Offline rhfil
#1 Posted : 23 April 2024 16:35:50(UTC)
rhfil
The CS3 has an audio output jack that I would like to take advantage of. But I would like to know and can not find what type of jack it is - monaural or stereo? And what the output is 8 ohm or 16 ohm is fairly standard. I know it requires a male mini mic jack but which of the two types?
Offline PerR
#2 Posted : 23 April 2024 17:31:50(UTC)
PerR
You cannot connect a loudspeaker directly. The output has a high impedans and an active loudspeaker with internal amplifier is required. You can use the same type as for a normal loudspeaker for a PC.
Per
thanks 1 user liked this useful post by PerR
This page was generated in 0.420 seconds.
