Offline Mille
#1 Posted : 02 April 2024 16:32:44(UTC)
Mille
Is it a difference to use webbrowser
compare to VNC ?
#2 Posted : 02 April 2024 21:28:27(UTC)
Hi Mille
I think you ask about the CS3 and the latest update.
All that follows suppose that your CS3 is linked to your PC either directly or through a WiFi router.
VNC allows you to have a remote view of the CS3 screen on your PC
- you may take remotely control of your trains from your PC or make screen copies
WebBrowser Allows you also to take control of your CS3 from your PC
- in this case, this is not a screen copy but rather a larger view of your CS3 (NOT a screen copy)
- in this case there is a different user access (i.e.: the images on the CS3 and your PC are different and sometimes interlocked (e.g.: if you edit a loco on the web Browser, the fonction is not available on the CS3 (until you are finished doing it on the PC
- you CANNOT have screen copies of your CS3 because the images are DIFFERENT (e.g.: a larger layout)
- some fonctions are NOT available like the fonction mapping
Mobile device control
- this fonction works only if your CS3 is connected to a WiFi router
- a regular smartphone (iPhone 11 in my case) allows to control locos, point switches, view the layout, start events
Old application CS2.exe
- all fonctions of this Märklin-prepared application are OK to work with a CS3 with the exception of the LAYOUT (which will cause the application to terminate
Offline Mille
#3 Posted : 03 April 2024 09:01:40(UTC)
Mille
Thanks Jean
Can i create events in VNC?
Offline PerR
#4 Posted : 03 April 2024 09:54:42(UTC)
PerR
Yes.
You can do exactly the same in VNC as you can directly from the CS3 itself.
Per
This page was generated in 0.425 seconds.
