Offline FMS
#1 Posted : 31 May 2009 00:08:21(UTC)
FMS
I'm having problems to keep my track clean. Does anyone have any home made plans or ideas to create something that helps with this cleaning process? I don't feel like buying something expensive (for me it is) from Lux. Or maybe somebody knows about some other less expensive brand..I don't know...Can somebody give me a help here?
Thank you all in advance
FMS
Offline pa-pauls
#2 Posted : 31 May 2009 00:57:51(UTC)
pa-pauls
Pål Paulsen
Online kimballthurlow
#3 Posted : 31 May 2009 01:01:22(UTC)
Hi FMS,
The best solution is a cheap one. It is made by Noch. It clips on the axle of any freight car.
I will post a photo as soon as I find it in another thread.
Offline davemr
#4 Posted : 31 May 2009 01:13:53(UTC)
davemr
A track cleaning rubber is the best way to keep them clean I find. It costs little and lasts a long time and is quick. Also if you run trains on a regular basis then C track hardly ever needs cleaning.
davemr
#5 Posted : 31 May 2009 01:27:34(UTC)
Here is the Noch track cleaning adaptor to clip on to most freight car or tender axle.
It only costs a few dollars for a pack of 5.
See http://www.noch.de/en/produktka...e3=&navi_Kategorie4=
Offline FMS
#6 Posted : 31 May 2009 12:17:10(UTC)
FMS
Kimbal, Dave and Pal,
Thank You for the inputs.
Maybe, if there's no other way, the solution might be the Marklin car.
I've got those Noch felts but they don't seem to be very efective due to the fact that they don't have any weight, so they don't produce any type of effort against the track.
About the rubber, I bought one and I tried it but in my opinion it's no good. The reason: it produces almost the same efect as sand paper. When track comes out of factory it comes with a certain finishing,the metal is totaly smooth and flat, when we use abrasive products we ruin that finishing and dirt starts to grab and get into the metal easely, the cleaing process will be more dificult from here.
FMS
#7 Posted : 31 May 2009 13:59:46(UTC)
Hi FMS,
Is it really dirty track?
I found that extra red/brown connection wires at various locations on my track solved many of my contact problems.
#8 Posted : 31 May 2009 14:07:15(UTC)
FMS, I would tend to agree with you. The track rubber is my last resort when track has been unused for so long that it has started corroding. The best solution I have found is to run your trains every day, that way you don't get too much dust mixing with the greasy deposits on the rails, which is the main problem causing loss of electrical contact.
I have been considering Kimball's suggestion of the "Noch solution", but I can see that that will only work with very regular running. The Marklin wagon is another possibility, but I don't see it being much better than an ordinary wagon with a Noch pad.
When I find a patch of track where locos hesitate, I run a clean cloth or paper towel along the top of the rails, and this usually wipes off the offending "muck". This is harder to do over turnouts, and even harder if there is catenary.
Offline FMS
#9 Posted : 31 May 2009 18:33:52(UTC)
FMS
Hi Kimball, Hi Ray!
Yes it's realy dirt.
I only have bad conections sometimes in certain areas and with certain locos...the Divas, the others couldn't care less..
I'm using C-track, so I don't have too much of those "events".
What I do notice, despite of what some users might say about C track, is that there's dirt. When I need to clean usually I need 3 pieces of rag to totally remove the black dirt from the top of the rails.
What makes me concerned is the fact that part of it, even if doesn't represent bad conection all the time,goes to the machines and rolling stock wheels. Maybe I'm beeing a bit weird with this, but I like to keep everything in perfect conditions.
FMS
Offline davemr
#10 Posted : 31 May 2009 23:00:39(UTC)
davemr
Remember also to clean the loco wheels and rolling stock. And yes I use my track rubber for that as well. It does no harm to track or wheels (I use the Roco one) and if used once a month or two will keep everything running.
The Noch pads etc are as said too lightweight and the Marklin effort would need to be run continually all over the layout to make a difference.
My advice is dont spend cash on somedthing that you dont need but rather buy a coach or loco.
davemr
Offline shaygetz
#11 Posted : 03 June 2009 02:25:22(UTC)
shaygetz
I use a Masonite pad mounted to the bottom of a couple of cars...
...with maghnets on the antiques...
...and with nails through the bottom of cheap cars.
You don't have to attach them, just allow them to "float" in the holes to go with the rise and fall of the track. It's a trick that's been around for many years and only costs a few pennies a car. I run one in every train and rarely have to clean mainline track.
"To escape the error of salvation by works we have fallen into the opposite error of salvation without obedience.”
---A.W. Tozer
Webpage... www.freewebs.com/shaygetz
Blog... http://misterbobsmodelworksemporium.blogspot.com/
Offline rcorreia
#12 Posted : 03 June 2009 02:51:51(UTC)
rcorreia
Hi FMS
I use a Roco car with a cleaning rubber, followed by a car with the noch utensils and it works fine both in C and M-track...
I'll try to take some photos and post them for you to see :D
Ricardo Correia
Lisboa, Portugal
http://www.facebook.com/#!/pages/Meinburg/123173834418570
Offline Seetal
#13 Posted : 03 June 2009 06:54:38(UTC)
Seetal
If you have easy access and not too much track you could try a product used to removed adhesive. It is called Goo-gone here in the US. A bit on a kitchen towel goes a long way, I have found it to be very useful. No abrasion, does not harm plastic or metal (or carpet which is good for my carpetbahn). I do rub the rails after the goo gone has been applied. I have read (discussion about pottery) that some people think an oily residue is left but I have not noticed that.
Not sure if it is available for you but you may have a regional equivalent.
Offline FMS
#14 Posted : 07 June 2009 14:19:11(UTC)
FMS
John I do that already.
Sometimes I use a rag ith WD40 and after I use a few (without any solvents) just to clean everything. But my idea is to do it each time the track is used, so I need somekind of wagon for that purpose.
Bob, tks for the tip.
Today is sunday, I go to vote ( here we're voting for the european parliament), and there's a toy fair that I'm going to try to find.
After I might construct a cleaning car.
FMS
Offline Drongo
#15 Posted : 21 December 2009 02:36:47(UTC)
Drongo
Hi Kimball,
You mentioned the connecting of Red/Brown wires around the layout. Can you please tell me how to exactly attach the wires. I know how to attach to the C track with the small spade connectors, but where does the other end of the wires go? To the transformer, but exactly how? If there are several connections to the layout, then there would be several sets of wires coming back to the transformer. confused It's been 40 years since I study "Electricity" at university - if I'd known it was necessary to setup my train layout I would have been more interested in my studies. Smile
Greg
#16 Posted : 21 December 2009 03:19:39(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by youngagain
<br />Hi Kimball,
Greg
greg
start the first red/brown wire length to the piece of track that the power feed wires come in. run the new pair down the track. approx 2 M and connect to a set of connectors in apiece of track. at the other end of that track connect a new pair of feeder wires and run down the track and connect and connect another pair on the other end of that track and so on.
hope that helps
remember red goes to the terminal marked B.
nn
Offline sudibarba
#17 Posted : 21 December 2009 05:51:57(UTC)
sudibarba
Iuse acetone on a rag and lightly drag it on the tracks to avoid catching as best I can. Cleans great - never seen any harm to tracks. Track not ballasted.
Eric
Offline Drongo
#18 Posted : 21 December 2009 06:12:04(UTC)
Drongo
Hi Nev,
Just to clarify - there are no wires going back to the transformer. The initial pair of wires go from the CS2 to the track and then the connections are in parrallel.
I make a red wire with a spade connector on eack end and the same with the brown wire. Go down the track layout about 2 metres from where the CS2 connection is, and then attach one end of the red wire to the red side of the track, then go another 2 metres or so and connect the other end. Is this it? Sorry to be so particular, it just doesn't seem to be explained to clearly to me. Don't say it - "as thick as a brick"!!! Smile
#19 Posted : 21 December 2009 08:07:13(UTC)
Greg, No problems. Nothing back to the transformer.
Ok again.
Make up sets of wires One red one brown approx 2 M long with spade connectors on each end. On the piece of track where track power comes from the MS , CS or the old 6012, on the other end on the empty spades connect the set of wires that you have made up (RED and Brown)to the respective spades. (B=RED) Now go approx 2 Metres down track (Best below the track) and then connect the two wires Red and Brown to a set of connectors on one end of the track. ON THAT piece of track and on the other end's set of spades connect a new length of 2 wires (Red/brown) and connect this new set of wires to their respective set of Spades Red & Brown. now go down track again approx 2 metres and connect to a set of spades. on the other end connect a new set of wires.
If you are using Marklin Spade Connectors they are Ok (Expensive.)and a tight Fit. If using connectors from Dick Smiths they are a bit loose and need to be soldered.
Nothing back to power supplies/transformers. This is minimising voltage drop through the track connectors (not that it is much, but on a big layout with lots of turnouts it can be a small problem. This is the easy cure.
Another way is to run the 2 wires around under table. They need to be on some form of riser to have the wires about 40mm below table commencing from the Power-in track. Then at regular intervilles bare the wire. solder on a small length with a spade connector on the end. feed up and connect.
Nev
Offline cyberbeast41
#20 Posted : 21 December 2009 16:51:20(UTC)
cyberbeast41
I just use plain kitchen paper/towel to clean my tracks (I don't know the right English word, Moltonel is a brand of what I mean). It cleans quiet good and you can clearly see when the tracks are clean.
#21 Posted : 22 December 2009 00:24:17(UTC)
I think it would be pointless to a certain degree, to clean your track everytime it shows some discolouring.
Dirt or grease just does'nt fall from the sky like snow or rain.
You have to make sure you clean your wheels first otherwise you'll be cleaning your tracks day in day out.
Electrotren used to make a Shell cleaning car.
It had a springloaded cleaning pad (1 soft, 1 abrasive). The tankcar itself, you area able to fill it with a cleaning soltion and regulate the flow by adjusting the flow needle.
The cleaning solution itself, drop by drop landed onto the cleaning pad (soft).
I have 2 of these havy tank cars (tank = brass), 1 with the soft and 1 with the abrasive pad.
regards.,
Offline Drongo
#22 Posted : 22 December 2009 01:34:40(UTC)
Drongo
Thanks Nev. Now I know. Fortunately, at the moment I'm not having any significant voltage drop, however, as the layout enlargest, I'll need to do this wiring.
BTW - does anyone know much about the LUX vacuum cleaning car - apart from it being very expensive? If it is as good as they say, which model should I get for the C track?
#23 Posted : 22 December 2009 02:28:30(UTC)
YES it is great. I have the Vacuum and scrubber (Trackcleaner) combination.
OR if you only want the track cleaner get the model with the decoder.
with accumulator and digital decoder
(Article 9020)
Vac:
with Faulhaber engine and Märklin digital decoder
(Article 8820)
COmbination
vacuum cleaner wagon and track and overhead wire grinding wagon for H0 scale, equipped with one decoder for ...
two-wire alternating current system Märklin with Märklin decoder (Article 9620)
Web site:
http://www.lux-modellbau.de/html_uk/gleis.htm
Available from Mike or Lokshop.
Nev
Offline Breitenfurt
#24 Posted : 22 December 2009 12:48:24(UTC)
Breitenfurt
Do these track cleaners really work. I have both Marklin's Railcar and wagon with a pad underneath and neither really help much. I always end up using a piece of balsa wood dipped in IPA and it gets really black after a few rubs around the track. I know they two items are Z scale; maybe HO works better.
Chris
This page was generated in 1.105 seconds.
