Offline charles Sharpe
#1 Posted : 21 October 2009 00:46:14(UTC)
charles Sharpe
I have a couple Marklin signals on my lay out I had a lot of trouble to programmed them in fact a dealer did it for me. So what other makes are out there and that you use. I would like to stay with the ones that have lights. Also on a box for marklin signals they have V2 sticker on them what is the difference between V2 and not V2.
Charles
Edited by user 21 October 2009 22:01:00(UTC)  | Reason: Not specified
CHARLES SHARPE
#2 Posted : 22 October 2009 07:09:49(UTC)
The non V2 signals had a problem and M modified the design and then offered a free replacement service.
I have forgotten what the problem was. (seniors Moments)
N
Offline davemr
#3 Posted : 22 October 2009 13:36:11(UTC)
davemr
Hi Charles. Viessmann make a range of similar signals which are cheaper than Marklin. They have what appears to be a new range with built in decoders but i have not as yet tried them.
davemr
Offline Steamer01
#4 Posted : 22 October 2009 23:37:50(UTC)
Steamer01
[size=1" face="Verdana" id="quote]quote:Originally posted by charles Sharpe
<br />I have a couple Marklin signals on my lay out I had a lot of trouble to programmed them in fact a dealer did it for me. So what other makes are out there and that you use. I would like to stay with the ones that have lights. Also on a box for marklin signals they have V2 sticker on them what is the difference between V2 and not V2.
Charles
The signals worked very fine with the first Märklin digital components: Control unit / Central unit and with the keyboards. Than Märklin announced the first Central Station with systems and than it appeared sometimes that the modern light signals didn't do there job for the whole time. Therefore Märklin replaced the signal electronic.
The signals with the sticker v2 work fine with the CS1 and CS2.
Steamer01
CS3 60216 + 8 x 60174 + 1 x 60175
www.rensenmodelbaanwereld.com
#5 Posted : 24 October 2009 20:11:13(UTC)
charles Sharpe
Were is the best place to look at and buy Viessmann signals I am unable to find a wiring diagram in English.
CHARLES SHARPE
Offline Philip
#6 Posted : 24 October 2009 20:24:37(UTC)
Philip
About a diagram,
Look at there homepage:
http://www.viessmann-modell.com/
It´s in english
Philip
Philip.
Let's keep it simple.
MFDWPL
#7 Posted : 24 October 2009 20:33:59(UTC)
charles Sharpe
Hello Phillip.
I tried the other night to log on and get the English page but I was unable to get to it I think I must have been to tied to see it.
Many thanks Charles.
CHARLES SHARPE
Offline davemr
#8 Posted : 25 October 2009 01:33:17(UTC)
davemr
Viessmann catalogue is good for pics and a description of their signals.
davemr
Online xxup
#9 Posted : 25 October 2009 01:54:54(UTC)
Yep my Marklin signals have started to play up since M4 was enabled on the eCOS... No problem until then.. Sigh!
Offline prjbourge
#10 Posted : 27 October 2009 21:28:35(UTC)
prjbourge
[size=1" face="Verdana" id="quote]quote:Originally posted by davemr
<br />Hi Charles. Viessmann make a range of similar signals which are cheaper than Marklin. They have what appears to be a new range with built in decoders but i have not as yet tried them.
Hi Smile
I tried the new Viessmann range, which is described as "Multiplex" family. They are quite different from Märklin's models, but you cannot really talk about "built-in" decoders. In fact, the decoder is imbedded in a box, to which the signal is wired using a 4 pin connector. As opposed to M., the address is not encoded in the signal head but in the decoder (very easy to set, using a red button) : it means you can swap signal without recoding anything.
here is the decoder :
[img]UserPostedImage[/img]
and the signal :
#11 Posted : 27 October 2009 21:31:40(UTC)
Can this decoder from Viessmann works too for CS2...?
confused
Offline Graham HO
#12 Posted : 27 October 2009 22:49:12(UTC)
Graham HO
Interesting developement by Viessmann - external terminal blocks on this decoder, does this facility exist on other late model accessory control boxes?
Offline Ranjit
#13 Posted : 28 October 2009 04:09:51(UTC)
Ranjit
Hi Pierre,
I am so interested in this multiplexer gadget for light signals from Viessmann. What exactly does it do? How does it work?
Ranjit
#Get Vaccinated
Offline TimR
#14 Posted : 28 October 2009 04:31:36(UTC)
TimR
Indonesia
Link to Reynauld's Euro-Imports in regards to Viessmann 5229
http://www.euro-trains.c...ucts/Viessmann/5229.aspx
I hope someone can shed more light to this product.
Now collecting C-Sine models.
Offline Philip
#15 Posted : 28 October 2009 10:06:12(UTC)
Philip
TimR
Have a look at this site:
http://www.viessmann-mod...9_92349_01_DE-EN_web.pdf
Philip
Philip.
MFDWPL
#16 Posted : 28 October 2009 10:38:36(UTC)
There is also a Viessmann book available which covers their signal range. German only I suspect.
http://cgi.ebay.com/Vies...cher?hash=item5883d38b00
Offline Philip
#17 Posted : 28 October 2009 11:03:36(UTC)
Philip
Hello agian.
I can see that a lot of you likes Viessman and are lookning for information abuot there products.
why not go to there homepage, it´s also in english and they seem to have online shopping possibilities.
Philip
Philip.
MFDWPL
#18 Posted : 28 October 2009 20:41:51(UTC)
charles Sharpe
Could you tell me if the Viessmann 4043Ks signal would be suitable for stop and go were you have a loco that crosses the route of another loco. Also to use the same signal at the end of my platforms.
CHARLES SHARPE
#19 Posted : 28 October 2009 20:58:37(UTC)
It´s very expensive the new lightsignal from Viessmann!!!
About in same prices of Marklins digitalsignal.
[:0]
#20 Posted : 28 October 2009 22:19:51(UTC)
charles Sharpe
The Marklin 76391 is 52euro. The Viessmann 4043 is 23.56 euro both from lok shop
CHARLES SHARPE
Offline Fredrik
#21 Posted : 29 October 2009 15:38:18(UTC)
Fredrik
Yes - but then again you'll need a 5229 (multiplexer) from Viessmann to drive the signal, that's an additional € 31,16- (adds up to more than the M* signal as decoder is included).
Fredrik.
WWW: MJ-fjärren
#22 Posted : 29 October 2009 16:16:15(UTC)
charles Sharpe
I am not sure but I think the 5229 runs more than one signal.
CHARLES SHARPE
#23 Posted : 29 October 2009 18:23:26(UTC)
<br />I am not sure but I think the 5229 runs more than one signal.
Nope...!
Just only one signal per each decoder 5229.
#24 Posted : 29 October 2009 19:18:27(UTC)
charles Sharpe
It looks as if I am back to Marklin . The last time we tried to program them it was on the CS1 I now have a CS2 and I wonder if it is any simpler to do But I don't see how. As I have remarked in the past I ended up sending them back to the supplier to do for me I felt so embarrassed .[:(]
CHARLES SHARPE
Offline leo
#25 Posted : 31 October 2009 11:12:35(UTC)
leo
Hello all, this is my first post to the forum.
I bought the Viessmann multiplexer few months ago and very satisfied with the product. One unit of Viessmann 5229 Multiplexer can control 1 Home Signal and 1 Distant Signal.
Here are the photos I took few days ago. Hope you enjoy it Smile
Leo
thanks 1 user liked this useful post by leo
Offline Ranjit
#26 Posted : 31 October 2009 12:21:34(UTC)
Ranjit
Welcome to the forum, Leo!
Thank you for the illustration of the Viessmann 5229 multiplexer. So, it is possible to control two signals at a time, right?
Ranjit
#Get Vaccinated
Offline Fredrik
#27 Posted : 31 October 2009 14:00:11(UTC)
Fredrik
No, not really - it can control 1 signal and it's distant signal. It can't control 2 main signals.
Fredrik.
WWW: MJ-fjärren
Offline leo
#28 Posted : 31 October 2009 15:38:25(UTC)
leo
Fredrik is right. The 5229 can only controls one Home Signal at a time.
The 5229 needs only one command for the Home Signal and its Distant Signal.
e.g. Address 21 Red ---&gt; Home Signal HP0 --&gt; Distant Signal Ks2
Leo
Offline frankie
#29 Posted : 01 November 2009 13:48:49(UTC)
frankie
It seems to me though that you can control only aspects of the signals, home and distant, ie. it doesn't cut the power on the track.
Then you have some form of "train control" that stops the loco depending on the signal aspect.
Alessandro
I have a CS1 Reloaded!
Offline Ian555
#30 Posted : 01 November 2009 13:53:43(UTC)
Ian555
Hi Leo,
Welcome to the forum.
Ian.
#31 Posted : 01 November 2009 14:05:16(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by frankie
<br />It seems to me though that you can control only aspects of the signals, home and distant, ie. it doesn't cut the power on the track.
Nope...!
If you connect at "bremsen",you cut the power off!
By control signal...
Offline GSRR
#32 Posted : 01 November 2009 17:03:26(UTC)
GSRR
[size=1" face="Verdana" id="quote]quote:Originally posted by Goofy
Nope...!
Hello Leo,
Goofy, when you mention "bremsen" are you speaking of the braking module 72441 / 72442?
Thomas
#33 Posted : 01 November 2009 18:05:41(UTC)
If you take look at this manual from 5229:
www.viessmann-modell.com...9_92349_01_DE-EN_web.pdf
#34 Posted : 01 November 2009 22:17:03(UTC)
Hi and Welcome to the forum, Leo.
#35 Posted : 04 April 2015 14:31:00(UTC)
Viessmann do have a new signal decoder 52292,which you can connect 2 main signals.
switching Märklin Semaphore wingsignals with INFRARED gates (H0-scale)
by Holz1 25/04/2024 14:24:55(UTC)
Can Marklin signals work with the c-track from Trix? (General MRR)
by Sniklz 25/01/2024 23:35:50(UTC)
Light Signals (Track plans)
by PhilipS 04/01/2024 23:09:23(UTC)
Working with Marklin M track signals (General MRR)
by tandrschaefer 03/01/2024 21:41:00(UTC)
76442 braking module and 7649x signals (H0-scale)
by fabstar68 26/12/2023 23:44:25(UTC)
Set signal read after train passes with 7649x signals (H0-scale)
by fabstar68 26/12/2023 01:02:24(UTC)
New layout with C & K track. Will older M signals work? (Digital)
by matiSon 23/11/2023 02:53:09(UTC)
M84 Decoder & Signals (H0-scale)
by Eddie7979 18/10/2023 02:57:41(UTC)
Signals on bridges (Digital)
by Mille 27/08/2023 12:42:46(UTC)
viessmann signals multiplexer (Digital)
by Alfred Bugeja 20/08/2023 09:22:45(UTC)
where to put signals (H0-scale)
by heinrichhess 28/07/2023 21:39:03(UTC)
Use of Signals instead of Stop Markers in Train Controller (Model railroad software)
by garben 19/05/2023 20:18:57(UTC)
Question about Marklin signals (Digital)
by MegaExo 14/03/2023 18:58:43(UTC)
signals with yellow light (Digital)
by Mille 06/02/2023 04:15:35(UTC)
Signals and Ecos (Digital)
by cintrans 22/01/2023 14:06:59(UTC)
Wiring up Hobby signals without decoder or 72751 box. (H0-scale)
by Kaspar 24/11/2022 15:30:49(UTC)
How to mount analog signals to table? (H0-scale)
by Brian_BR96 06/10/2022 02:44:03(UTC)
Programming 763xx signals with CS3 help. (Digital)
by luckas 26/08/2022 15:57:31(UTC)
What do you control yours turnout and signals? (Digital)
by Goofy 11/07/2022 08:35:18(UTC)
Requirements and wiring for 'cosmetic only' signals (Model railroad software)
by luckas 10/06/2022 17:06:17(UTC)
New Marklin Digital Signals, any Online Primers or Guides? (Digital)
by 5HorizonsRR 29/05/2022 21:50:03(UTC)
Vintage signals, digital power and led bulbs (Model railroad wiring)
by BenP 08/05/2022 00:14:22(UTC)
Viessmann Regular or Multiplexer signals (in a computer controlled layout) (Digital)
by pmgsr 24/04/2022 21:21:35(UTC)
Circuit Track - HO K Track Configuration with Signals (H0-scale)
by rfeist 09/04/2022 20:58:07(UTC)
Cosmetic signals for CS3 (General MRR)
by Pasquiles 07/04/2022 23:16:09(UTC)
Advanced signals (General MRR)
by Thewolf 09/12/2021 04:01:46(UTC)
Signals in storage yard (Prototype)
by DaleSchultz 02/08/2021 00:05:41(UTC)
Viessmann signals with ESU SignalPilot and CS3 (Digital)
by swisslocofan 26/05/2021 23:56:39(UTC)
Märklin Model Signals Illustrated Handbook No.0341 (Collector's Corner general)
by phils2um 10/05/2021 01:45:00(UTC)
Signals (General MRR)
by Seacoast George 21/04/2021 17:26:38(UTC)
Correct Use of German Colored Light Signals? (Prototype)
by arnold894 14/04/2021 21:56:02(UTC)
HO scale signals for Marklin system (Model railroad wiring)
by biswasg 30/12/2020 08:56:46(UTC)
Marklin Signals (General MRR)
by Terry K 16/12/2020 14:42:23(UTC)
Signals, wiring, and blocks (Small scale)
by kfrankli 15/11/2020 14:52:28(UTC)
by morsing 26/08/2020 11:53:21(UTC)
Switching yard signals simultaneously. Analog. (Model railroad wiring)
by jvroyo65 30/06/2020 21:48:30(UTC)
m83 power supply + Viess. Signals (Digital)
by kehdi737w 27/06/2020 10:37:38(UTC)
Problem with 76391 signals. (H0-scale)
by gauravk84 12/06/2020 12:08:04(UTC)
Analog Signals (H0-scale)
by Brian_BR96 27/05/2020 22:40:42(UTC)
version 2 Marklin 763XX signals (H0-scale)
by Tex 13/04/2020 21:18:49(UTC)
help needed with installation of signals on analogue layout with signals on either side of the track (H0-scale)
by Primo -23K 14/03/2020 08:28:34(UTC)
Signals - 8939, et al (Small scale)
by gritz_1 21/02/2020 19:53:29(UTC)
Marklin signals “New” MFX/DCC (Digital)
by michelvr 21/02/2020 00:57:22(UTC)
smd led for signals (Digital)
by sonra 18/12/2019 23:33:28(UTC)
signals 76495 block signal (General MRR)
by springboard 10/11/2019 20:39:38(UTC)
Which home signals do I need? (Digital)
by LongHairedDavid 10/11/2019 16:00:00(UTC)
Using Marklin 8945 relay with 89391 Signals (Small scale)
by nickbeat09 28/09/2019 21:32:02(UTC)
connection problem of multiple signals (General MRR)
by stororoj 15/09/2019 04:35:31(UTC)
Signals 7044 and 7188 - Overhaul ? (General MRR)
by ocram63_uk 09/08/2019 19:11:06(UTC)
Signals are lighted up but I can not switch them (Model railroad wiring)
by avio 13/06/2019 19:36:10(UTC)
This page was generated in 1.506 seconds.
