Offline dandrikop
#1 Posted : 11 September 2009 14:47:15(UTC)
dandrikop
I have the ICE 2 set "29790" and I need to install interior lighting.
I had done this before with another ICE 2 set I had, but I didn't like it, so I sold it. My big problem was the intermediate car(s), as the cab control car had already electrical connections. Namely, I had installed a pick-up shoe and a ground spring per intermediate car. The problems with that configuration were the following:
- while the spring fitted each car fine, there was actually no pick-up shoe to fit ICE 2 intermediate cars. I had to do some modification on the pick-up shoe which was not very stable.
- the train had many pick-up shoes, so it was slow and made noise.
- if I needed to control the interior lighting digitally, I should put a digital decoder per intermediate and cab control car.
Has anybody implemented a solution such as the one of the expensive ICE 2 set 39711 for the electrical connections between intermediate cars?
#2 Posted : 11 September 2009 14:51:45(UTC)
Dandrikop, have a look at this thread
https://www.marklin-user...ault.aspx?g=posts&t=8780
#3 Posted : 11 September 2009 14:53:13(UTC)
Ooops, that is your thread!
Offline dandrikop
#4 Posted : 11 September 2009 16:05:26(UTC)
dandrikop
Yes, this was mine, but I haven't followed it up, so as to see all that information.
#5 Posted : 11 September 2009 16:38:22(UTC)
I have done a conversion but the method I've used would be to complicated to copy.
my ICE 2 has 2 motors (2 motorcars) with 10 intermediate cars.
on each coupling I've superglued 6 contacts 2 on each side and 1 on top & bottom.
I had 1 decoder and all wires (6) had been extended through the whole train.
1st wire: red = 2nd pickupshoe (2nd motorcar)
2nd wire: orange: common wire.
3rd wire: light for 2nd motorcar (white)
4th wire: light for 2nd motorcar (red)
5th wire: Aux 1
6th wire Aux 2.
all cars had led's.
I'm reconstructing the wiring by adding a function decoder into the 2nd motorcar.
This will eliminate the red wires and wires for headlighting(reverse) (2nd motorcar).
having 10 intermediate cars there is also a function decoder in the bord car, this function decoder will be removed and used in the 2nd motor car.
The end result will be as follows:
1st wire: orange common
2nd wire: Aux 1
3rd wire: Aux 2
the interior lighting is seperated into 2 circuits.
the wires from motorcar I will supply lighting for 5 cars and the same with the motor car II.
Car 5 and 6 will have no electrical connection as it would interfere with each decoder.
regards.,
Offline gachar001
#6 Posted : 11 September 2009 18:32:45(UTC)
gachar001
India
[size=1" face="Verdana" id="quote]quote:Originally posted by river6109
<br />on each coupling I've superglued 6 contacts 2 on each side and 1 on top & bottom.
Would you happen to have a picture of the contacts? What did you use?
I have the same problem with my ICE 2 lighting. I have a thin black wire running from the control car to the intermediate car with a tiny plug (The ones which are at the end of the pick up shoe wires). But on complex curves, the train sometimes derails if the wire snags.
Gautham
Atlanta, GA USA
#7 Posted : 11 September 2009 19:31:43(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by gachar001
I'll get the photos tomorrow.
Offline gachar001
#8 Posted : 11 September 2009 21:51:28(UTC)
gachar001
India
Gautham
Atlanta, GA USA
#9 Posted : 14 September 2009 13:32:07(UTC)
I tried doing that, but I think the copper contacts I was using were too thick, so they did not stay on.
Gauntham, if you read the thread I posted a link to in my first post here, you will see that Lutz gives the part numbers for the copper contacts, and also the complete coupler with copper contacts.
Offline gachar001
#10 Posted : 14 September 2009 22:44:35(UTC)
gachar001
India
Thanks. I found it.
Gautham
Atlanta, GA USA
ICE 2 Interior lighting (General MRR)
by dandrikop 19/12/2007 12:59:51(UTC)
This page was generated in 0.360 seconds.
