renato
Thnaks Renato, unfortunately I do not have any of the old transformers with the red knob that regulates speed. I have a Maerklin 60VA power supply and also another brand that outputs 14V AC. so will give a test to see which is best.
If necessary I will adjust the power to the crane by putting a resister into the circuit.
N
This page was generated in 0.277 seconds.
